    read csv-data and put it in an array
    313 Posts 3 Posters 479.4k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp ah well. both work here… your latest and mine produce the same results
      your output
      date	Name	age
      12	Sam 69
      2	Frank 81
      Sue81
      5	mary 65
      10	eee EEEEE 51
      16	fff FFFFF 8
      ggg GGGGG32
      27	hhh HHHHH 18
      my output
      date	Name	age
      12	Sam 69
      2	Frank 81
      Sue81
      5	mary 65
      10	eee EEEEE 51
      16	fff FFFFF 8
      ggg GGGGG32
      27	hhh HHHHH 18
      • PerlchampP Offline
        Perlchamp
        what does that mean? but you don’t use css, do you ? YES, but didn’t you see, that i have annotate the
        .concat(entrie.isBefore(now)?"_DIMMED":''
        lines in the code, i posted ? without entrie.isBefore … css is addressed, with it’s not addressed
          sdetweil @Perlchamp
          @Perlchamp I stepped thru and watched it change from with dimmed and without
            Perlchamp
            sorry for nerving, sam. i would like to understand the code. where is the part in which the name and age of people with the same birthday are collected/combined ?
              sdetweil @Perlchamp
              @Perlchamp I’ll use you last code post
              // loop thru all the brithdays found in the file that match this month, one at a time
              for(var birthday of Object.keys(this.active_birthdays)) {
                                  // each row is a person
              		    for(var person of this.active_birthdays[birthday]) {
              			// create looped row section
                                      // create a row
              			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY", tBody, null);
                                      // get timne/date of now
              			let now = moment();
                                      // we need to change the style to dimmed,. if the BD is in the past
              			//let entrie = moment(birthday,"DD.MM");                      // < --- problem
                                      // assume the birthday is NOT in the past
              			let entrie = now
                                      // if the user requested dimming
              			if(this.config.dimmEntries) {
                                          // get the brithdate in this year 01.05.2020
                                          // note the value WAS the SAME as 'now'
              			    entrie = moment(birthday,'DD.MM');
                                      // set the default value for the birthdate display
              			var bd = "";  // assume we don't need to display it
                 			// if we have not seen this birthdate in the loop so far, its the fiist time
              			if(birthdays_seen[birthday] == undefined) {
                                          // so we need the number of the day of the month
                                         // if it starts with 0, get from char 1 on sop 01.05 becomes 1.05, then
                                         // use split to get the parts [ 1, 05]
                                         // if not '0', use all bd numbers 12.05, and split to [12,05]
                                         // and take the 1st element of array
                                         // 1, or 12, for the two examples
              			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                                          // now we need a row of data for the the person
                                          // class name is either TD-IMAGE or TD-IMAGE_DIMMED
                                          // use the two moments to compare (the fix for the entrie= now above will fix this)
                                          // if the persons ds is before now, and we want dimmed, then add the tail of the class name on
                                          // else use this the name (concat('') - add nothing))
                                          // this  entrie.isBefore(now)?'_DIMMED':'' means
                                          // the result of the expression is entrie before now
                                          // if true return '_DIMMED'
                                          // if false return ''
                                          // "TD-IMAGE".concat() this means add onto the string "TD-IMAGE" whatever is inside the concat() parens, either '_DIMMED' or ''
                                          // so the class will be TD-IMAGE (for people with bithrdays ON or AFTER today)
                                          // or TD-IMAGE_DIMMED for people with birthdays BEFORE today
              			    //var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
              			    var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
              			    //var nameTD = this.createEl("td", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, person.name);
              			    var nameTDo = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
              			    this.createEl("span", null, "TD-AGE", nameTD, " ");
              			    // needs class for width
              			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTDo, person.age);
              			    var spanTD = this.createEl("span", null, "TD-AGE", nameTD0, person.age);
              			else{
                                           // we HAVE seen the birthday before, the row is already created, so we need to add to the END THAT ROW, ie after the span of the previous person
              			    // add a break (to the end of the TD for the name (has span already for age)
              			    this.createEl("br", null , null , nameTDo, null);
              			    // add a span with name
              			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',nameTDo, person.name);
                                          //  add a span for the persons name (after the line break
              			    var nameTD = this.createEl("span", null, "TD-BODY", nameTDo, person.name);
              			    // add a span with for spacing
                                          // add a span with age
              			    var spanTD = this.createEl("span", null, "TD-AGE", nameTDo, person.age);
                                          // if we have another person with the same BD, new stuff will be added after this span
              			var spacerTR = this.createEl("tr", null, null , tBody, null);
              			var spacerTD = this.createEl("td", null, "SPACER", spacerTR, " ");
              			spacerTD.colSpan = "2";
                                      // regardless of 1st or second, we have seen this birthdaty
              			birthdays_seen[birthday] = true;
                @Perlchamp my code had
                					let now = moment()
                					let entrie=now
                					var bd = "";
                  Perlchamp
                  thanks a lot. i will study this …
                    sdetweil @Perlchamp
                    @Perlchamp make that one fix and then my code will work too
                      Perlchamp
                      update !
                      i tried, but how should i do this ?
                      i was in the dev. didn’t helped me. it’s , how said, the part
                      with => blackScreen
                      without => working (formatted => css).
                        sdetweil @Perlchamp
                        @Perlchamp have to edit the source code, then reload the browser page, cannot edit in debugger
                        let now = moment()
                        					let entrie=now   // <-- this line was not included in yours..   i commented
                        • 28
                        • 29
                        • 30
                        • 31
                        • 32
                        • 30 / 32
