    MagicMirror Pimatic (Home Automation) Dashboard
    35 Posts 10 Posters 39.4k Views 10 Watching
    • binderthB Offline
      binderth @sero
      @sero said in MagicMirror Pimatic (Home Automation) Dashboard:
      @binderth
      When using REST you need to poll / ask pimatic for updated values in a regular interval. With WebSockets pimatic can push changed values. This is less overhead and minimizes delays.
      @Mr.Sponti said in MagicMirror Pimatic (Home Automation) Dashboard:
      @binderth
      as @sero mentioned, the Advantage over the socket-API is that you get live events, if something in pimatic changes.
      In addition I use the “MMM-REST” (push) module for displaying selected status messages in case a specific pimatic rule is fullfilled.
      Thanks for the update. So, I think, I’ll do the same for my openHAB items, as openHAB can also push item changes through an API to MM. oh, I love challenges, since I never had done something in node.js! ;)
        shgmongohh
        Nice mirror. Could you please provide your Module? I want to use it for my own pimatic controller.
        Thank you in advance.
        Sebastian.
        • Mr.SpontiM Offline
          Mr.Sponti
          @shgmongohh - Unfortunately I’m neither familiar with git nor with javascript or web style sheets. Based on my old school programming skills from the early eighties I studied several moduls and created 2 new moduls.
          The first one connect to pimatic via the WebSocket API and receives on device attribute changes all new values which I compare to device attribute definitions placed in the magic mirror config.js. If a device mach the new attribute, it is shown in the notification board (similar and based on modul MMM-DWD-WarnWeather by LukeSkywalker92). My modul also consist on 3 files:
          Pimatic Notification Borad:
          • MMM-Pimatic.js
          • node_helper.js
          • MMM-Pimatic.css
          • icons/icons-pimatic.png
          The second modul displays temperature devices and consists of 2 files and requires that the first modul is running, as it receives the pimatic attribute changes from the node-helper of the first modul by waiting on “notificationReceived”.
          Pimatic Temperature Devices:
          • MMM-M2-Pimatic.css
          • MMM-M2-Pimatic.js
          If someone could create the git repository and crosscheck the code I can provide the files by sending a zip.archiv.
          I would be glad to see additional ideas/moduls dealing with pimatic.
          • Z Offline
            Zinkeler
            please can someone tell me how i can install MagicMirror and Pimatic together.
            If i install MagicMirror then i can´t install pimatic (needs a lower version of node).
            If i install pimatic then i cant´t install MagicMirror (needs a higher version of node).
            For MagicMirror i used the latest version.
            For Pimatic is used the latest version.
            For Raspberry i installed Raspberry stretch
              Mr.Sponti
              @Zinkeler - Sorry, but I can’t help here. I’m running 2 pi’s with separate installations of pimatic and MagicMirror. The first Raspberry hosts pimatic including several interfaces (Homeduino, MySensors, arexx temperature logger) and the second is mounted behind a HDMI Monitor hanging at the wall of my diningroom.
              Z 1 Reply Last reply Reply Quote 0
              • Z Offline
                Zinkeler @Mr.Sponti
                @Mr.Sponti - thank you for your answer.
                I now setup a second PI and installed Pimatic.
                On both PI´s i installd socket.io and socket.io-Client.
                My second pi works fine with pimatic and my first Pi works with MagicMirror.
                I installed your modul as you described.
                If i run a test on my MagicMirror-PI:
                pi@raspberrypi3:~ $ node testpim.js
                connected
                [ { id: 'temperatur',
                    template: 'device',
                    attributes: [ [Object], [Object] ],
                    actions: [],
                    config:
                     { class: 'HomeduinoRFWeatherStation',
                       protocols: [Object],
                       values: [Object],
                       processingTemp: '$value',
                       processingHum: '$value',
                       xAttributeOptions: [],
                i see, that socket works too.
                But on my MagicMirror is only get the message "Connecting to pimatic ..."
                 config.js:
                            module: 'MMM-M1-Pimatic',
                            position: 'bottom_center',
                            header: 'PIMATIC',
                            host : 'xxx.xxx.xxx.xx',
                            port : 80,
                            user : 'user',
                            passwd : 'passwort',
                                device: [
                                        icon: 'icon-Default',
                                        attributeName: 'schrankschalter.state',
                                        defaultValue: false,
                                        notification : 'Eingeschaltet'
                What am i doing wrong??
                P.S. are you german, because than it´s easier to talk about :-)
                • yawnsY Offline
                  yawns Moderator
                  Ich weiß, dass github in der Readme genau das zeigt, was du probierst, aber meiner Meinung nach ist das falsch.
                              header: 'PIMATIC',
                                  port : 80,
                                  user : 'user',
                                  device: [
                  Meiner Meinung nach müssen host, port, user und passwd in den config Bereich.
                  • Z Offline
                    Zinkeler @yawns
                    @yawns
                    Vielen Dank !!
                    Genau das war das Problem, jetzt klappte es :-)
                      Peter
                      Who can help me with this?
                      I am running MM on one RPI and Pimatic on another one.
                      But I have no idea how to get the information of Pimatic on the MM screen.
                      If somebody can tell me what to install where …
                      Thanks in advance!
                      Peter
                        Mr.Sponti
                        @Peter
                        I’ve reworked my MMM-Pimatic modul but need now to adjust the description on gihub. The modul connects to a pimatic server to listen on device attribute changes and displays changes as notifications on the MagicMirror screen. Temperature values can be displayed in a separate table. As soon as I’ve completed the Readme, I will send you a message.
                        • 1 / 4
