    Cant seem to find config section to edit modules.
    9 Posts 4 Posters 2.3k Views 4 Watching
    • R
      Robertovj3
      I am new to rasberry pi and setting up the magic mirror. It seems straight forward but when i added a module and went to edit it, i cant not seem to find the config file so i properly edit. Did i set up something wrong or am i going to the wrong location?
      // this is my path to the config file and it wont take me anywhere
      pi@raspberrypi:~ $ cd MagicMirror/config
      pi@raspberrypi:~/MagicMirror/config $ ls
      config.js config.js.sample
        sdetweil @Robertovj3
        @Robertovj3 config.js right there
        You don’t edit the module itself
        • R
          Robertovj3 @sdetweil
          @sdetweil so where do i go to edit the config file to add other modules code?
            @Robertovj3 https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1589489993907
            Mykle1M R 2 Replies Last reply Reply Quote 1
            • Mykle1M
              Good answer! :-)
              • R
                thanks that really explains a lot! :)
                • P
                  pandeyprakhar00
                  I made these tutorials for giving a head start, starting from scratch !
                  https://www.youtube.com/playlist?list=PLBy3Sw0lBrNeihCn0fOr-m5RYJNb4w4IS
                  It used @sdetweil installation scripts !
                  1. Introduction to Raspberry pi : https://youtu.be/wqKCPbu7V7Y
                  2. Setting up MM Hardware : https://youtu.be/BZ_JVD9ReMk
                  3. Installing MM & introduction to MM - Modules : https://youtu.be/PHpth_KQHcE
                  4. Configuring Calendar & Weather Modules : https://youtu.be/ce6O2aGB9tY
                  Hope it helps !
                  R 1 Reply Last reply Reply Quote 2
                  • R
                    Robertovj3 @pandeyprakhar00
                    @pandeyprakhar00 Thanks for that i was actually watching your videos they are really well! i was wondering if the screencast was not working anymore. i installed but it does not seem to cast it provides error.
                    • P
                      pandeyprakhar00 @Robertovj3
                      @Robertovj3 Thank you for for appreciation !
                      Check the github page of MMM-ScreenCast for issues… I am sure you will find something there, else create a new issue !
