    MMM-Keyboard (a virtual touch keyboard)
    10 Posts 7 Posters 4.4k Views 8 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      Naaaa nanana Nana Nana
      You can touch this!
      As part of a bigger project to build a touch kitchen dashboard, I programmed a virtual touch keyboard based on the npm module simple-keyboard.
      This module can basically interact with every other module using the MM notification system!
      Download:
      [card:lavolp3/MMM-Keyboard]
      https://github.com/lavolp3/MMM-Keyboard
      Screenshots:
      example screenshot
      Features:
      • working with MM’s notification system (see below), can interact with every other module you can think of! (the notification function needs to be programmed into the module)
      • supports en and de locales, more on request
      • standard and numeric keyboard supported
      Working with the Keyboard
      Opening the keyboard
      The keyboard works with MagicMirror’s notification system. You can broadcast notifications from another module using the following parameters
      this.sendNotification("KEYBOARD", {
          key: "uniqueKey",
          style: "default"
      The payload of the notification must be an object containing two parameters:
      key: You can use any unique key, it is advised to use the module name. MMM-Keyboard will take the key and send it back for the module to understand it.
      style: Use “default” or “numbers” here
      Receiving data
      As soon as you hit the “SEND!”-Button the keyboard sends back the written content using the format
      this.sendNotification("KEYBOARD_INPUT", {
          key: "uniqueKey",
          message: "test"
      You can fetch this message by checking for the key component. Here an example:
      notificationReceived : function (notification, payload) {
          if (notification == "KEYBOARD_INPUT" && payload.key === "uniqueKey") {
              console.log(payload.message);
      Implemented modules
      • MMM-Bring (PR prepared, not implemented into master yet)
      Planned:
      • MMM-Todo
      • an own Timer / Alarm module
      For further implementations, contact me or send it as an issue here!
      Thanks to @jheyman for alpha testing and Francisco Hodges for the beautiful simple-keyboard npm module!
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      J L 2 Replies Last reply Reply Quote 2
        jheyman @lavolp3
        @lavolp3
        I can’t thank you enough for building this, I have now completed my touchscreen dashboard using this, and it was an integral part in making it useful, to add things to my shopping list directly on the screen :thumbs_up:
        lavolp3L 1 Reply Last reply Reply Quote 1
        • lavolp3L Offline
          lavolp3 Module Developer @jheyman
          @jheyman Thanks for the nice words and happy it works! Looks great!
          • lavolp3L Offline
            lavolp3 Module Developer @lavolp3
            This module is now integrated into MMM-Bring.
            Currently working an adaption Microsoft ToDo with keyboard support .
              ashleydaniel
              Looks really good, I did that on my last year project, but I forget that type of keyboard, because now I am using X-Bows Coupons curve keywords, and it helps me while typing my code.
              • L Offline
                lally james @lavolp3
                @lavolp3 said in MMM-Keyboard (a virtual touch keyboard):
                You can touch this!
                Download:
                https://github.com/lavolp3/MMM- Keyboard
                Screenshots:
                example screenshot
                Features:
                    key: "uniqueKey",
                    style: "default"
                Receiving data
                    key: "uniqueKey",
                    message: "test"
                Implemented modules
                Planned:
                • MMM-Todo
                that is very detailed information i was looking for man thanks for sharing, love this sort of detailed information
                  Dankodan
                  this.sendNotification(“KEYBOARD_INPUT”, {
                  key: “uniqueKey”,
                  message: “test”
                  sorry, which file should these parameters be inserted in, I can’t see the keyboard
                  thanks
                  key: “uniqueKey”,
                  message: “test”
                    sdetweil @Dankodan
                    @Dankodan that is how to send the notification via javascript code in some other module.
                    there are many modules that can send notifications for you and allow you to configure them in config.js
                    'KEYBOARD_INPUT”  is the notification id
                    and
                    key: “uniqueKey”,
                    message: “test”
                    is called the payload, or notification content/value
                      reverendz @sdetweil
                      @sdetweil said in MMM-Keyboard (a virtual touch keyboard):
                      key: “uniqueKey”,
                      message: “test”
                      I’m having the same issue as the previous poster.
                      I can’t figure out how to put this into the config.js and get it to work. When I put the example as listed, my config won’t build.
                      Can you provide an example?
                      Explicitly: the module (doesn’t matter which, ideally one of the defaults) and how it looks when you implement this.
                        sdetweil @reverendz
                        @reverendz this is NOT a config.js set of code.
                        from the module readme
                        The keyboard works with MagicMirror’s notification system. You can broadcast notifications from ====>another module<===== using the following parameters
                            key: "uniqueKey",
                            style: "default",
                            data: {},
                        and in the parms
                        swype	boolean	false	Activate swipe mode (experimental!) (not implemented yet)
                        alwaysShow	boolean	false	Always show keyboard. (not implemented yet)
                        note, NOT IMPLEMENTED YET
                        so, you SOME other module to invoke the notification
                        maybe command to notification ( so you could do it from a terminal window/ssh session)
                        see the third party list (linked in the header above) and put notification in the search field
                        there are a lot to choose from
                        • R reverendz referenced this topic on
