    "Npm start" doesn't work
    17 Posts 2 Posters 5.1k Views 1 Watching
      Mahieedaboss
      So I enter npm start and then it loads and all but then it just opens the application electron showing just a blak screen and my cursor. I check the files and saw that there was no config file so how do I get it??
        sdetweil @Mahieedaboss
        @Mahieedaboss is this a new install? did u do manual install?? git clone, & npm install?
        if so, you missed step 5 of the manual instructions
        Make a copy of the config sample file: cp config/config.js.sample config/config.js
          Mahieedaboss @sdetweil
          @sdetweil said in "Npm start" doesn't work:
          how would I copy a sample file.
          This is a new install so I’m pretty sure I did it manually. I did git clone and npm install myself
          P.s Jeez that was a fast response
            Mahieedaboss
              @Mahieedabos please see the steps
              https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
              in the future u may want to try my scripts for install and update
              which were removed from version 2.11, but listed in the alternative install section
              https://docs.magicmirror.builders/getting-started/installation.html#alternative-installation-methods
              you run the scripts directly from the repo , see the readme
                Mahieedaboss
                hi again,
                when I copy
                  Mahieedaboss
                  hi again,
                  when I copy
                  it just does nothing
                  why is this
                    @Mahieedaboss u are in the MagicMirror folder, right?
                    see step 3
                      Mahieedaboss
                      So I tried npm start and it appears I have the config file but now I have more problems
                      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                      [2020-04-09 17:08:55.739] [LOG] Starting MagicMirror: v2.11.0
                      [2020-04-09 17:08:55.742] [LOG] Loading config …
                      [2020-04-09 17:08:55.746] [LOG] Loading module helpers …
                      [2020-04-09 17:08:55.747] [LOG] No helper found for module: alert.
                      [2020-04-09 17:08:55.764] [LOG] Initializing new module helper …
                      [2020-04-09 17:08:55.765] [LOG] Module helper loaded: updatenotification
                      [2020-04-09 17:08:55.765] [LOG] No helper found for module: clock.
                      [2020-04-09 17:08:55.947] [LOG] Initializing new module helper …
                      [2020-04-09 17:08:55.948] [LOG] Module helper loaded: calendar
                      [2020-04-09 17:08:55.948] [LOG] No helper found for module: compliments.
                      [2020-04-09 17:08:55.948] [LOG] No helper found for module: currentweather.
                      [2020-04-09 17:08:55.948] [LOG] No helper found for module: weatherforecast.
                      [2020-04-09 17:08:55.961] [LOG] Initializing new module helper …
                      [2020-04-09 17:08:55.961] [LOG] Module helper loaded: newsfeed
                      [2020-04-09 17:08:55.961] [LOG] All module helpers loaded.
                      [2020-04-09 17:08:56.018] [LOG] Starting server on port 8080 …
                      [2020-04-09 17:08:56.028] [LOG] Server started …
                      [2020-04-09 17:08:56.029] [LOG] Connecting socket for: updatenotification
                      [2020-04-09 17:08:56.029] [LOG] Connecting socket for: calendar
                      [2020-04-09 17:08:56.030] [LOG] Starting node helper for: calendar
                      [2020-04-09 17:08:56.030] [LOG] Connecting socket for: newsfeed
                      [2020-04-09 17:08:56.030] [LOG] Starting module: newsfeed
                      [2020-04-09 17:08:56.030] [LOG] Sockets connected & modules started …
                      [2020-04-09 17:08:56.100] [LOG] Launching application.
                      When it loads now, I still have the black screen with cursor
                      What am I not doing???
                        @Mahieedaboss don’t see any problem there…
                        what pi is this?
                          Mahieedaboss
                          So I have the config files but I still only see a black screen and a cursor??
                            @Mahieedaboss i asked, what pi is this?
                              Mahieedaboss
                              I went through all the manual steps again but the problem with the no text just courser problem is still there!!! NOte: The command starting with
                              cp
                              when copied and pasted and run did nothing
                              S 3 Replies Last reply Reply Quote 0
                                @Mahieedaboss need more info… what pi is this please
                                  @Mahieedaboss said in "Npm start" doesn't work:
                                  it does not display any output, it just copies (cp) one file to another
                                    @Mahieedaboss as you don’t have much experience at the linux terminal window, I suggest you run my automated install script…
                                    do
                                    cd ~
                                    rm -rf MagicMirror
                                    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                      Mahieedaboss
                                      Mac mini…
