    MMM-MplayerRadio
    46 Posts 7 Posters 18.7k Views 8 Watching
      robfer
      Hi!
      my second post :)
      I’ve lost my first one somewhere , sorry if you read twice :) :)
      I’ve raspberry with AIY voice module , magic mirror software and a little touchscreen
      the touchscreen works good ( in the lego cabinet) with touch software like MMM-ModuleBar
      but I can’t use the buttons below the MMM-MplayerRadio , they seems dosn’t work or send notification
      the MplayerRadio module is working , and I really like hear the music from the module but i want to use the touch buttons too 😃
      i’ve used the “/etc/asound.conf” of your hints and the radio plays ok (with the “Pulse” configuration) but only if the trick below:
      I put the option DisplayStatioOnStartup: true and I click on the suggested radio
      (with this option = false, the radio dosn’t start or I cannot go in the menu with the radio display list)
      I’ve also installed MMM-Volume module too, but the volume button I suppose have the same problem of previous , play and next buttons
      Do you have any advice or hints or config example ?
      thanks for reading
      Roberto
      • wishmaster270W Offline
        wishmaster270 Module Developer @robfer
        @robfer Hi, normally there is some other module covering the buttons in such cases.
        You can solve this by setting z-index in your custom.css.
        The higher the index the more in the foreground the module will be.
        The following config is part of my custom.css file:
        .MMM-ImagesPhotos, .MMM-ImageSlideshow, .MMM-COVID19, .MMM-Spotify, .MMM-Temperature, .MMM-LEDStripControl {
            z-index: -1;
        .MMM-MplayerRadio {
            z-index: 999;
          robfer @wishmaster270
          @wishmaster270
          thanks,
          you was right, the module newsfeed cover the buttons on my little screen
          hiding and showing it solve my problem, now i can use the radio and the volume buttons too :)
          maybe without use the custom.css
          but in this case a little extra question, if you know: can I put standard module newsfeed in the custom.css file? (I tryed but seems not work)
            @robfer Hi, sure you can. The right class will be “.module.newsfeed”
            • T Offline
              totofar
              @bugsounet created notifications/patterns in his module MMM-GoogleAssistant to drive this module MMM-MplayerRadio.
              Did anyone manage to implement these commands in GoogleAssistant ? How does it work ?
              Thanks in advance
              • T Offline
                totofar
                Found the solution…
                FYI, for newbies like me…
                If you want to use MMM-GoogleAssistant to command MMM-MplayerRadio, just use the recipe installed by default with GA.
                To setup this function, just setup that way in config.js
                		  module: "MMM-GoogleAssistant",
                		  position: "fullscreen_above",
                			recipes: [
                			  "Reboot-Restart-Shutdown.js", "MMM-MplayerRadio.js",
                			debug: true,
                			assistantConfig: {...
                Then MPlayerRadio will be driven with the voice “Jarvis radio play”, “Jarvis radio next”, …
                • 3 / 3
