    How to declare an array in config.js?
    6 Posts 3 Posters 1.5k Views 3 Watching
    • F Offline
      fischershaw
      How does one declare an array in config.js within the config object? Just using [] does not work. For instance, declaring the following within a module’s config object:
      biff: ['muffy','sport','spam']
      does NOT create an array. Instead, what is created is the comma separated string: “muffy,sport,spam”.
      • bheplerB Offline
        bhepler Module Developer @fischershaw
        @fischershaw - Try double quotes. The " character.
        biff: ["muffy","sport","spam"],
        Don’t forget the trailing comma.
        • F Offline
          fischershaw @bhepler
          @bhepler Yes, the trailing comma is present. The config.js file is syntactically correct, it just produces unexpected results. In this case a string instead of an array.
            sdetweil @fischershaw
            @fischershaw @bhepler the way you have done it works for me…
            from my MyCovid19 module
            in config.js
            			config:{
            				countries:["Italy","USA","China","Spain", "France",'Sweden'],
            in my code
             for(var i in this.config.countries){
                    switch(this.config.countries[i].toLowerCase()) {
            oh, single or double quotes doesn’t matter, even in the same array, long as they are matched
            why do you think it is a string? its an array of strings
            • open the developers window, (npm start dev or ctrl-shift-i on the keyboard),
            • select the sources tab,
            • look thru the items on the left, expand modules, find your module, click its .js file ,
            • then put a stop (click on the line edge to the left of the 1st statement after start),
            • then hit f5 (refresh page) and the page will be reloaded and the debugger will stop on that statement,
            • u can examine the variables in the config object
            F 1 Reply Last reply Reply Quote 1
            • F Offline
              fischershaw @sdetweil
              @sdetweil My dumb error which I corrected. Sorry to bother you.
                @fischershaw is ok, we all learn… I just spent 2 hours trying to figure out why an api request failed, 404 not found
                I had spelled apikey with an uppercase K…
                which debugging approach did you use?
