    cannot install pm2
    46 Posts 2 Posters 18.3k Views 2 Watching
    • M
      mrlowndes
      Hello. I’m getting this error when I try to install pm2:
      • do I install in /MagicMirror directory?
      pi@raspberrypi:~/MagicMirror $ sudo npm install -g pm2
      npm ERR! Unexpected end of JSON input while parsing near '...s":{"moment-timezone"'
      npm ERR!     /root/.npm/_logs/2020-04-29T18_34_01_247Z-debug.log
        sdetweil @mrlowndes
        @mrlowndes not in MagicMirror…
        did u try to install MagicMirror manually ?
        do node -v and npm -v
        what OS is this
        show results of lsb_release -a
        • M
          mrlowndes
          @sdetweil yes, manual install of MM
          pi@raspberrypi:~ $ node -v
          v10.20.1
          pi@raspberrypi:~ $ npm -v
          6.14.4
          how do I show results of lsb_release -a?
            sdetweil @mrlowndes
            @mrlowndes lsb_release -a
            same way you did results of npm -v
            on my desktop i see
            (base) sam@sams:~/MagicMirror$ lsb_release -a
            No LSB modules are available.
            Distributor ID:	Ubuntu
            Description:	Ubuntu 18.04.4 LTS
            Release:	18.04
            Codename:	bionic
            do this
            sudo apt-get purge -y npm
            then
            rm -rf ~/MagicMirror
            and then run my installer script from here
            read the readme for the command to issue
            it will ask to install pm2 and disable screen saver
            if you don’t, then I have extra scripts to do those
            • M
              mrlowndes
              @sdetweil ok I’ll give that a go. In the meantime:
              pi@raspberrypi:~ $ sudo npm install -g pm2
              npm ERR!     /root/.npm/_logs/2020-04-29T18_49_06_787Z-debug.log
              and
              pi@raspberrypi:~/MagicMirror $ lsb_release -a
              Distributor ID:	Raspbian
              Description:	Raspbian GNU/Linux 10 (buster)
              Release:	10
              Codename:	buster
                sdetweil @mrlowndes
                @mrlowndes so, I asked you to uninstall npm
                • M
                  mrlowndes
                  @sdetweil yes, stand by…
                  • M
                    mrlowndes
                    @sdetweil purged npm, now running your installer script…updating packages…I’m on a 2Mb/s internet connection…
                    • M
                      mrlowndes
                      We're ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
                      pi@raspberrypi:~ $ cd MagicMirror
                      pi@raspberrypi:~/MagicMirror $ pm2 start MagicMirror
                      bash: pm2: command not found
                      • M
                        mrlowndes
                        @sdetweil looks like pm2 was not installed:
                        Splashscreen: Changed theme to MagicMirror successfully.
                        Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                        install and setup pm2
                        bash: line 442: pm2: command not found
                        bash: line 518: pm2: command not found
                        bash: line 521: pm2: command not found
                        Do you want to disable the screen saver? (y/N)?y
                          sdetweil @mrlowndes
                          @mrlowndes did u reply yes or no?
                            @sdetweil run the fixuppm2 script from my site
                            • M
                              mrlowndes
                              pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                              the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
                              npm ERR!     /root/.npm/_logs/2020-04-29T20_09_52_853Z-debug.log
                              bash: line 103: pm2: command not found
                              bash: line 180: pm2: command not found
                              bash: line 183: pm2: command not found
                                sdetweil @mrlowndes
                                @mrlowndes ok, lets do
                                sudo npm purge -g pm2
                                • M
                                  mrlowndes
                                  I don’t think that worked. Tried to paste code but got flagged as spam
                                    sdetweil @mrlowndes
                                    @mrlowndes
                                    try
                                    sudo npm uninstall -g pm2
                                    • M
                                      mrlowndes
                                      @sdetweil ok done. Now should I try bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)" again?
                                        sdetweil @mrlowndes
                                        @mrlowndes yes
                                        • M
                                          mrlowndes
                                          @sdetweil same result:
                                          npm ERR!     /root/.npm/_logs/2020-04-29T20_19_40_905Z-debug.log
                                            sdetweil @mrlowndes
                                            @mrlowndes ok, time to get crazy , kill all npm stuff
                                            /cd ~
                                            sudo rm -rf .npm
                                            sudo apt-get install -y npm
                                            cd MagicMirror
                                            rm -rf node_modules
                                            npm install
                                            then do the fixuppm2 script again
                                            • 1 / 3
