    "Npm start" doesn't work
    17 Posts 2 Posters 5.3k Views 1 Watching
      Mahieedaboss
      how would I copy a sample file.
      This is a new install so I’m pretty sure I did it manually. I did git clone and npm install myself
      P.s Jeez that was a fast response
        sdetweil @Mahieedaboss
        @Mahieedabos please see the steps
        https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
        in the future u may want to try my scripts for install and update
        which were removed from version 2.11, but listed in the alternative install section
        https://docs.magicmirror.builders/getting-started/installation.html#alternative-installation-methods
        you run the scripts directly from the repo , see the readme
          Mahieedaboss
          hi again,
          when I copy
            Mahieedaboss
            hi again,
            when I copy
            cp config/config.js.sample config/config.js
            it just does nothing
            why is this
              @Mahieedaboss u are in the MagicMirror folder, right?
              see step 3
                Mahieedaboss
                So I tried npm start and it appears I have the config file but now I have more problems
                [2020-04-09 17:08:55.739] [LOG] Starting MagicMirror: v2.11.0
                [2020-04-09 17:08:55.742] [LOG] Loading config …
                [2020-04-09 17:08:55.746] [LOG] Loading module helpers …
                [2020-04-09 17:08:55.747] [LOG] No helper found for module: alert.
                [2020-04-09 17:08:55.764] [LOG] Initializing new module helper …
                [2020-04-09 17:08:55.765] [LOG] Module helper loaded: updatenotification
                [2020-04-09 17:08:55.765] [LOG] No helper found for module: clock.
                [2020-04-09 17:08:55.947] [LOG] Initializing new module helper …
                [2020-04-09 17:08:55.948] [LOG] Module helper loaded: calendar
                [2020-04-09 17:08:55.948] [LOG] No helper found for module: compliments.
                [2020-04-09 17:08:55.948] [LOG] No helper found for module: currentweather.
                [2020-04-09 17:08:55.948] [LOG] No helper found for module: weatherforecast.
                [2020-04-09 17:08:55.961] [LOG] Initializing new module helper …
                [2020-04-09 17:08:55.961] [LOG] Module helper loaded: newsfeed
                [2020-04-09 17:08:55.961] [LOG] All module helpers loaded.
                [2020-04-09 17:08:56.018] [LOG] Starting server on port 8080 …
                [2020-04-09 17:08:56.028] [LOG] Server started …
                [2020-04-09 17:08:56.029] [LOG] Connecting socket for: updatenotification
                [2020-04-09 17:08:56.029] [LOG] Connecting socket for: calendar
                [2020-04-09 17:08:56.030] [LOG] Starting node helper for: calendar
                [2020-04-09 17:08:56.030] [LOG] Connecting socket for: newsfeed
                [2020-04-09 17:08:56.030] [LOG] Starting module: newsfeed
                [2020-04-09 17:08:56.030] [LOG] Sockets connected & modules started …
                [2020-04-09 17:08:56.100] [LOG] Launching application.
                When it loads now, I still have the black screen with cursor
                What am I not doing???
                  @Mahieedaboss don’t see any problem there…
                  what pi is this?
                    Mahieedaboss
                    So I have the config files but I still only see a black screen and a cursor??
                      @Mahieedaboss i asked, what pi is this?
                        Mahieedaboss
                        I went through all the manual steps again but the problem with the no text just courser problem is still there!!! NOte: The command starting with
                        cp
                        when copied and pasted and run did nothing
                        S 3 Replies Last reply Reply Quote 0
                          @Mahieedaboss need more info… what pi is this please
                            @Mahieedaboss said in "Npm start" doesn't work:
                            it does not display any output, it just copies (cp) one file to another
                              @Mahieedaboss as you don’t have much experience at the linux terminal window, I suggest you run my automated install script…
                              do
                              cd ~
                              rm -rf MagicMirror
                              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                Mahieedaboss
                                Mac mini…
