    Config Error
    newcodeerror
    39 Posts 5 Posters 17.6k Views 5 Watching
    • P
      PHAGE.GOV
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
      			module: "alert",
      			Position: "right"
      			Welcome_message "string"
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
      			disabled,true,
      			module: "compliments",
      			position: "lower_third"config: {
      			compliments: {
      				morning: [
      					"Good Morning My Lord",
      					"Have The Best Day Ever:)",
      					"Ten is such a weird number..."
      				afternoon: [
      					"Good Afternoon!",
      					"Welcome to Apollonis!",
      					"I am under maintainance please excersise caution"
      				evening: [
      					"Good Evening, Sir!",
      					"You Are In Control, Sir."
      			updateInterval:50000,
      			remoteFile: null,
      			fadeSpeed: 4000,
      			morningStartTime: 3,
      			morningEndTime: 12,
      			afternoonStartTime: 12,
      			afternoonEndTime: 17
      			module: "currentweather",
      				locationID: "4881346", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "4900f833e3e07ddd3b769d933245d37a"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      I keep getting error screens and it wont even let me run the magic mirror!
      I changed the weather stuff and the compliments. I have no experience with coding.
      I also get this when i ran a check.
      pi@raspberrypi:~ $ npm run config:check
      npm ERR! code ENOENT
      npm ERR! syscall open
      npm ERR! path /home/pi/package.json
      npm ERR! errno -2
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/.npm/_logs/2020-05-20T01_00_43_703Z-debug.log
      Thanks in advance!!!
      • P
        PHAGE.GOV
        also should I have posted those Ip Adresses?
          sdetweil @PHAGE.GOV
          @PHAGE-GOV said in Config Error:
          means you are not in the MagicMirror folder before npm, start
          the apid id/keys should be changed to ****
          also, please use the markdown around config or code blacks, paste into editor, select all, the hit the button that looks like </>
          • P
            PHAGE.GOV @sdetweil
            @sdetweil i will do that in the future!
            but how do i go into the MM folder before NPM?
            and also literally change the Keys to the asterisks?
              sdetweil @PHAGE.GOV
              @PHAGE-GOV you open a terminal window on the desktop ctrl-alt-T, and then cd MagicMirror
              (just like you would do on Windows)
              or ssh into the pi from your windows pc, and THEN
              cd MagicMirror
              yes, when displaying on the forum, we request you hide sensitive info. (like to calendars, email, …)
              if u paid for your apikey and gave it away to anyone that can cut/paste, you MIGHT be unhappy!
              google apikeys are based on usage… have a couple hundred people using YOUR apikey might cost you
              • P
                PHAGE.GOV @sdetweil
                @sdetweil yeah, so note to self for the future lol
                so literally type “cd magic mirror” and that should fix it?
                and also change my api key in the future, not in the config file, right?
                  sdetweil @PHAGE.GOV
                  @PHAGE-GOV in the config file the apikey should be ok, only when u paste config to the forum should u blank it out…
                  linux is case sensitive, so its
                  cd MagicMirror
                  • P
                    PHAGE.GOV @sdetweil
                    @sdetweil so i did the cd Magic Mirror and then ran pm2 start/mm.sh
                    and i got a pm2 error “script not found: home/pi/MagicMirror/mm.sh”
                      sdetweil @PHAGE.GOV
                      @PHAGE-GOV use my pm2 setup script here
                      P 2 Replies Last reply Reply Quote 0
                      • P
                        PHAGE.GOV @sdetweil
                        @sdetweil well i tried lol
                        [2020-05-20 17:25:02.499] [LOG]    Starting MagicMirror: v2.11.0
                        [2020-05-20 17:25:02.506] [LOG]    Loading config ...
                        [2020-05-20 17:25:02.510] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:41
                        SyntaxError: Unexpected identifier
                            at Module._compile (internal/modules/cjs/loader.js:722:23)
                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                            at Module.load (internal/modules/cjs/loader.js:645:32)
                            at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                            at Module.require (internal/modules/cjs/loader.js:685:19)
                            at require (internal/modules/cjs/helpers.js:16:16)
                            at loadConfig (/home/pi/MagicMirror/js/app.js:69:12)
                            at App.start (/home/pi/MagicMirror/js/app.js:210:3)
                            at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:115:7)
                            at Module._compile (internal/modules/cjs/loader.js:786:30)
                        [2020-05-20 17:25:02.511] [LOG]    Loading module helpers ...
                        [2020-05-20 17:25:02.555] [LOG]    Initializing new module helper ...
                        [2020-05-20 17:25:02.557] [LOG]    Module helper loaded: updatenotification
                        [2020-05-20 17:25:02.558] [LOG]    No helper found for module: helloworld.
                        [2020-05-20 17:25:02.559] [LOG]    All module helpers loaded.
                        [2020-05-20 17:25:02.680] [LOG]    Starting server on port 8080 ...
                        [2020-05-20 17:25:02.693] [LOG]    Server started ...
                        [2020-05-20 17:25:02.694] [LOG]    Connecting socket for: updatenotification
                        [2020-05-20 17:25:02.695] [LOG]    Sockets connected & modules started ...
                        [2020-05-20 17:25:02.785] [LOG]    Launching application.
                        [2020-05-20 17:25:24.052] [LOG]    Shutting down server...
                        [2020-05-20 17:25:24.053] [LOG]    Stopping module helper: updatenotifica
                          sdetweil @PHAGE.GOV
                          Welcome_message “string”
                          • P
                            PHAGE.GOV @sdetweil
                            @sdetweil would it be a good idea at this point to just delete and reinstall lol
                            • P
                              PHAGE.GOV @sdetweil
                              @sdetweil wait so how do i fix that line? like what would you recomend?
                                sdetweil @PHAGE.GOV
                                @PHAGE-GOV that is what you have to figure out… run the syntax checker
                                cd ~/MagicMirror
                                the error is typically reported on the line following the error, but maybe not in this case.
                                read this
                                https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1589635889121
                                you are asking for people to do the work for you, and not learning… time to learn
                                P 3 Replies Last reply Reply Quote 0
                                • P
                                  PHAGE.GOV @sdetweil
                                  @sdetweil okay mom lmaoo, and yes, i agree
                                  • P
                                    PHAGE.GOV @sdetweil
                                    so sensei @sdetweil , i got this.
                                    hecking file...  /home/pi/MagicMirror/config/config.js
                                    Line 41 col 4 Parsing error: Unexpected token Welcome_message
                                    so does that just mean i should delete that line altogether?
                                    • P
                                      PHAGE.GOV @sdetweil
                                      @sdetweil wait so it said the options were “string” and “false” for “welcome message” thats where its wrong, so i think its fixed?? ill update if it isnt fixed lol
                                        sdetweil @PHAGE.GOV
                                        no idea… maybe it is an important line,
                                        but as I said, the error is reported on the line after the actual problem
                                        if u read the linked getting started
                                        you would see that elements in config.js are
                                            sometext : somevalue
                                        where somevalue MUST be quoted before and after (single or double doesn’t matter, as long as both ends are the same)
                                        unless somevalue is true/false, or a number
                                        AND you need to add a continuation char (comma ,) at the end to the line if the next line
                                        is include in this info, or more info is comming (another module config for example)
                                        • P
                                          PHAGE.GOV @sdetweil
                                          @sdetweil yeah ill try that, i tried fixing “string” because it had an extra space in it but i got the no config.js file again, i will try looking for the other stuff rn
                                          S lavolp3L 2 Replies Last reply Reply Quote 0
                                            sdetweil @PHAGE.GOV
                                            if it has an error in the config, it throws up its hands and says no config…
                                            yes there is one, but he can’t tell what to do
