    read csv-data and put it in an array
    313 Posts 3 Posters 484.3k Views 4 Watching
      sdetweil
      new getDom(), without header or footer
      	getDom: function() {
      		var wrapper = this.createEl("div",null,null,null);
      		if(Object.keys(this.active_birthdays).length>0){
      			// create your table and header here
      		    // create TBODY section with day names
      		    var tBody = this.createEl("tBody", "birthday-tbody", "tbody", wrapper );
      			for(var birthday of Object.keys(this.active_birthdays)){
      				for(var person of this.active_birthdays[birthday]){
      				    var bodyTR = this.createEl("tr", "birthday-tr-body",null, tBody);
      					    var bodyTDimage = this.createEl("td","birthday-td-image", null, bodyTR );
      					    	bodyTDimage.appendChild(document.createTextNode(birthday));
      					    var bodyTD = this.createEl("td", "birthday-td-body", null, bodyTR );
      							bodyTD.appendChild(document.createTextNode(person.name));
      						var ageTD = this.createEl("td","birthday-td-age", null, bodyTR  );
      					    	ageTD.appendChild(document.createTextNode(person.age));
      // create your table footer here
      		// pass the created content back to MM to add to DOM.
      		return wrapper;
      • PerlchampP Offline
        Perlchamp
        the classes are not addressed :
        … without header and footer.
        why the classes are null ?
          sdetweil @Perlchamp
          @Perlchamp sorry, typo
          className with upper case
          	createEl : function (type, id, className, parent, value){
          		var el= document.createElement(type)
          		if(id)
          			el.id=id
          		if(className)
          			el.className=className
          		if(parent)
          			parent.appendChild(el)
          		if(value)
          			el.appendChild(document.createTextNode(value))
          		return el
            Perlchamp
            i set the classes in uppercase, allthough in the css-file. but the classes are not adressed.
            by the way. maybe there is a problem with TWO cells in a row, because the daynumbers are OVER the names. if you look at the picture i send before (not the last post), than you can see, that the daynumbers are in ONE row with the names …
              sdetweil @Perlchamp
              @Perlchamp well, part of the problem is the ID of the cells is the same for each row… removing id and class (which I don’t have)
              works
              cells don’t NEED ids… but if u wanted, you would have to create a counter to append each loop to make the ids unique
              new createEl which does text value too
              		if(id)
              			el.id=id
              		if(className)
              		if(parent)
              		if(value)
              		return el
              and table header
              	createTableHeader: function(parent, className, columnlabels){
              		var header = document.createElement("tr")
              		for(columnName of columnlabels){
              			this.createEl("th",null,className, header,columnName)
              		parent.appendChild(header)
              		return header
              getdom()
              	// this is the major worker of the module, it provides the displayable content for this module
              			// create your table  here
              			var table = this.createEl("table", "birthday-table", null, wrapper );
              			// table header here, array of column names
              			var table_header=this.createTableHeader(table, null, ["date","Name","age"])
              		    var tBody = this.createEl("tBody", "birthday-tbody", null, table );
              				    var bodyTR = this.createEl("tr", null,null, tBody);
              					    var bodyTDimage = this.createEl("td",null, null, bodyTR , birthday );
              					    var bodyTD = this.createEl("td", null, null, bodyTR , person.name);
              						var ageTD = this.createEl("td",null, null, bodyTR  ,person.age );
              		return wrapper;
                Perlchamp
                ok, i’ve seen, the header function … uff, all is placed right (code).
                i don’t see the day of birth. the first cell is still the problem :-(
                  sdetweil @Perlchamp
                  @Perlchamp with my code I see
                  I removed class
                  date Name age
                  12.05 Sam 69
                  02.05 Frank 81
                  02.05 Sue 81
                  05.05 mary 65
                  10.05 eee EEEEE 51
                  16.05 fff FFFFF 8
                  16.05 ggg GGGGG 32
                  27.05 hhh HHHHH 18
                    Perlchamp
                    i have a calendar OVER the birthdaylist, so i DON#T need the month in the first cell. the FIRST cell has a calendar sheet as background-image, THOUGH i DON’T need the leading null of the day of birth. should be:
                    5 Sam 69
                    Mary 12
                    8 Frank 81
                    15 Sue 81
                    did you seen the images i did send ?
                    and, of course, people with the same day of birth without day of birth
                      sdetweil @Perlchamp
                      @Perlchamp no images email or text
                      (cannot do fixed font here)
                      date	Name	age
                      12	Sam	69
                      2	Frank	81
                              Sue	81
                      5	mary	65
                      10	eee EEEEE	51
                      16	fff FFFFF	8
                              ggg GGGGG	32
                      27	hhh HHHHH	18
                      code
                      			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
                      		    var birthdays_seen= {}
                      				    		var bd =""
                      					    	if(birthdays_seen[birthday] == undefined){
                      					    		bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0]
                                   				 	        birthdays_seen[birthday] = true
                      					 	   var bodyTDimage = this.createEl("td",null, null, bodyTR , bd );
                      		return wrapper;
                        Perlchamp
                        my code:
                           createEl : function (type, id, className, parent, value) {
                        	var el= document.createElement(type);
                        	if(id)
                        	    el.id = id;
                        	if(className)
                        	    el.className = className;
                        	if(parent)
                        	    parent.appendChild(el);
                        	if(value)
                        	    el.appendChild(document.createTextNode(value));
                        	return el;
                            createTableHeader: function(parent, className, columnlabels) {
                        	var header = document.createElement("tr");
                        	for(columnName of columnlabels) {
                        	    this.createEl("th", null, className, header, columnName);
                        	parent.appendChild(header);
                        	return header;
                        	Log.log(JSON.stringify(this.active_birthdays))
                        	if ((moment() > this.midnight) || (!this.loaded)) {
                        	    var month = moment().month();
                        	    var year = moment().year();
                        	    var monthName = moment().format("MMMM");
                        	    var monthLength = moment().daysInMonth();
                        	    if(Object.keys(this.active_birthdays).length>0) {
                        		// create table
                        		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper)
                        		// create tableheader
                        		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table);
                        		for(var birthday of Object.keys(this.active_birthdays)) {
                        		    for(var person of this.active_birthdays[birthday]) {
                        			var bodyTR = this.createEl('tr', "birthday-tr-body", "tr-body" , tBody);
                        			if (birthday.charAt(0) === "0") {
                        			    birthday = birthday.replace("0","");
                        			    birthday = birthday.substring(0,1);
                        			var bodyTDimage = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, birthday.substring(0,2));
                        			var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY" , bodyTR, person.name);
                        			var ageTD = this.createEl("td", "birthday-td-age", "TD-AGE", bodyTR  ,person.age );
                        	    // Create TFOOT section -- currently used for debugging only
                        	    return wrapper;
                        	this.loaded = true;
                        • 24
                        • 25
                        • 26
                        • 27
                        • 28
                        • 31
                        • 32
                        • 26 / 32
