    MMM-Reddit two headers instead of just one
    5 Posts 2 Posters 857 Views 1 Watching
      JoMa25
      Hey Guys, I’m new to the MM community and wanted to put in a Reddit module I found on this forum. (https://github.com/kjb085/MMM-Reddit) Now as you can see in this image, I have two headers instead of just one. Does anyone know a solution? Some other user posted the same issue in the forum of the module maker but he didnt response (12 days ago).
      			module: "MMM-Reddit",
          				subreddit: 'aww',
      				displayType: 'image',
      				imageQuality: 'high',
      				count: 10,
      				show: 1,
      				width: 500,
      				showNumComments: false,
      				showHeader: true,
        bhepler Module Developer @JoMa25
        @JoMa25 - try turning off the showHeader in your config and see if one of the headers goes away. I didn’t look at the code, but it’s possible the module creator implemented his own header before the Magic Mirror framework started doing it.
        You can probably turn off the module-specific header and use the MagicMirror’s framework header. I don’t know if the header is supposed to be dynamic in the module, but a decent workaround may be:
                header: "Topics from s/aww",
                       subreddit: 'aww',
        		count: 10,
        		show: 1,
        		width: 500,
        		showHeader: false,
          JoMa25 @bhepler
          This post is deleted!
            @JoMa25 - sorry, was bouncing around abit on my code. See my edited post for an alternative.
              JoMa25 @bhepler
              @bhepler your custom header doesnt show
