    MMM-MplayerRadio
    46 Posts 7 Posters 18.1k Views 8 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer
      Description:
      I use an HifiBerry DAC+ on my mirror to play Spotify and Radio.
      The aim of this module is to provide a simple mechanism to play online radios on the mirror and switch between different stations.
      Because my wife and i like different stations i added profile support as well.
      The module can be controlled either by notifications or touch.
      It uses the Raspian “mplayer” to play “m3u” playlist files my favorite webpage of online radios (http://www.surfmusik.de/) provides. But you can use any m3u file you like.
      Download:
      MMM-MplayerRadio
      [card:Tom-Hirschberger/MMM-MplayerRadio]
      Version 0.1.3
      • the vlcWrapper.bash and vlcPaWrapper.bash scripts now stop vlc with a kill followed by a kill -9 after one second delay. The processes did not stop with the current versions of vlc otherwise.
      Version 0.1.2
      • the streamlink wrapper supports additional custom arguments like the vlc wrappers now
      Version 0.1.1
      • the vlcWrapper.bash and vlcPaWrapper.bash now support a variable count of custom options that can be added after the stream url. The options will be added directly to the vlc command line i.e. to disable certificate verification.
      Version 0.1.0
      • it is possible to display the current stream information if vlc is used now. Use the provided vlcWrapper.bash script to start vlc with the options needed.
      • modified the vlcPaWrapper.bash script to use the additional options needed to start vlc with enabled stream information support.
      • updated the options and URLs in the readme
      Version 0.0.14
      • added a new wrapper called vlcPaWrapper.bash which uses vlc to play a stream but sets the audio of vlc with pa_volume to a configurable value before
      Version 0.0.13
      • The module now waits for the old process to stop before it starts the new one during station changes which is essential for the xmms2 and HiFiBerryOS wrapper.
      • During a station change the module does not signal a stop of the old station and the start of the new station but only the station change to the frontend now. This is to reduce flickering.
      • The wrapper of HiFiBerryOS is now more robust if the station gets changed or if the playback gets stopped at the HiFiBerryOS interface
      Version 0.0.12
      • fixed wrong state (playing/stopped) if customCommand is used and the wrapper/program stops
      Version 0.0.11
      • All CSS classes are prefixed with the module name now
      • A new wrapper script is included to control a remote HiFiBerryOS instance via ssh
      Version 0.0.10
      • added a new wrapper script (streamlinkWrapper.bash) which can be used to play streams that do not send continuously
      Version 0.0.9
      This now Version 0.0.9 provides:
      • fixed the stations not being stopped if the module gets stopped (i.e. if the mirror gets stopped)
      Version 0.0.8
      This new Version 0.0.8 provides:
      • Fixed a bug which caused the module to ignore the initStation parameter at the first RADIO_PLAY notification
      Version 0.0.7
      This new Version 0.0.7 provides:
      • Fixed a bug which caused the module to be not loaded if only one station is used
      Version 0.0.6
      This new Version 0.0.6 provides:
      • the stations now get displayed correctly if scroll is disabled and there are less stations than needed (count of stations before the current station, the current station and the count of stations to display after)
      Version 0.0.5
      This new Version 0.0.5 provides:
      • The module got a total redesign. Instead of old styling with a table a new flexbox layout is used which makes it possible to do a lot more customization via css.
      • There is a new option which can be used to display more than one station before and after the currently active one.
      • There is a new option to enable scrolling (if active all stations will be displayed in a scrollable container).
      • If scrolling is active a new option can be enabled to focus the currently active station even if it has been changed by notification.
      • The streamInfo line can be hidden with a config option new.
      • The initial state feature (yellow radio instead of stations) has been removed.
      As there are a lot of problems with mplayer at the moment i strongly suggest to use the customCommand feature to play the stations with vlc. See the readme for details!
      Version 0.0.4
      • The flickering has been reduced massively.
      Version 0.0.3
      • it is possible to configure a custom script to play the stations. This way it is possible to use in example xmms2 instead of mplayer
      • added an autoplay feature. Simply add the index of the station you want to start automatically after the module started to the new config option “autoplay”. The index starts with 0.
      • reduced the flickering caused by station and profile changes
      Version 0.0.2
      • added buttons to increase/decrease the volume (send notification to MMM-Volume)
      Version 0.0.1
      The initial release provides the following features
      • Using multiple stations and add an logo for each one
      • The stations can be switched by notification or touch
      • Stations either can have no profile (valid for all profiles) or an profile string
      Screenshots
      E 1 Reply Last reply Reply Quote 2
      • O Offline
        omoioli
        Your module looks very great, smith notification and profil change ! Can you re-upload the pictures to see it ?
          wishmaster270 Module Developer @omoioli
          @omoioli
          Hi, great if you like it.
          What exactly do you mean. Currently there are a lot of problems with the forum. Are the screenshots not visible or do you like to have an different one?
          • O Offline
            omoioli @wishmaster270
            @wishmaster270 yes, screenshoots were not visible, but now, it’s good … may be a bug…
            • E Offline
              electros Project Sponsor @wishmaster270
              @wishmaster270 Wow this looks great, I like it. But can i have a request please?
              Can you try to make a version with xmms2 player ?. I want to use this to listening aacp or mp3 radio stream and mplayer is so slowly I push button to start and he start playing radio after nearly one minute. And if you can implement a volume graph and volume control will be great.
              Thank you.
                normally mplayer is very fast. Can you try to reduce the caching with the “mplayerCache” option either for one station or globally for all. The default value is 512 and may be a little high.
                There already exists an module to control the volume MMM-Volume which i use in my setup.
                • E Offline
                  @wishmaster270 ok i will try to modify caching to see what happend.
                  And about the volume yes i know that module but i have a touchscreen and can be better if i have a buttons for volume in same module from where i start listening.
                    wishmaster270 Module Developer @electros
                    @electros I will check if I can include two control buttons to increase/decrease the volume by sending notifications to MMM-Volume.
                    • E Offline
                      @wishmaster270 Thank you, and about the caching nothing change with that. here is one of the link http://www.surfmusik.de/m3u/magicfm,14949.m3u can you try please maybe i doing something wrong
                        I tried this link on the command line:
                        mplayer -cache 256 -playlist http://www.surfmusik.de/m3u/magicfm,14949.m3u
                        Mplayer complains that the station is to slow. It doesn’t even start playing in my case.
                        It looks like mplayer has some known problems with aac.
                        But you are right. If i use xmms2 it works.
                        The problem is, that xmms2 uses a totally different interface.
                        But also some good news. I released a new version 0.0.2 which adds two volume buttons.
                        • 1 / 5
