    "Npm start" doesn't work
    17 Posts 2 Posters 4.5k Views 1 Watching
      Mahieedaboss @sdetweil
      @sdetweil said in "Npm start" doesn't work:
      cp config/config.js.sample config/config.js
      how would I copy a sample file.
      This is a new install so I’m pretty sure I did it manually. I did git clone and npm install myself
      P.s Jeez that was a fast response
        Mahieedaboss
          sdetweil @Mahieedaboss
          @Mahieedabos please see the steps
          https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
          in the future u may want to try my scripts for install and update
          which were removed from version 2.11, but listed in the alternative install section
          https://docs.magicmirror.builders/getting-started/installation.html#alternative-installation-methods
          you run the scripts directly from the repo , see the readme
            Mahieedaboss
            hi again,
            when I copy
              Mahieedaboss
              hi again,
              when I copy
              it just does nothing
              why is this
                @Mahieedaboss u are in the MagicMirror folder, right?
                see step 3
                  Mahieedaboss
                  So I tried npm start and it appears I have the config file but now I have more problems
                  [2020-04-09 17:08:55.739] [LOG] Starting MagicMirror: v2.11.0
                  [2020-04-09 17:08:55.742] [LOG] Loading config …
                  [2020-04-09 17:08:55.746] [LOG] Loading module helpers …
                  [2020-04-09 17:08:55.747] [LOG] No helper found for module: alert.
                  [2020-04-09 17:08:55.764] [LOG] Initializing new module helper …
                  [2020-04-09 17:08:55.765] [LOG] Module helper loaded: updatenotification
                  [2020-04-09 17:08:55.765] [LOG] No helper found for module: clock.
                  [2020-04-09 17:08:55.947] [LOG] Initializing new module helper …
                  [2020-04-09 17:08:55.948] [LOG] Module helper loaded: calendar
                  [2020-04-09 17:08:55.948] [LOG] No helper found for module: compliments.
                  [2020-04-09 17:08:55.948] [LOG] No helper found for module: currentweather.
                  [2020-04-09 17:08:55.948] [LOG] No helper found for module: weatherforecast.
                  [2020-04-09 17:08:55.961] [LOG] Initializing new module helper …
                  [2020-04-09 17:08:55.961] [LOG] Module helper loaded: newsfeed
                  [2020-04-09 17:08:55.961] [LOG] All module helpers loaded.
                  [2020-04-09 17:08:56.018] [LOG] Starting server on port 8080 …
                  [2020-04-09 17:08:56.028] [LOG] Server started …
                  [2020-04-09 17:08:56.029] [LOG] Connecting socket for: updatenotification
                  [2020-04-09 17:08:56.029] [LOG] Connecting socket for: calendar
                  [2020-04-09 17:08:56.030] [LOG] Starting node helper for: calendar
                  [2020-04-09 17:08:56.030] [LOG] Connecting socket for: newsfeed
                  [2020-04-09 17:08:56.030] [LOG] Starting module: newsfeed
                  [2020-04-09 17:08:56.030] [LOG] Sockets connected & modules started …
                  [2020-04-09 17:08:56.100] [LOG] Launching application.
                  When it loads now, I still have the black screen with cursor
                  What am I not doing???
                    @Mahieedaboss don’t see any problem there…
                    what pi is this?
                      Mahieedaboss
                      So I have the config files but I still only see a black screen and a cursor??
                        @Mahieedaboss i asked, what pi is this?
