    help with MovieInfo module
    11 Posts 3 Posters 8.2k Views 3 Watching
    • V Offline
      vicdilou
      Hi !
      I have clone and configure in congif.js but he don’t start
      Did anyone install it could tell me how to do it please ?
      Thanks.
      (the link to the module)
      • Y Offline
        yawns Moderator
        Did you also run npm install as described in the readme?
        • V Offline
          vicdilou
          Yes but I haven’t seen any change.
          • V Offline
            vicdilou
            Now the program start but the module is not on the screen, where do i have to put the api-key ?
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @vicdilou
              @vicdilou
                  module: 'MMM-MovieInfo',
                  position: 'top_right',
                      api_key: "PUTYOURAPIKEYINHERE"
              • V Offline
                vicdilou
                thank you, but there is just an empty space in the right top.
                  @vicdilou any errors in the terminal or electron console?
                  • V Offline
                    vicdilou @strawberry 3.141
                    @strawberry-3.141 Yes
                    The error is “Error getting movie info 500”
                      @vicdilou normally status code 500 menas internal server error
                      can you replace line 46-48 in node_helper.js with this, then we get probably more information
                      } else {
                          console.log(error);
                          console.log("Error getting movie info " + response.statusCode);
                          console.log(body);
                      • V Offline
                        @strawberry-3.141 i have this message now :
                        {“status_message”:“Internal error: Something went wrong, contact TMDb.”,“success”:false,“status_code”:11}
                          It’s fixed now, was some date manipulation
