    MMM-SynologySurveillance
    34 Posts 5 Posters 25.0k Views 5 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer
      Description:
      This module querys the mjpeg streams of cams connected to Synology Diskstations with the syno api and displays the cams in an column based grid.
      One cam can be displayed in a bigger view. This cam can either be changed by notification or click/touch.
      I use the mjpeg streams because i do not need any other tools to render/display them. The quality is not that good as with RTSP streams but for need the quality is good enough.
      Download:
      [card:Tom-Hirschberger/MMM-SynologySurveillance]
      Screenshots
      Vertical
      Horizontal
      Version 0.2.5
      • fixed not working alias for mjpeg cams
      • if a mjpeg cam is configured with a alias but without a name the alias is used as name now
      • updated the mjpeg example in the readme to use name instead of alias
      Version 0.2.4
      • fixed the replacement of the host and port parts in the URLs
      • if debug is enabled the clean URLs of the cams will be logged now. They can be directly entered to a browser to check the validity
      Version 0.2.3
      • fixed the module being crashed cause of the changes in 0.2.2
      • fixed the wrong camera being displayed in big profiles had been visited in the meantime where the whole module was hidden
      • introducing a new option moduleIsDisplayedInEveryProfile which needs to be set to true if MMM-ProfileSwitcher is used but the module is set to the ignore list and is displayed on all profiles
      Version 0.2.2
      • fixed current big camera and displayed cameras did not match the current used profile in some rare cases
      Version 0.2.1
      • increased the compatibility to older DSM versions. The paths of the web apis now will be queried with api versions instead of using a fixed one.
      • if the debug flag is set to true the MySynoSSClient prints more information, too.
      Version 0.2.0
      • instead of the syno library a custom implementation is used now. The custom implementation is compatible with newer releases of Surveillance Station (> 9.1) now
      • support of the skipOnPrivilegeError config option is dropped with the new implementation. If configured it will be ignored now.
      • cause the new implementation is able to fetch all information at once the refreshes of the gui could been reduced. Now all information of all DiskStations is fetched and the gui is refreshed once.
      • introducing a new config option changedPositionAnimationSpeed with this release. If the position of one cam changes and the gui needs to be refreshed this animation speed is used instead of the “usual” one. The option is set to 0 as default to reduce flickering.
      • if a position update fails for a cam the position indicator will now be reset to the previous position
      • reduced the console output of the module but introducing the debug config option to re-enable more output
      Version 0.1.4
      • introducing the new option imgDecodeCheckInterval which can either be set for all or for single cams. If the option is set to a value higher than 0 the module periodically (unit is seconds) checks if the displayed cam image is still decodeable. If not the URL gets reset and a refresh of all URLs is triggered. This is to avoid freezed cam images.
      • introducing minimumTimeBetweenRefreshs which prevents to refresh the URLs to often (i.e. cause of the new imgDecodeCheckInterval). The unit is milliseconds!
      • the module now tries to restore the old big cam setting if profiles get changed. So the last selected cam is displayed in big before the profile changed. To disable the new feature the new config option restoreBigAfterProfileChange can be set to false.
      • fixed all issues reported by the new automatic module scanning script developed by @KristjanESPERANTO
      Version 0.1.3
      • fixed a rare issue which caused position changes to not work with some nodejs versions (i.e. 16.3.1)
      Version 0.1.2
      • fixed host part not being replaced properly
      Version 0.1.1
      • Did a total refactoring of the code that creates the HTML elements
      • Did a refactoring of the code that fetches the URLs of the cameras from the NAS to increase the error handling
      • Added a option to add a timestamp to MJPEG URLs to avoid caching issues
      • Added the possibility to invalidate the cam URLs with a notification to force a refresh
      • Fixed animationSpeed being ignored if module is shown after it was hidden
      • Fixed profiles not working properly in all cases
      Version 0.1.0
      • It is now possible to display any mjpeg stream by adding dummy diskstations with cams that have a url configured
      Version 0.10.0
      • introducing the replacePortPart option which is need to use encrypted connections (https). The api returns the http port even if the information is fetched via an encrypted connection.
      Version 0.0.9
      • fixed timestamps being added to cam urls although the option disabled in the configuration
      • fixed timestamps only being added to the big cam in vertical view. Now the timestamps get added to all cam urls (if the option is enabled)
      Version 0.0.8
      • Catching errors of the Synology API in more scenarios now and keep the old url in these cases
      • added an option to force a update of the dom objects of this module if it gets shown after it was hidden (to avoid caching issues with the new electron version of MagicMirror 2.18 and above)
      • added an option to add an timestamp to the cam urls (to avoid caching issues with the new electron version of MagicMirror 2.18 and above)
      • added an option to specify the apiVersion in the configuration (only the versions supported by syno library can be used)
      Version 0.0.7
      • the Synology Diskstations throw privilege errors randomly; this is a known bug and caused some cams to disappear although an valid url had been provided at the last refresh; the default behavior now is to ignore this errors and keep the last url or position information; this can be changed with an new config option (skipOnPrivilegeError)
      • if an error occurs during the fetch of the position information of a camera the cam will be displayed without the information; next time the information is provided it will be updated
      Version 0.0.6
      • fixed an issue which caused position (ptz) changes to not work correctly if the internal position index differed to the ones used in the SynologyStation (i.e. because stations got deleted)
      • the view now only will be refreshed if either the cam stream or the ptz information changed after a fetch
      • it is now possible to force a refresh of the cam information by clicking on the dummy icon if no information had been provided previously
      • the PTZ information now only will be fetched if either showPositions or showBigPositions is active
      Version 0.0.5
      • fixed cam streams not updating after connection is to ds or cam is lost
      • fixed update issues of cam positions
      • fixed styles issues if cams with and without positions are mixed
      Version 0.0.4
      • it is now possible to move the cam to positions stored in the ds either by notification or by click/touch
      • the positions can be displayed as squares either only for the big and/or for the small cams
      • if next or prev position notification is called without specifying a cam the big one is used automatically
      Version 0.0.3
      • fixed a bug which caused wrong media URLs if multiple Diskstations are used
      • it is now possible to replace the protocol and host part of the media URLs (http://XXX.XXX.XXX.XXX) with the values configured. The Diskstation returns private IPs although the access is through a public IP otherwise.
      Version 0.0.2
      • Layouting is now organized with flex box layout instead of tables
      • Added two layouts (horizontal, vertical) which can be choosen by configuration
      • Column count of vertical layout now needs to be configured via css
      Version 0.0.1
      • query the urls of cams of Synology Diskstations with the syno api
      • display the cams in an grid based on columns
      • show one cam in a bigger view
      • change the bigger view cam by notification or click/touch
      • display different cams in different profiles
        digied
        Hi, I installed this model recently and all I see is a grey square with a little camera in it. How can I fix this?
          wishmaster270 Module Developer @digied
          @digied Hi,
          the gray square with camera symbol indicates that the module was not able to fetch the url from the nas.
          Make sure that the user you are using has permission to access for the Survalliance Station application.
          Does the log show any output?
            digied @wishmaster270
            @wishmaster270 This is my config:
                                module: "MMM-SynologySurveillance",
                                        showOneBig: true,
                                        addBigToNormal: false,
                                        showCamName: false,
                                        showBigCamName: false,
                                        showUnreachableCams: true,
                                        showPositions: true,
                                        showBigPositions: true,
                                        vertical: true,
                                        ds: [
                                                        protocol: "https",
                                                        host: "192.168.2.26",
                                                        port: "5000",
                                                        user: "ewalstra",
                                                        password: "*********",
                                                        replaceHostPart: true,
                                                        cams: [
        alias: "Voordeur",
            I can’t see where to put in the URL?
              @wishmaster270 It does:
              [02.01.2023 12:01.50.428] [ERROR] Whoops! There was an uncaught exception…
              [02.01.2023 12:01.50.430] [ERROR] TypeError: Cannot read properties of undefined (reading ‘listCameras’)
              at Class.getStreamUrls (/home/pi/MagicMirror/modules/MMM-SynologySurveillance/node_helper.js:76:17)
              at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-SynologySurveillance/node_helper.js:384:12)
              at Socket. (/home/pi/MagicMirror/js/node_helper.js:108:11)
              at Socket.emit (node:events:513:28)
              at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
              at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:614:39
              at process.processTicksAndRejections (node:internal/process/task_queues:78:11)
                @digied Hi,
                that’s definitely a error that should not happen. I will check this tomorrow.
                You can not add the url directly. It will be fetched from the NAS.
                But I am pretty sure that either your port or protocol setting is wrong. The default protocol is http with port 5000. If you access the NAS with protocol https it is port 5001 usually.
                Can you please try the following config:
                                            showOneBig: true,
                                            showCamName: false,
                                            vertical: true,
                                            ds: [
                                                            protocol: "http",
                                                            port: "5000",
                                                            user: "ewalstra",
                                                            cams: [
        alias: "Voordeur",
                Edit: I released a new version of the module is was working on the last weeks which improves the error handling. Please use the new version to avoid already fixed problems. I also added more examples to the README to make things about the protocols and ports clearer.
                  @wishmaster270 I’m sorry, still no luck. These are the logs:
                  pi@raspberrypi:~/.pm2/logs $ tail mm-error.log
                  [08.01.2023 11:34.06.023] [ERROR] TypeError: Cannot read properties of undefined (reading 'listCameras')
                      at Class.getStreamUrls (/home/pi/MagicMirror/modules/MMM-SynologySurveillance/node_helper.js:72:19)
                      at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-SynologySurveillance/node_helper.js:327:12)
                      at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:108:11)
                  [08.01.2023 11:34.06.024] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [08.01.2023 11:34.06.024] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  pi@raspberrypi:~/.pm2/logs $ tail mm-out.log
                  [08.01.2023 11:31.06.012] [LOG]   MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol http
                  [08.01.2023 11:32.06.009] [LOG]   MMM-SynologySurveillance: Received notification REFRESH_URLS
                  [08.01.2023 11:32.06.010] [LOG]   MMM-SynologySurveillance: Refreshing the urls!
                  [08.01.2023 11:32.06.011] [LOG]   MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol http
                  [08.01.2023 11:33.06.011] [LOG]   MMM-SynologySurveillance: Received notification REFRESH_URLS
                  [08.01.2023 11:33.06.013] [LOG]   MMM-SynologySurveillance: Refreshing the urls!
                  [08.01.2023 11:33.06.013] [LOG]   MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol http
                  [08.01.2023 11:34.06.013] [LOG]   MMM-SynologySurveillance: Received notification REFRESH_URLS
                  [08.01.2023 11:34.06.016] [LOG]   MMM-SynologySurveillance: Refreshing the urls!
                  [08.01.2023 11:34.06.017] [LOG]   MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol http
                  And this is the config:
                                          showOneBig: true,
                                          showCamName: false,
                                          vertical: true,
                                          ds: [
                                                          protocol: "http",
                                                          port: "5000",
                                                          user: "ewalstra",
                                                          password: "********",
                                                          cams: [
        alias: "Voordeur",
                    @digied
                    I tried to reproduce the error you are get with your config but it does not appear in all these cases:
                    • forgot to install npm install
                    • user does not exist
                    • user does exist but does not have the permissions
                    • host is wrong and does not exist
                    • host is a different host which does exist
                    What version of the module are you using? You can find the version in the package.json file.
                    What version of MagicMirror are you using?
                    How did you install the module?
                    What version of Synology DSM are you using?
                    What version of Synology Surveillance are you using?
                    Are there any errors in the Logs before this errors which may are related?
                      digied
                      It is:
                      “name”: “MMM-SynologySurveillance”,
                      “version”: “0.1.1”,
                      “description”: “”,
                      “main”: “MMM-SynologySurveillance.js”,
                      “dependencies”: {
                      “syno”: “^1.0.0”
                      “name”: “magicmirror”,
                      “version”: “2.22.0”,
                      Just following instructions:
                      cd ~/MagicMirror/modules
                      git clone https://github.com/Tom-Hirschberger/MMM-SynologySurveillance.git
                      cd MMM-SynologySurveillance
                      npm install.  this one I had to do using sudo npm install
                      7.1.1-42962 update 2
                      It is a DS218
                      9.0.2-10061
                      This is the log for npm start run:
                      pi@raspberrypi:~/MagicMirror/config $ npm start run
                      magicmirror@2.22.0 start
                      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js run
                      [15.01.2023 10:41.20.823] [LOG] Starting MagicMirror: v2.22.0
                      [15.01.2023 10:41.20.831] [LOG] Loading config …
                      [15.01.2023 10:41.20.838] [LOG] Loading module helpers …
                      [15.01.2023 10:41.20.840] [LOG] No helper found for module: alert.
                      [15.01.2023 10:41.20.859] [LOG] Initializing new module helper …
                      [15.01.2023 10:41.20.860] [LOG] Module helper loaded: updatenotification
                      [15.01.2023 10:41.20.862] [LOG] No helper found for module: clock.
                      [15.01.2023 10:41.20.863] [LOG] No helper found for module: MMM-connection-status.
                      [15.01.2023 10:41.21.281] [LOG] Initializing new module helper …
                      [15.01.2023 10:41.21.283] [LOG] Module helper loaded: MMM-SynologySurveillance
                      [15.01.2023 10:41.21.535] [LOG] Initializing new module helper …
                      [15.01.2023 10:41.21.537] [LOG] Module helper loaded: calendar
                      [15.01.2023 10:41.21.618] [LOG] Initializing new module helper …
                      [15.01.2023 10:41.21.620] [LOG] Module helper loaded: MMM-Formula1
                      [15.01.2023 10:41.21.622] [LOG] No helper found for module: weather.
                      [15.01.2023 10:41.21.623] [LOG] No helper found for module: MMM-Buienradar.
                      [15.01.2023 10:41.21.948] [LOG] Initializing new module helper …
                      [15.01.2023 10:41.21.949] [LOG] Module helper loaded: MMM-SolarEdgeLite
                      [15.01.2023 10:41.22.301] [LOG] Initializing new module helper …
                      [15.01.2023 10:41.22.302] [LOG] Module helper loaded: MMM-SystemStats
                      [15.01.2023 10:41.22.326] [LOG] Initializing new module helper …
                      [15.01.2023 10:41.22.326] [LOG] Module helper loaded: newsfeed
                      [15.01.2023 10:41.22.327] [LOG] All module helpers loaded.
                      [15.01.2023 10:41.22.435] [LOG] Starting server on port 8080 …
                      [15.01.2023 10:41.22.677] [LOG] Server started …
                      [15.01.2023 10:41.22.679] [LOG] Connecting socket for: updatenotification
                      [15.01.2023 10:41.22.679] [LOG] Starting module helper: updatenotification
                      [15.01.2023 10:41.22.680] [LOG] Connecting socket for: MMM-SynologySurveillance
                      [15.01.2023 10:41.22.682] [LOG] Connecting socket for: calendar
                      [15.01.2023 10:41.22.683] [LOG] Starting node helper for: calendar
                      [15.01.2023 10:41.22.684] [LOG] Connecting socket for: MMM-Formula1
                      [15.01.2023 10:41.22.685] [LOG] Starting module: MMM-Formula1
                      [15.01.2023 10:41.22.685] [LOG] Connecting socket for: MMM-SolarEdgeLite
                      [15.01.2023 10:41.22.686] [LOG] Starting module helper: MMM-SolarEdgeLite
                      [15.01.2023 10:41.22.686] [LOG] Connecting socket for: MMM-SystemStats
                      [15.01.2023 10:41.22.687] [LOG] Connecting socket for: newsfeed
                      [15.01.2023 10:41.22.688] [LOG] Starting node helper for: newsfeed
                      [15.01.2023 10:41.22.689] [LOG] Sockets connected & modules started …
                      [15.01.2023 10:41.22.714] [LOG] Launching application.
                      MESA-LOADER: failed to retrieve device information
                      MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: kan gedeeld objectbestand niet openen: Toegang geweigerd (search paths /usr/lib/aarch64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)
                      failed to load driver: kms_swrast
                      MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: kan gedeeld objectbestand niet openen: Toegang geweigerd (search paths /usr/lib/aarch64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)
                      failed to load swrast driver
                      [15.01.2023 10:41.26.401] [LOG] MMM-SynologySurveillance: Received notification CONFIG
                      [15.01.2023 10:41.26.402] [LOG] MMM-SynologySurveillance: Received notification INIT_DS
                      [15.01.2023 10:41.26.405] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol https
                      [15.01.2023 10:41.26.410] [ERROR] Whoops! There was an uncaught exception…
                      [15.01.2023 10:41.26.418] [ERROR] TypeError: Cannot read properties of undefined (reading ‘listCameras’)
                      at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-SynologySurveillance/node_helper.js:324:12)
                      [15.01.2023 10:41.26.420] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [15.01.2023 10:41.26.421] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      [15.01.2023 10:41.26.476] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/nl.dutch%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 300000
                      [15.01.2023 10:41.26.544] [LOG] Create new calendarfetcher for url: http://p103-caldav.icloud.com/published/2/Njc3ODUzOTEzNjc3ODUzOQyRiARRL2CkxgtBVQDZXfBmcEh4jRSjf1NpTv-kmUkeab9A4t6LtTrrc3BUTsPoy9oS4yCg4f5Rnt5FlMRu6Oo - Interval: 300000
                      [15.01.2023 10:41.26.574] [LOG] Create new calendarfetcher for url: http://p62-caldav.icloud.com/published/2/MzE2ODIwNDE4MzE2ODIwNJD9RGBryCg63_2az9y7tWOTHmUDf_W0Y3YkBa1tdgnP7AW7ihN1TLzhWzBnHSok2S9kxwdK6IkOT1I55L8cvuE - Interval: 300000
                      [15.01.2023 10:41.26.579] [LOG] Create new calendarfetcher for url: http://racingnews365.nl/ics/download/calendar-formula-2022.ics?all - Interval: 300000
                      [15.01.2023 10:41.26.583] [LOG] Create new calendarfetcher for url: https://wasteapi.ximmio.com/api/CallIcal?cn=Gemeente Almere&x=53d8db94-7945-42fd-9742-9bbc71dbe4c1&ty=null&ua=65222&sd=2021-12-21&ed=2025-01-09&path=https://wasteapi.ximmio.com&ln=nl&nt=1130 - Interval: 300000
                      [15.01.2023 10:41.26.743] [LOG] Create new newsfetcher for url: http://feeds.nos.nl/nosnieuws - Interval: 300000
                      [15.01.2023 10:41.26.748] [LOG] Create new newsfetcher for url: https://nl.motorsport.com/rss/f1/news/ - Interval: 300000
                      [15.01.2023 10:41.26.752] [LOG] MMM-Formula1 received a notification: CONFIG
                      [15.01.2023 10:41.26.772] [LOG] MMM-Formula1 is fetching the race schedule for the current season
                      [15.01.2023 10:41.26.797] [LOG] MMM-Formula1 is fetching DRIVER standings for the current season
                      [15.01.2023 10:41.26.802] [INFO] Checking git for module: MMM-connection-status
                      [15.01.2023 10:41.26.855] [INFO] Checking git for module: MMM-SynologySurveillance
                      [15.01.2023 10:41.26.918] [INFO] Checking git for module: MMM-Formula1
                      [15.01.2023 10:41.27.030] [INFO] Checking git for module: MMM-Buienradar
                      [15.01.2023 10:41.27.139] [LOG] MMM-Formula1 is returning DRIVER standings for the current season
                      [15.01.2023 10:41.27.154] [INFO] Checking git for module: MMM-SolarEdgeLite
                      [15.01.2023 10:41.27.215] [INFO] Newsfeed-Fetcher: reloadInterval set to ttl=6000000 for url https://nl.motorsport.com/rss/f1/news/
                      [15.01.2023 10:41.27.289] [INFO] Checking git for module: MMM-SystemStats
                      [15.01.2023 10:41.27.556] [INFO] Checking git for module: default
                      [15.01.2023 10:41.28.370] [INFO] Calendar-Fetcher: Broadcasting 0 events.
                      [15.01.2023 10:41.28.463] [INFO] Newsfeed-Fetcher: Broadcasting 50 items.
                      [15.01.2023 10:41.28.820] [INFO] Calendar-Fetcher: Broadcasting 26 events.
                      [15.01.2023 10:41.28.947] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                      [15.01.2023 10:41.29.181] [INFO] Calendar-Fetcher: Broadcasting 32 events.
                      [15.01.2023 10:41.29.350] [INFO] Calendar-Fetcher: Broadcasting 18 events.
                      [15.01.2023 10:41.30.356] [ERROR] Moment Timezone has no data for GMT+0200. See http://momentjs.com/timezone/docs/#/data-loading/.
                      [15.01.2023 10:41.30.359] [ERROR] Moment Timezone has no data for GMT+0200. See http://momentjs.com/timezone/docs/#/data-loading/.
                      [15.01.2023 10:41.30.362] [ERROR] Moment Timezone has no data for GMT+0200. See http://momentjs.com/timezone/docs/#/data-loading/.
                      [15.01.2023 10:41.30.390] [INFO] Calendar-Fetcher: Broadcasting 10 events.
                      [512768:0115/104146.877630:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                      [512768:0115/104205.526070:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
                      [512768:0115/104223.429194:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
                      [15.01.2023 10:42.25.641] [LOG] MMM-SynologySurveillance: Received notification REFRESH_URLS
                      [15.01.2023 10:42.25.642] [LOG] MMM-SynologySurveillance: Refreshing the urls!
                      [15.01.2023 10:42.25.642] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol https
                      [15.01.2023 10:42.25.644] [ERROR] Whoops! There was an uncaught exception…
                      [15.01.2023 10:42.25.645] [ERROR] TypeError: Cannot read properties of undefined (reading ‘listCameras’)
                      [15.01.2023 10:42.25.645] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [15.01.2023 10:42.25.646] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      [15.01.2023 10:43.25.645] [LOG] MMM-SynologySurveillance: Received notification REFRESH_URLS
                      [15.01.2023 10:43.25.646] [LOG] MMM-SynologySurveillance: Refreshing the urls!
                      [15.01.2023 10:43.25.646] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol https
                      [15.01.2023 10:43.25.650] [ERROR] Whoops! There was an uncaught exception…
                      [15.01.2023 10:43.25.652] [ERROR] TypeError: Cannot read properties of undefined (reading ‘listCameras’)
                      [15.01.2023 10:43.25.653] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [15.01.2023 10:43.25.653] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        @digied
                        There two things i do not understand…
                        • Did you modify your package.json? The original one of the module contains “syno”: “latest” as a dependency. Which will install version 2.2.0 currently. But the part of your package.json contains “syno”: “^1.0.0” which will install the latest 1.x version. I did not use any 1.X version in my module and do not know if the surveillance part did already exist in this old version. Please use the original version of the package.json. No need to make any changes to it.
                        • Why did you need to use sudo for npm install? Only files in the module folder get modified by npm install of this module. There is no need to use sudo in a regular installation. Installing things with sudo may break things and it is not sure that the version of npm of the current user is used. Please do not use sudo for npm install. And never install with npm -g global option.
                          @wishmaster270 Hi! Strange thing about the version. So I just did this again:
                          pi@raspberrypi:~/MagicMirror/modules $ cat MMM-SynologySurveillance/package.json
                          “version”: “0.1.1”,
                          “description”: “”,
                          “dependencies”: {
                          “syno”: “^1.0.0”
                          “scripts”: {
                          “test”: “echo "Error: no test specified" && exit 1”
                          “repository”: {
                          “type”: “git”,
                          “url”: “git@github.com:Tom-Hirschberger/MMM-SynologySurveillance.git”
                          “author”: “Thomas Hirschberger”,
                          “license”: “MIT”,
                          “bugs”: {
                          “url”: “https://github.com/Tom-Hirschberger/MMM-SynologySurveillance/issues”
                          “homepage”: “https://github.com/Tom-Hirschberger/MMM-SynologySurveillance/#readme”
                          pi@raspberrypi:~/MagicMirror/modules $ sudo rm -r MMM-SynologySurveillance/
                          pi@raspberrypi:~/MagicMirror/modules $ ls
                          default MMM-connection-status MMM-Formula1 MMM-MercedesMe MMM-RTSPStream MMM-SolarEdgeLite MMM-SystemStats
                          MMM-Buienradar MMM-F1 MMM-IPCam MMM-OpenWeatherForecast MMM-SolarEdge MMM-SpeedTest MMM-Worldclock
                          pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-SynologySurveillance.git
                          Cloning into ‘MMM-SynologySurveillance’…
                          remote: Enumerating objects: 298, done.
                          remote: Counting objects: 100% (103/103), done.
                          remote: Compressing objects: 100% (84/84), done.
                          remote: Total 298 (delta 38), reused 42 (delta 19), pack-reused 195
                          Receiving objects: 100% (298/298), 1.27 MiB | 15.34 MiB/s, done.
                          Resolving deltas: 100% (184/184), done.
                          default MMM-connection-status MMM-Formula1 MMM-MercedesMe MMM-RTSPStream MMM-SolarEdgeLite MMM-SynologySurveillance MMM-Worldclock
                          MMM-Buienradar MMM-F1 MMM-IPCam MMM-OpenWeatherForecast MMM-SolarEdge MMM-SpeedTest MMM-SystemStats
                          “version”: “0.1.1”,
                          “description”: “”,
                          “dependencies”: {
                          “syno”: “latest”
                          “devDependencies”: {},
                          “scripts”: {
                          “repository”: {
                          “type”: “git”,
                          “license”: “MIT”,
                          “bugs”: {
                          So now I see also the sync: latest.
                          Thus I did the npm install again, but it seems I don’t have enough access for it:
                          pi@raspberrypi:~/MagicMirror/modules $ cd MMM-SynologySurveillance/
                          pi@raspberrypi:~/MagicMirror/modules/MMM-SynologySurveillance $ cat package.json
                          “version”: “0.1.1”,
                          “description”: “”,
                          “dependencies”: {
                          “syno”: “latest”
                          “scripts”: {
                          “repository”: {
                          “type”: “git”,
                          “license”: “MIT”,
                          “bugs”: {
                          Still good, so now I run the npm install:
                          pi@raspberrypi:~/MagicMirror/modules/MMM-SynologySurveillance $ npm install
                          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                          npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                          added 76 packages, and audited 77 packages in 7s
                          2 packages are looking for funding
                          run npm fund for details
                          2 high severity vulnerabilities
                          To address all issues (including breaking changes), run:
                          npm audit fix --force
                          Run npm audit for details.
                          Ok, this time no errors… Let me start MM:
                          pi@raspberrypi:~/MagicMirror $ npm start run
                          [16.01.2023 16:49.50.904] [LOG] Starting MagicMirror: v2.22.0
                          [16.01.2023 16:49.50.911] [LOG] Loading config …
                          [16.01.2023 16:49.50.922] [LOG] Loading module helpers …
                          [16.01.2023 16:49.50.925] [LOG] No helper found for module: alert.
                          [16.01.2023 16:49.50.943] [LOG] Initializing new module helper …
                          [16.01.2023 16:49.50.944] [LOG] Module helper loaded: updatenotification
                          [16.01.2023 16:49.50.946] [LOG] No helper found for module: clock.
                          [16.01.2023 16:49.50.947] [LOG] No helper found for module: MMM-connection-status.
                          [16.01.2023 16:49.51.366] [LOG] Initializing new module helper …
                          [16.01.2023 16:49.51.368] [LOG] Module helper loaded: MMM-SynologySurveillance
                          [16.01.2023 16:49.51.618] [LOG] Initializing new module helper …
                          [16.01.2023 16:49.51.620] [LOG] Module helper loaded: calendar
                          [16.01.2023 16:49.51.691] [LOG] Initializing new module helper …
                          [16.01.2023 16:49.51.693] [LOG] Module helper loaded: MMM-Formula1
                          [16.01.2023 16:49.51.694] [LOG] No helper found for module: weather.
                          [16.01.2023 16:49.51.695] [LOG] No helper found for module: MMM-Buienradar.
                          [16.01.2023 16:49.52.016] [LOG] Initializing new module helper …
                          [16.01.2023 16:49.52.016] [LOG] Module helper loaded: MMM-SolarEdgeLite
                          [16.01.2023 16:49.52.362] [LOG] Initializing new module helper …
                          [16.01.2023 16:49.52.363] [LOG] Module helper loaded: MMM-SystemStats
                          [16.01.2023 16:49.52.387] [LOG] Initializing new module helper …
                          [16.01.2023 16:49.52.387] [LOG] Module helper loaded: newsfeed
                          [16.01.2023 16:49.52.388] [LOG] All module helpers loaded.
                          [16.01.2023 16:49.52.495] [LOG] Starting server on port 8080 …
                          [16.01.2023 16:49.52.734] [LOG] Server started …
                          [16.01.2023 16:49.52.736] [LOG] Connecting socket for: updatenotification
                          [16.01.2023 16:49.52.737] [LOG] Starting module helper: updatenotification
                          [16.01.2023 16:49.52.738] [LOG] Connecting socket for: MMM-SynologySurveillance
                          [16.01.2023 16:49.52.739] [LOG] Connecting socket for: calendar
                          [16.01.2023 16:49.52.740] [LOG] Starting node helper for: calendar
                          [16.01.2023 16:49.52.740] [LOG] Connecting socket for: MMM-Formula1
                          [16.01.2023 16:49.52.741] [LOG] Starting module: MMM-Formula1
                          [16.01.2023 16:49.52.742] [LOG] Connecting socket for: MMM-SolarEdgeLite
                          [16.01.2023 16:49.52.742] [LOG] Starting module helper: MMM-SolarEdgeLite
                          [16.01.2023 16:49.52.744] [LOG] Connecting socket for: MMM-SystemStats
                          [16.01.2023 16:49.52.744] [LOG] Connecting socket for: newsfeed
                          [16.01.2023 16:49.52.745] [LOG] Starting node helper for: newsfeed
                          [16.01.2023 16:49.52.746] [LOG] Sockets connected & modules started …
                          [16.01.2023 16:49.52.819] [LOG] Launching application.
                          [16.01.2023 16:49.56.198] [LOG] MMM-SynologySurveillance: Received notification CONFIG
                          [16.01.2023 16:49.56.200] [LOG] MMM-SynologySurveillance: Received notification INIT_DS
                          [16.01.2023 16:49.56.202] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol https
                          [50739:0116/164958.846579:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                          [16.01.2023 16:49.59.003] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/nl.dutch%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 300000
                          [16.01.2023 16:49.59.045] [LOG] Create new calendarfetcher for url: http://p103-caldav.icloud.com/published/2/Njc3ODUzOTEzNjc3ODUzOQyRiARRL2CkxgtBVQDZXfBmcEh4jRSjf1NpTv-kmUkeab9A4t6LtTrrc3BUTsPoy9oS4yCg4f5Rnt5FlMRu6Oo - Interval: 300000
                          [16.01.2023 16:49.59.056] [LOG] Create new calendarfetcher for url: http://p62-caldav.icloud.com/published/2/MzE2ODIwNDE4MzE2ODIwNJD9RGBryCg63_2az9y7tWOTHmUDf_W0Y3YkBa1tdgnP7AW7ihN1TLzhWzBnHSok2S9kxwdK6IkOT1I55L8cvuE - Interval: 300000
                          [16.01.2023 16:49.59.065] [LOG] Create new calendarfetcher for url: http://racingnews365.nl/ics/download/calendar-formula-2022.ics?all - Interval: 300000
                          [16.01.2023 16:49.59.070] [LOG] Create new calendarfetcher for url: https://wasteapi.ximmio.com/api/CallIcal?cn=Gemeente Almere&x=53d8db94-7945-42fd-9742-9bbc71dbe4c1&ty=null&ua=65222&sd=2021-12-21&ed=2025-01-09&path=https://wasteapi.ximmio.com&ln=nl&nt=1130 - Interval: 300000
                          [16.01.2023 16:49.59.285] [LOG] Create new newsfetcher for url: http://feeds.nos.nl/nosnieuws - Interval: 300000
                          [16.01.2023 16:49.59.291] [LOG] Create new newsfetcher for url: https://nl.motorsport.com/rss/f1/news/ - Interval: 300000
                          [16.01.2023 16:49.59.294] [LOG] MMM-Formula1 received a notification: CONFIG
                          [16.01.2023 16:49.59.315] [LOG] MMM-Formula1 is fetching the race schedule for the current season
                          [16.01.2023 16:49.59.342] [LOG] MMM-Formula1 is fetching DRIVER standings for the current season
                          [16.01.2023 16:49.59.347] [INFO] Checking git for module: MMM-connection-status
                          [16.01.2023 16:49.59.390] [INFO] Checking git for module: MMM-SynologySurveillance
                          [16.01.2023 16:49.59.467] [INFO] Checking git for module: MMM-Formula1
                          [16.01.2023 16:49.59.554] [INFO] Checking git for module: MMM-Buienradar
                          [16.01.2023 16:49.59.594] [INFO] Newsfeed-Fetcher: reloadInterval set to ttl=6000000 for url https://nl.motorsport.com/rss/f1/news/
                          [16.01.2023 16:49.59.698] [LOG] MMM-Formula1 is returning DRIVER standings for the current season
                          [16.01.2023 16:49.59.704] [INFO] Checking git for module: MMM-SolarEdgeLite
                          [16.01.2023 16:49.59.781] [INFO] Checking git for module: MMM-SystemStats
                          [16.01.2023 16:49.59.923] [INFO] Checking git for module: default
                          [16.01.2023 16:49.59.982] [INFO] Newsfeed-Fetcher: Broadcasting 50 items.
                          [16.01.2023 16:50.00.666] [INFO] Calendar-Fetcher: Broadcasting 0 events.
                          [16.01.2023 16:50.00.713] [LOG] MMM-SynologySurveillance: Found cam Generic_ONVIF-001
                          [16.01.2023 16:50.01.085] [INFO] Calendar-Fetcher: Broadcasting 26 events.
                          [16.01.2023 16:50.01.252] [INFO] Calendar-Fetcher: Broadcasting 31 events.
                          [16.01.2023 16:50.01.389] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
                          [16.01.2023 16:50.01.750] [INFO] Calendar-Fetcher: Broadcasting 18 events.
                          [16.01.2023 16:50.02.554] [ERROR] Moment Timezone has no data for GMT+0200. See http://momentjs.com/timezone/docs/#/data-loading/.
                          [16.01.2023 16:50.02.555] [ERROR] Moment Timezone has no data for GMT+0200. See http://momentjs.com/timezone/docs/#/data-loading/.
                          [16.01.2023 16:50.02.556] [ERROR] Moment Timezone has no data for GMT+0200. See http://momentjs.com/timezone/docs/#/data-loading/.
                          [16.01.2023 16:50.02.569] [INFO] Calendar-Fetcher: Broadcasting 10 events.
                          [16.01.2023 16:50.02.884] [LOG] MMM-SynologySurveillance: {
                          “dsIdx”: 0,
                          “camStreams”: {
                          “Generic_ONVIF-001”: “https://datanas//192.168.2.26:5000/webapi/entry.cgi?api=SYNO.SurveillanceStation.Stream.VideoStreaming&version=1&method=Stream&format=mjpeg&cameraId=2&StmKey=“c0a94e2b77e2887405161edf7a32964b””
                          [50702:0116/165002.966141:ERROR:cert_verify_proc_builtin.cc(670)] CertVerifyProcBuiltin for datanas failed:
                          ----- Certificate i=0 (CN=synology,O=Synology Inc.,L=Taipel,C=TW) -----
                          ERROR: No matching issuer found
                          [50739:0116/165036.029773:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
                          And this is what the MM is showing:
                          Before I got the little cam showing, now it is this square. Any thoughts?
                            @wishmaster270 btw, the cam itself is found:
                            [16.01.2023 16:55.55.543] [LOG] MMM-SynologySurveillance: Received notification REFRESH_URLS
                            [16.01.2023 16:55.55.544] [LOG] MMM-SynologySurveillance: Refreshing the urls!
                            [16.01.2023 16:55.55.545] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol https
                            [16.01.2023 16:55.57.908] [LOG] MMM-SynologySurveillance: Found cam Generic_ONVIF-001
                            [16.01.2023 16:55.58.816] [LOG] MMM-SynologySurveillance: {
                            “dsIdx”: 0,
                            “camStreams”: {
                              @digied That log looks totally different than the other one. What did you change?
                                @wishmaster270 I changed nothing. I only fetched the module again as you can see. The latest module is now installed with npm install. So no sudo this time. Now what?
                                  @wishmaster270 I see that my previous post wasn’t published. So I repeat it; I deleted the MMM-SynologySurveillance map and did the git clone again. This time I see the line syno:latest. So I did the npm install without the sudo and restarted MM. Now instead of the grey square with the cam, I get a grey square with some little square in it like this:
                                  So now what?
                                  S wishmaster270W 2 Replies Last reply Reply Quote 0
                                    sdetweil @digied
                                    @digied because users with reputation below 2, have all their posts reviewed.
                                    it JUST showed up in the review queue, and I approved it…
                                    please don’t double post… I DO have other things to do…
                                      @digied Hi,
                                      it’s nearly perfect. Now the needed library and the access to the NAS works.
                                      The output of your log shows that the fetched URL contains the hostname of your NAS AND the IP.
                                      Maybe there is a bug in my replaceHostname function.
                                      Your config contains a replaceHostPart set to true.
                                      Can you set it to false please.
                                      Edit: Now that I see all your posts things are clearer ;-)
                                        digied @sdetweil
                                        @sdetweil Sorry…
                                          @wishmaster270 Great! I did see the certificate error so I changed the https/5001 into http/5000 in the config and now the log shows this:
                                          [16.01.2023 20:49.14.962] [LOG] MMM-SynologySurveillance: {
                                          “dsIdx”: 0,
                                          “camStreams”: {
                                          “Generic_ONVIF-001”: “http://datanas//192.168.2.26:5000/webapi/entry.cgi?api=SYNO.SurveillanceStation.Stream.VideoStreaming&version=1&method=Stream&format=mjpeg&cameraId=2&StmKey="6058a182182e0c518d126bbf69e2e350"”
                                          [73749:0116/204923.065357:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                                          [73749:0116/204930.176714:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
                                          [73749:0116/204930.183104:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
                                          [16.01.2023 20:50.05.716] [LOG] MMM-SynologySurveillance: Received notification REFRESH_URLS
                                          [16.01.2023 20:50.05.718] [LOG] MMM-SynologySurveillance: Refreshing the urls!
                                          [16.01.2023 20:50.05.719] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol http
                                          [16.01.2023 20:50.08.721] [LOG] MMM-SynologySurveillance: Found cam Generic_ONVIF-001
                                          [16.01.2023 20:50.09.721] [LOG] MMM-SynologySurveillance: {
                                          “dsIdx”: 0,
                                          “camStreams”: {
                                          Now the certificate error is gone, but still no image from the cam.
                                            @wishmaster270 Sorry, haven’t seen your change of the replaceHostname before. I now set it to false and now I can see the image, but very small at the moment. SO the stream is working now, I just have to get the image larger now. Thanks for your help!
