    MagicMirror Pimatic (Home Automation) Dashboard
    35 Posts 10 Posters 43.3k Views 10 Watching
    • Mr.SpontiM
      Mr.Sponti
      First of all a big, very big thank you to Michael Teeuw!!!
      MagicMirror is really one of the greatest Raspberry projects followed by ‘pimatic - home automation controller’, another amazing Raspberry project. So far as I know both are developments from Dutchmen.
      After studying the documentation and several MM-moduls, I decided to use MagicMirror to setup a central dashboard for my family. Beside customizing of the standard moduls I used the modul ‘MMM-DWD-WarnWeather by LukeSkywalker92’ as a base to create a new modul for retrieving data from my pimatic home controller.
      I’m a complete novice to nodejs and all this web stuff, but my programming skill were sufficient to modify the Warnweather module and to integrate the the pimatic socket API.
      And voila, here is my dashboard providing now actual information from the internet plus status information from my IoT devices controlled by pimatic.
      alt text
      Special thanks, to those people taken time to document and to publish there solutions.
      (As soon as I’ve learned to use git, I will also publish the pimatic modul)
      Best regards and a happy new year!
      cowboysdudeC binderthB 2 Replies Last reply
      Reply Quote 3
      • cowboysdudeC
        cowboysdude Module Developer @Mr.Sponti
        @Mr.Sponti Very nice! :) It’s where I’m headed…
        • binderthB
          binderth @Mr.Sponti
          @Mr.Sponti nice! just curious, why didn’t you use the “MMM-REST” module for your pimatic integration? I’m about to display some of the exact same Information (but from openHAB as a source for my home automation). So I wonder, if there were any impediments for using MMM-REST.
          Thanks,
          Thomas.
            sero @binderth
            @binderth
            When using REST you need to poll / ask pimatic for updated values in a regular interval. With WebSockets pimatic can push changed values. This is less overhead and minimizes delays.
            binderthB 1 Reply Last reply
            • Mr.SpontiM
              Mr.Sponti
              @binderth
              as @sero mentioned, the Advantage over the socket-API is that you get live events, if something in pimatic changes.
              In addition I use the “MMM-REST” (push) module for displaying selected status messages in case a specific pimatic rule is fullfilled.
              • binderthB
                binderth @sero
                @sero said in MagicMirror Pimatic (Home Automation) Dashboard:
                @binderth
                @Mr.Sponti said in MagicMirror Pimatic (Home Automation) Dashboard:
                @binderth
                Thanks for the update. So, I think, I’ll do the same for my openHAB items, as openHAB can also push item changes through an API to MM. oh, I love challenges, since I never had done something in node.js! ;)
                  shgmongohh
                  Nice mirror. Could you please provide your Module? I want to use it for my own pimatic controller.
                  Thank you in advance.
                  Sebastian.
                  • Mr.SpontiM
                    Mr.Sponti
                    @shgmongohh - Unfortunately I’m neither familiar with git nor with javascript or web style sheets. Based on my old school programming skills from the early eighties I studied several moduls and created 2 new moduls.
                    The first one connect to pimatic via the WebSocket API and receives on device attribute changes all new values which I compare to device attribute definitions placed in the magic mirror config.js. If a device mach the new attribute, it is shown in the notification board (similar and based on modul MMM-DWD-WarnWeather by LukeSkywalker92). My modul also consist on 3 files:
                    Pimatic Notification Borad:
                    • MMM-Pimatic.js
                    • node_helper.js
                    • MMM-Pimatic.css
                    • icons/icons-pimatic.png
                    The second modul displays temperature devices and consists of 2 files and requires that the first modul is running, as it receives the pimatic attribute changes from the node-helper of the first modul by waiting on “notificationReceived”.
                    Pimatic Temperature Devices:
                    • MMM-M2-Pimatic.css
                    • MMM-M2-Pimatic.js
                    If someone could create the git repository and crosscheck the code I can provide the files by sending a zip.archiv.
                    I would be glad to see additional ideas/moduls dealing with pimatic.
                    • Z
                      Zinkeler
                      please can someone tell me how i can install MagicMirror and Pimatic together.
                      If i install MagicMirror then i can´t install pimatic (needs a lower version of node).
                      If i install pimatic then i cant´t install MagicMirror (needs a higher version of node).
                      For MagicMirror i used the latest version.
                      For Pimatic is used the latest version.
                      For Raspberry i installed Raspberry stretch
                      • Mr.SpontiM
                        Mr.Sponti
                        @Zinkeler - Sorry, but I can’t help here. I’m running 2 pi’s with separate installations of pimatic and MagicMirror. The first Raspberry hosts pimatic including several interfaces (Homeduino, MySensors, arexx temperature logger) and the second is mounted behind a HDMI Monitor hanging at the wall of my diningroom.
                        Z 1 Reply Last reply
                        • Z
                          Zinkeler @Mr.Sponti
                          @Mr.Sponti - thank you for your answer.
                          I now setup a second PI and installed Pimatic.
                          On both PI´s i installd socket.io and socket.io-Client.
                          My second pi works fine with pimatic and my first Pi works with MagicMirror.
                          I installed your modul as you described.
                          If i run a test on my MagicMirror-PI:
                          pi@raspberrypi3:~ $ node testpim.js
                          connected
                          [ { id: 'temperatur',
                              template: 'device',
                              attributes: [ [Object], [Object] ],
                              actions: [],
                              config:
                               { class: 'HomeduinoRFWeatherStation',
                                 protocols: [Object],
                                 values: [Object],
                                 processingTemp: '$value',
                                 processingHum: '$value',
                                 xAttributeOptions: [],
                          i see, that socket works too.
                          But on my MagicMirror is only get the message "Connecting to pimatic ..."
                           config.js:
                                      module: 'MMM-M1-Pimatic',
                                      position: 'bottom_center',
                                      header: 'PIMATIC',
                                      host : 'xxx.xxx.xxx.xx',
                                      port : 80,
                                      user : 'user',
                                      passwd : 'passwort',
                                          device: [
                                                  icon: 'icon-Default',
                                                  attributeName: 'schrankschalter.state',
                                                  defaultValue: false,
                                                  notification : 'Eingeschaltet'
                          What am i doing wrong??
                          P.S. are you german, because than it´s easier to talk about :-)
                          • yawnsY
                            yawns Moderator
                            Ich weiß, dass github in der Readme genau das zeigt, was du probierst, aber meiner Meinung nach ist das falsch.
                                        header: 'PIMATIC',
                                            port : 80,
                                            user : 'user',
                                            device: [
                            Meiner Meinung nach müssen host, port, user und passwd in den config Bereich.
                            • Z
                              Zinkeler @yawns
                              @yawns
                              Vielen Dank !!
                              Genau das war das Problem, jetzt klappte es :-)
                                Peter
                                Who can help me with this?
                                I am running MM on one RPI and Pimatic on another one.
                                But I have no idea how to get the information of Pimatic on the MM screen.
                                If somebody can tell me what to install where …
                                Thanks in advance!
                                Peter
                                • Mr.SpontiM
                                  Mr.Sponti
                                  @Peter
                                  I’ve reworked my MMM-Pimatic modul but need now to adjust the description on gihub. The modul connects to a pimatic server to listen on device attribute changes and displays changes as notifications on the MagicMirror screen. Temperature values can be displayed in a separate table. As soon as I’ve completed the Readme, I will send you a message.
                                  P 1 Reply Last reply
                                    Peter @Mr.Sponti
                                    @Mr.Sponti thanks!
                                    Would be great!
                                    Peter
                                    • Mr.SpontiM
                                      Mr.Sponti
                                      @Peter Here you can find the latest version of my MMM-Pimatic module. The README isn’t yet covering all features but should be sufficient for the installation and basic configuration of the module.
                                      Please feel free to contact me if you need help to get it running.
                                        Peter @Mr.Sponti
                                        @Mr.Sponti thanks!
                                        I will try it as soon as possible.
                                        I will let you know the results!
                                        Peter
                                          Peter
                                          pi@magicrpi:~/MagicMirror/modules/MMM-Pimatic $ npm install
                                          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                                          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
                                          npm WARN modules No description
                                          npm WARN modules No repository field.
                                          npm WARN modules No README data
                                          npm WARN modules No license field.
                                          And I have no idea what to do (how to install) socket.io-client.
                                          Peter
                                          Mr.SpontiM 1 Reply Last reply
                                          • Mr.SpontiM
                                            Mr.Sponti @Peter
                                            @Peter , you can ignore these Warnings, but you need to install the socket.io-client modul:
                                            cd  ~/MagicMirror/modules/MMM-Pimatic
                                            npm install socket.io-client
