    my mirror freezes!
    98 Posts 5 Posters 53.9k Views 4 Watching
    • bheplerB Offline
      bhepler Module Developer
      This post is deleted!
        sdetweil @Manu85
        @Manu85 yes, follow the modules readme
          Manu85
          ok i try …
            Manu85
            I installed it at the top of the config.js file and I have an error when starting the MM “please create a config file”
            language: “fr”,
            timeFormat: 24,
            units: “metric”,
                    module: 'MMM-Logging',
                        // Module functions out of the box with nothing set here.
                        // See below for configurable options.
              sdetweil @Manu85
              @Manu85
                      },    // < ---- missing comma  (like behind all modules)
                Manu85
                language: “fr”,
                timeFormat: 24,
                units: “metric”,
                  Manu85
                  excuse me I sent the message twice because the site had crashed …, I test what you sent me
                    Manu85
                    I still have the same message.
                    language: “fr”,
                    timeFormat: 24,
                    units: “metric”,
                      sdetweil @Manu85
                      @Manu85 sorry, copy error on my part
                          } ,    // < --- add comma here  means continued
                        Manu85
                        impeccable, you’re the best, the mirror has restarted, and now what’s next please
                          sdetweil @Manu85
                          @Manu85 wait til it hangs… look at the MMM-Logging module instructions, where does it put the log file,
                          find it and practice how to view it
                            Manu85
                            ok i just deleted my automatic hourly reboot and i’ll wait for it to hang
                            • ? Offline
                              A Former User
                              Just for more information. It’s on MM v2. 11.0?
                              Because I have some freeze problem too. I have never in v2.10.x
                              I suspect electron versioning bug
                                sdetweil @Guest
                                @Bugsounet so far my 10 different mm systems have been running fine since upgrade (using my upgrade script)
                                • ? Offline
                                  A Former User
                                  weird, thx, i will inspect more
                                    Manu85
                                    @sdetweil Hello, as agreed I deleted the automatic reboot and this morning the MM is blocked (as usual) I use WinScp and when I wanted to quit it he offered to create a folder "my workspace "that’s what I did, I then opened this new file which connects me directly to the MMM-Logging module and after that I don’t know what to do!
                                      sdetweil @Manu85
                                      @Manu85 said in my mirror freezes!:
                                      sorry, what does that mean?
                                      by adding the mmm-logging module
                                      you get enhanced messages on the terminal window console like this with timestamps
                                      [24253:0406/055023.243727:INFO:CONSOLE(107)] "clearing timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (107)
                                      [24253:0406/055023.243800:INFO:CONSOLE(110)] "starting timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (110)
                                      [24253:0406/055023.243847:INFO:CONSOLE(112)] "timer started", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (112)
                                      so, you should have started your mirror like this to capture all the traces
                                      npm start >somefile
                                      now that the app is hung, you can open another winscp terminal window and then
                                      cd ~/.MagicMirror
                                      tail somefile
                                      which will show the last 15 lines of somefile by default
                                      tail -n number somefile
                                      where number is something like 20, 40, 50 will show more lines
                                      if you started with pm2, then the output is on the logs…
                                      pm2 logs --lines=100 >somefile
                                      will dump the last 100 lines into somefile so you can examine them
                                        Manu85
                                        I have a report which was created in MM “somfile” but I cannot send it because I have this error on the forum
                                        Error
                                        Post content was flagged as spam by Akismet.com
                                          sdetweil @Manu85
                                          @Manu85 u can send it to me by email, to my same userid as here at gmail
                                            Manu85
                                            when placing your order I have this:
                                            pi@raspberrypi:~/MagicMirror $ npm start >somefile
                                            [2020-04-06 14:36:28.593] [ERROR] 2020-04-06T14:36:28 { Error: listen EADDRINUSE 127.0.0.1:8080
                                            at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                                            at listenInCluster (net.js:1378:12)
                                            at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                                            at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
                                            errno: ‘EADDRINUSE’,
                                            code: ‘EADDRINUSE’,
                                            syscall: ‘listen’,
                                            address: ‘127.0.0.1’,
                                            port: 8080 } (/home/pi/MagicMirror/js/app.js:40 process.)
                                            code: ‘EADDRINUSE’,
                                            syscall: ‘listen’,
                                            • 2 / 5
