    Refresh modules / MagicMirror without running pm2 restart?
    17 Posts 4 Posters 6.5k Views 4 Watching
    • C Offline
      cotxwx
      Good Day,
      I’m using MMM-RAIN-RADAR on my MM, and it’s great. Family loves it, and even though support for it has been suspended, we’ll continue to use it. One of the issues I notice with it, though, is that the module stops updating after a couple of hours. The module is still there, but the radar content disappears. I’ve setup a cron to run “pm2 restart mm.sh” every four hours, but that seems to be a bit overkill, and I’ve recently discovered the 4 hours interval isn’t even enough. We still find it stops updating radar content.
      Which brings me to my question. I’ve read there is no way to “reload” individual modules, but is there anything faster / more efficient to update / reload MM without restarting the whole service? Something I could potentially cron to run every hour or so?
      Thank you!
        sdetweil
        @cotxwx said in Refresh modules / MagicMirror without running pm2 restart?:
        MMM-RAIN-RADAR
        when it stops processing, open the developers window, ctrl-shift-i on the keyboard, select the tab labeled ‘console’,
        enter ‘radar’ (no quotes) in the filter field and scroll up to see any errors…
        I think there should be an unhandled promise rejection error…
        • C Offline
          cotxwx
          I will grab that next time it locks up. Thanks!
          • C Offline
            cotxwx @sdetweil
            Is there something specific I should be looking for here? It just locked up and this is all I see.
              sdetweil @cotxwx
              @cotxwx hm… I have it loaded too… we shall see
              C 1 Reply Last reply Reply Quote 1
              • C Offline
                cotxwx @sdetweil
                @sdetweil If you haven’t had this issue before, that pretty much rules out the module itself, I’d guess. I do have a FW at my egress, with some DNS block lists. It doesn’t seem logical that it would load initially, but fail an hour or two later, but I’ve seen weirder.
                (Unless, of course, you’ve just loaded it. In that case, ignore my last statement).
                  sdetweil @cotxwx
                  @cotxwx just loaded for 1st time ever…
                  have fixed a few things already… my system does module hiding for screen sleep…
                  it doesn’t… added error handler for the case I think is the problem… we will see…
                  • C Offline
                    cotxwx @sdetweil
                    @sdetweil if you’ve just loaded it, watch out for “updateOnWarning:” in the config.js - If you don’t set it to ‘0’, the entire module disappears if there are no active warnings in your area. I learned that one the hard way. :)
                    Thanks for the assistance!
                      sdetweil @cotxwx
                      @cotxwx hm… mine is showing, did not set that variable
                        sdetweil @cotxwx
                        @cotxwx mine has never stopped working and never reported an error
                        • C Offline
                          cotxwx @sdetweil
                          @sdetweil Good to know, thank you. I’ll start looking in to my FW logs and see if something stands out. I really appreciate you taking the time to do this.
                          • C Offline
                            cotxwx
                            Well, temporary workaround for anyone having a similar issue…
                            Installed xdotool and created a shell script to “press” ctrl+r every hour. Now it’ll just refresh itself at the top of the hour.
                              sdetweil @cotxwx
                              @cotxwx weird. i can’t get mine to stall…
                              • P Offline
                                Privacywonk @sdetweil
                                @cotxwx I am experiencing the same issue. Do you by chance turn your mirror monitor off? Mine is hooked up to a TV HDMI input and the issue seems to present itself when I switch between HDMI inputs…
                                  sdetweil @Privacywonk
                                  @Privacywonk hm. I don’t see that at all.
                                  I have 4 different devices running mm attached to the 4 HDMI ports on my tv, and don’t see any behavior problems switching
                                  Pi4 (4k)
                                  pi3 (1080p)
                                  pi0 (1080p)
                                  and
                                  jetson nano (4k)
                                    RJDaPirate
                                    I’m experiencing the same issue with my MM. Module worked fine for weeks not won’t last an hour before the Rain Radar Module goes dark.
                                      sdetweil @RJDaPirate
                                      @RJDaPirate when it goes dark, open the developers window ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
                                      you can also filter messages by module, by putting part of the module name in the filter field, rain, for example
                                      let us know
