    "Npm start" doesn't work
    17 Posts 2 Posters 4.3k Views 1 Watching
      sdetweil @Mahieedaboss
      @Mahieedabos please see the steps
      https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
      in the future u may want to try my scripts for install and update
      which were removed from version 2.11, but listed in the alternative install section
      https://docs.magicmirror.builders/getting-started/installation.html#alternative-installation-methods
      you run the scripts directly from the repo , see the readme
        Mahieedaboss
        hi again,
        when I copy
          Mahieedaboss
          hi again,
          when I copy
          cp config/config.js.sample config/config.js
          it just does nothing
          why is this
            @Mahieedaboss u are in the MagicMirror folder, right?
            see step 3
              Mahieedaboss
              So I tried npm start and it appears I have the config file but now I have more problems
              [2020-04-09 17:08:55.739] [LOG] Starting MagicMirror: v2.11.0
              [2020-04-09 17:08:55.742] [LOG] Loading config …
              [2020-04-09 17:08:55.746] [LOG] Loading module helpers …
              [2020-04-09 17:08:55.747] [LOG] No helper found for module: alert.
              [2020-04-09 17:08:55.764] [LOG] Initializing new module helper …
              [2020-04-09 17:08:55.765] [LOG] Module helper loaded: updatenotification
              [2020-04-09 17:08:55.765] [LOG] No helper found for module: clock.
              [2020-04-09 17:08:55.947] [LOG] Initializing new module helper …
              [2020-04-09 17:08:55.948] [LOG] Module helper loaded: calendar
              [2020-04-09 17:08:55.948] [LOG] No helper found for module: compliments.
              [2020-04-09 17:08:55.948] [LOG] No helper found for module: currentweather.
              [2020-04-09 17:08:55.948] [LOG] No helper found for module: weatherforecast.
              [2020-04-09 17:08:55.961] [LOG] Initializing new module helper …
              [2020-04-09 17:08:55.961] [LOG] Module helper loaded: newsfeed
              [2020-04-09 17:08:55.961] [LOG] All module helpers loaded.
              [2020-04-09 17:08:56.018] [LOG] Starting server on port 8080 …
              [2020-04-09 17:08:56.028] [LOG] Server started …
              [2020-04-09 17:08:56.029] [LOG] Connecting socket for: updatenotification
              [2020-04-09 17:08:56.029] [LOG] Connecting socket for: calendar
              [2020-04-09 17:08:56.030] [LOG] Starting node helper for: calendar
              [2020-04-09 17:08:56.030] [LOG] Connecting socket for: newsfeed
              [2020-04-09 17:08:56.030] [LOG] Starting module: newsfeed
              [2020-04-09 17:08:56.030] [LOG] Sockets connected & modules started …
              [2020-04-09 17:08:56.100] [LOG] Launching application.
              When it loads now, I still have the black screen with cursor
              What am I not doing???
                @Mahieedaboss don’t see any problem there…
                what pi is this?
                  Mahieedaboss
                  So I have the config files but I still only see a black screen and a cursor??
                    @Mahieedaboss i asked, what pi is this?
                      Mahieedaboss
                      I went through all the manual steps again but the problem with the no text just courser problem is still there!!! NOte: The command starting with
                      cp
                      when copied and pasted and run did nothing
                      S 3 Replies Last reply Reply Quote 0
                        @Mahieedaboss need more info… what pi is this please
