    read csv-data and put it in an array
    313 Posts 3 Posters 540.0k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp you copied all this exactly, right?
      			module:"MyCovid19",
      			disabled:false,
      			position:"top_left",
      			classes: 'sam',
      			config:{
      				countries:["Italy","USA","China","Spain", "France",'Sweden'],
      				// line colors can be any definition of color either a name ,or a hex string
      				// one per country above, used in order,
      				line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
      				chart_type:"cumulative_deaths",  // or "cumulative deaths"
      				chart_title:"cumulative deaths by country", // however u want to label
      				// the vertical steps on the chart.. how tall u want it to be and how mant increments
      				ranges:{min:0,max:30000,stepSize:5000},
      				// size of the chart in pixels
      			    width: 400,
      			    height: 400,
      			    // only used if we need to debug something
      			    debug:false,
      			    startDate:'02/01/2020',
      			    //backgroundColor: 'white',
      • PerlchampP Offline
        Perlchamp
        my config yet:
        			module:"MyCovid19",
        			disabled:false,
        			classes: 'sam',
        			config:{
        				countries:["Italy"],
        				//countries:["Italy","USA","China","Spain", "France",'Sweden'],
        				//line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
        				line_colors:['white'],
        			    width: 400,
        			    height: 400,
        			    debug:false,
          sdetweil @Perlchamp
          @Perlchamp I used yours exactly, and works
            Perlchamp
            may it need time to load the raw data?
            i will start it, drink a coffee, will come back and see …
              sdetweil @Perlchamp
              @Perlchamp raw data is the csv file from the source
              it should be there within a few seconds…
                sdetweil
                I will be busy for next few hours with grandson
                  Perlchamp
                  my old config doesn’t go either. something’s wrong. but what ?
                    sdetweil @Perlchamp
                    @Perlchamp did you do the npm install in my module folder per the instructions?
                      Perlchamp
                      shame on me. i didn’t install npm , tztztz …
                      ok, now it works fine …
                      the mistake i made before was to create an empty node_helper.js in my modul-folder, though the errors came …
                      how said, everything’s fine now, but i will have a lot of work writing a node_helper.js. i copied your node_helper.js (sample) ini my module-folder => no errors :-)
                      how said, i’m a noob and i don’t know, if i can handle this all to manage.
                      i want to code a small app, showing me the birthdays of the actual month. like this:
                      maybe you can be my tutor, taking my hands and help me …
                      so long
                      many thanks in advance
                      stay healthy
                      keep corona away
                        sdetweil @Perlchamp
                        @Perlchamp said in read csv-data and put it in an array:
                        there is a minimum set of stuff to do… its not small if you don’t understand the stuff…
                        I will answer questions and teach a little of the structure… I won’t write anything for you.
                          Perlchamp
                          that’s not what i wanted (writing code for me). my big problem is, not to know how i can start, how i can test code-snippets and so on …
                          i read some articles, but when i want to test some lines of code, i don’t know what to do. in my magicmirror module i can’t do that => error messages … i hope that i have expressed myself clearly and understandably …
                          if i have a code-snoppet, go to terminal and put in
                          node xxx.js
                          path not found, module not found, and many other error messages … maybe i soon despair …
                            sdetweil @Perlchamp
                            @Perlchamp is the xxx.js in the current folder? if not u need to give path to the file
                            you can do in MM module, with messages… there are two parts… the server side (node_helper) whose messages (console.log) come out on the same terminal window
                            the browser side (modulename.js) uses Log.log. and displays only in the developer window
                            I have modified a logging module that will display them together on the terminal window
                            https://github.com/sdetweil/MMM-Logging
                            install this as the FIRST module in the list
                            use this definition in config.js
                                        module: 'MMM-Logging',
                                        disabled: false,
                                            // Module functions out of the box with nothing set here.
                                            // See below for configurable options.
                                            echoLocal: true,
                                            echoRemote: true,
                                            overwriteBrowserMethods: true,
                                            format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
                              Perlchamp
                              thanks a lot, i will try to “play” with it. can take some time …
                                sdetweil @Perlchamp
                                @Perlchamp ok, if you are trying to use the csv-> somethign libraries and installed them in you module folder, then u want to be IN that folder to run your sample node xxx.js tests so the module folder path is right for require()
                                  Perlchamp
                                  @sdetweil said in read csv-data and put it in an array:
                                  you mean in my module folder? it’s called “MMM-birthdaylist” …
                                    sdetweil @Perlchamp
                                    @Perlchamp correct
                                    cd ~/MagicMirror/modules/MMM-birthdaylist
                                    node xxx.js
                                    note xxx.js can’t do anything specifically MagicMirror related no module register no sendSocketNotification
                                      Perlchamp
                                      ok, thanks a lot sam :-)
                                      no i will try to play with it.
                                        Perlchamp
                                        Log.log("hello Log");
                                        => Log.log(“hello Log”);
                                        ReferenceError: Log is not defined
                                        at Object. (/home/thomas/MagicMirror/modules/MMM-birthdaylist/test.js:1:1)
                                        at Module._compile (internal/modules/cjs/loader.js:778:30)
                                        at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)
                                        at Module.load (internal/modules/cjs/loader.js:653:32)
                                        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                        at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                                        at startup (internal/bootstrap/node.js:283:19)
                                        at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                                        console.log("hello console");
                                        => hello console
                                          Perlchamp
                                          another question:
                                          what can i do with MMM-logging. if i start npm start in the MagicMirror folder nothing will displayed. and to test, etc. i have to close MagicMirror because it fill the hole screen …
                                            sdetweil @Perlchamp
                                            @Perlchamp log.log only works in the modulename.js (the part loaded in the browser)
                                            we call it that cause its filename matches the module name
                                            • 15
                                            • 16
                                            • 2 / 16
