    MagicMirror Pimatic (Home Automation) Dashboard
    35 Posts 10 Posters 39.4k Views 10 Watching
    • Mr.SpontiM Offline
      Mr.Sponti
      @binderth
      as @sero mentioned, the Advantage over the socket-API is that you get live events, if something in pimatic changes.
      In addition I use the “MMM-REST” (push) module for displaying selected status messages in case a specific pimatic rule is fullfilled.
      • binderthB Offline
        binderth @sero
        @sero said in MagicMirror Pimatic (Home Automation) Dashboard:
        @binderth
        When using REST you need to poll / ask pimatic for updated values in a regular interval. With WebSockets pimatic can push changed values. This is less overhead and minimizes delays.
        @Mr.Sponti said in MagicMirror Pimatic (Home Automation) Dashboard:
        @binderth
        Thanks for the update. So, I think, I’ll do the same for my openHAB items, as openHAB can also push item changes through an API to MM. oh, I love challenges, since I never had done something in node.js! ;)
          shgmongohh
          Nice mirror. Could you please provide your Module? I want to use it for my own pimatic controller.
          Thank you in advance.
          Sebastian.
            Mr.Sponti
            @shgmongohh - Unfortunately I’m neither familiar with git nor with javascript or web style sheets. Based on my old school programming skills from the early eighties I studied several moduls and created 2 new moduls.
            The first one connect to pimatic via the WebSocket API and receives on device attribute changes all new values which I compare to device attribute definitions placed in the magic mirror config.js. If a device mach the new attribute, it is shown in the notification board (similar and based on modul MMM-DWD-WarnWeather by LukeSkywalker92). My modul also consist on 3 files:
            Pimatic Notification Borad:
            • MMM-Pimatic.js
            • node_helper.js
            • MMM-Pimatic.css
            • icons/icons-pimatic.png
            The second modul displays temperature devices and consists of 2 files and requires that the first modul is running, as it receives the pimatic attribute changes from the node-helper of the first modul by waiting on “notificationReceived”.
            Pimatic Temperature Devices:
            • MMM-M2-Pimatic.css
            • MMM-M2-Pimatic.js
            If someone could create the git repository and crosscheck the code I can provide the files by sending a zip.archiv.
            I would be glad to see additional ideas/moduls dealing with pimatic.
            • Z Offline
              Zinkeler
              Hello,
              please can someone tell me how i can install MagicMirror and Pimatic together.
              If i install MagicMirror then i can´t install pimatic (needs a lower version of node).
              If i install pimatic then i cant´t install MagicMirror (needs a higher version of node).
              For MagicMirror i used the latest version.
              For Pimatic is used the latest version.
              For Raspberry i installed Raspberry stretch
                Mr.Sponti
                @Zinkeler - Sorry, but I can’t help here. I’m running 2 pi’s with separate installations of pimatic and MagicMirror. The first Raspberry hosts pimatic including several interfaces (Homeduino, MySensors, arexx temperature logger) and the second is mounted behind a HDMI Monitor hanging at the wall of my diningroom.
                Z 1 Reply Last reply Reply Quote 0
                • Z Offline
                  Zinkeler @Mr.Sponti
                  @Mr.Sponti - thank you for your answer.
                  I now setup a second PI and installed Pimatic.
                  On both PI´s i installd socket.io and socket.io-Client.
                  My second pi works fine with pimatic and my first Pi works with MagicMirror.
                  I installed your modul as you described.
                  If i run a test on my MagicMirror-PI:
                  pi@raspberrypi3:~ $ node testpim.js
                  connected
                  [ { id: 'temperatur',
                      template: 'device',
                      attributes: [ [Object], [Object] ],
                      actions: [],
                      config:
                       { class: 'HomeduinoRFWeatherStation',
                         protocols: [Object],
                         values: [Object],
                         processingTemp: '$value',
                         processingHum: '$value',
                         xAttributeOptions: [],
                  i see, that socket works too.
                  But on my MagicMirror is only get the message "Connecting to pimatic ..."
                   config.js:
                              module: 'MMM-M1-Pimatic',
                              position: 'bottom_center',
                              header: 'PIMATIC',
                              host : 'xxx.xxx.xxx.xx',
                              port : 80,
                              user : 'user',
                              passwd : 'passwort',
                                  device: [
                                          icon: 'icon-Default',
                                          attributeName: 'schrankschalter.state',
                                          defaultValue: false,
                                          notification : 'Eingeschaltet'
                  What am i doing wrong??
                  P.S. are you german, because than it´s easier to talk about :-)
                  • yawnsY Offline
                    yawns Moderator
                    Ich weiß, dass github in der Readme genau das zeigt, was du probierst, aber meiner Meinung nach ist das falsch.
                                header: 'PIMATIC',
                                    port : 80,
                                    user : 'user',
                                    device: [
                    Meiner Meinung nach müssen host, port, user und passwd in den config Bereich.
                    • Z Offline
                      Zinkeler @yawns
                      @yawns
                      Vielen Dank !!
                      Genau das war das Problem, jetzt klappte es :-)
                      • P Offline
                        Peter
                        Who can help me with this?
                        I am running MM on one RPI and Pimatic on another one.
                        But I have no idea how to get the information of Pimatic on the MM screen.
                        If somebody can tell me what to install where …
                        Thanks in advance!
                        Peter
                        • 4 / 4
