    Default Module: Weather Forecast
    5 Posts 3 Posters 3.8k Views 3 Watching
    • lolobyteL
      lolobyte
      Why weather forecast won’t show
      showRainAmount?
      This is my config:
                          module: 'weatherforecast',
                          position: 'top_right',
                          header: 'Wettervorhersage',
                          classes: 'small bright', // Add your own styling. Optional.
                                  locationID: '121212121',  //ID from http://www.openweathermap.org
                                  appid: 'xxxxxxxxxxxxxxxxxxxxx',
                                  maxNumberOfDays: 10,
                                  animationSpeed: 2000,
                                  fade: true,
                                  fadePoint: 0.25,
                                  appendLocationNameToHeader: true,
                                  showRainAmount: true,
      Any ideas?
      Edited By Moderator: App Id removed from the code snippet. Please try not to post your API tokens and secrets in a public forum. :bow:
      J 1 Reply Last reply
      • yawnsY
        yawns Moderator
        Edit:
        Oh, the developer branch has this option. If you are on the developer branch, then maybe there is no rain at that day/days?
        if (this.config.showRainAmount) {
        				var rainCell = document.createElement("td");
        				if (isNaN(forecast.rain)) {
        					rainCell.innerHTML = "";
        				} else {
        					rainCell.innerHTML = forecast.rain + " mm";
        				rainCell.className = "align-right bright rain";
        				row.appendChild(rainCell);
        lolobyteL 1 Reply Last reply
        Reply Quote 1
        • lolobyteL
          lolobyte @yawns
          @yawns
          Thank you, actually no developer branch installed.
          • J
            jakubc @lolobyte
            @lolobyte after
            remove comma
            yawnsY 1 Reply Last reply
            • yawnsY
              yawns Moderator @jakubc
              @jakubc
              You are right, the comma is redundant, but it doesn’t do any harm in this environment. In this case it did not work because lolobyte was running a MagicMirror version which did not have this feature. :)
              Reply Quote 1
