    Config Error
    newcodeerror
    39 Posts 5 Posters 12.8k Views 5 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @PHAGE.GOV
      @PHAGE-GOV I guess you have that part in the alert module.
      It needs to be like @sdetweil said. on the left side a single word, here welcome_message. You need to take care of underlines and the upper-/lowercase.
      Then there is a : and then the value which can be a string or false.
      welcome_message: 'Any string you like'
      OR
      welcome_message: false
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        sdetweil @lavolp3
        @lavolp3 but his error was
        Unexpected token Welcome_message
        so, one at least more this is wrong
        • lavolp3L Offline
          lavolp3 Module Developer @sdetweil
          @sdetweil Looking at above post, there’s looots of errors in the config.
          @PHAGE-GOV we can’t lead you through all of these.
          You need to understand how config.js needs to look. Only one comma set false or forgotten breaks the whole file and the mirror.
          • lavolp3L Offline
            lavolp3 Module Developer @lavolp3
            @lavolp3 The alert part needs to look like this:
            			module: "alert",
            			position: "right",
            			welcome_message: "a string"
            • P Offline
              PHAGE.GOV @sdetweil
              @sdetweil okay so ive been combing through the code, and since i didnt know how to properly edit .json files, i had alot of cleanup to do, im still not done, but getting there. what is a trailing space though? i dont know what to remove
              • P Offline
                PHAGE.GOV @lavolp3
                @lavolp3
                			module: "compliments",
                			position: "lower_third",
                			compliments: {
                				"anytime" : [
                					"Hey there sexy!"
                				"morning" : [
                so 64 is the compliments line and it says it has trailing spaces. Im actually learning so much about json files rn so thank you @sdetweil and @lavolp3
                  sdetweil @PHAGE.GOV
                  @PHAGE-GOV ignore the trailing space error. It’s stupid
                  • P Offline
                    PHAGE.GOV @sdetweil
                    @sdetweil indeed it is, i found it tho, and i fixed everything else too! thank you so much! and i learned so much from this also, i feel much more confident poking around and i defs learned much more about proper coding
                      sdetweil @PHAGE.GOV
                      @PHAGE-GOV and finding your way on the next error. After 3 years I still make them
                      • P Offline
                        PHAGE.GOV @sdetweil
                        @sdetweil yeah, but npm run config:check was such a life saver
                        • 3 / 4
