    Config Error
    newcodeerror
    39 Posts 5 Posters 12.7k Views 5 Watching
      PHAGE.GOV
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			     // false, default for all  NON-armv6l devices
      			module: "alert",
      			Position: "right"
      			Welcome_message "string"
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
      			disabled,true,
      			module: "compliments",
      			position: "lower_third"config: {
      			compliments: {
      				morning: [
      					"Good Morning My Lord",
      					"Have The Best Day Ever:)",
      					"Ten is such a weird number..."
      				afternoon: [
      					"Good Afternoon!",
      					"Welcome to Apollonis!",
      					"I am under maintainance please excersise caution"
      				evening: [
      					"Good Evening, Sir!",
      					"You Are In Control, Sir."
      			updateInterval:50000,
      			remoteFile: null,
      			fadeSpeed: 4000,
      			morningStartTime: 3,
      			morningEndTime: 12,
      			afternoonStartTime: 12,
      			afternoonEndTime: 17
      			module: "currentweather",
      				locationID: "4881346", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "4900f833e3e07ddd3b769d933245d37a"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      I keep getting error screens and it wont even let me run the magic mirror!
      I changed the weather stuff and the compliments. I have no experience with coding.
      I also get this when i ran a check.
      pi@raspberrypi:~ $ npm run config:check
      npm ERR! code ENOENT
      npm ERR! syscall open
      npm ERR! errno -2
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/.npm/_logs/2020-05-20T01_00_43_703Z-debug.log
      Thanks in advance!!!
        PHAGE.GOV
        also should I have posted those Ip Adresses?
          sdetweil @PHAGE.GOV
          @PHAGE-GOV said in Config Error:
          means you are not in the MagicMirror folder before npm, start
          the apid id/keys should be changed to ****
          also, please use the markdown around config or code blacks, paste into editor, select all, the hit the button that looks like </>
            PHAGE.GOV @sdetweil
            @sdetweil i will do that in the future!
            but how do i go into the MM folder before NPM?
            and also literally change the Keys to the asterisks?
              sdetweil @PHAGE.GOV
              @PHAGE-GOV you open a terminal window on the desktop ctrl-alt-T, and then cd MagicMirror
              (just like you would do on Windows)
              or ssh into the pi from your windows pc, and THEN
              cd MagicMirror
              yes, when displaying on the forum, we request you hide sensitive info. (like to calendars, email, …)
              if u paid for your apikey and gave it away to anyone that can cut/paste, you MIGHT be unhappy!
              google apikeys are based on usage… have a couple hundred people using YOUR apikey might cost you
                PHAGE.GOV @sdetweil
                @sdetweil yeah, so note to self for the future lol
                so literally type “cd magic mirror” and that should fix it?
                and also change my api key in the future, not in the config file, right?
                  sdetweil @PHAGE.GOV
                  @PHAGE-GOV in the config file the apikey should be ok, only when u paste config to the forum should u blank it out…
                  linux is case sensitive, so its
                  cd MagicMirror
                    PHAGE.GOV @sdetweil
                    @sdetweil so i did the cd Magic Mirror and then ran pm2 start/mm.sh
                    and i got a pm2 error “script not found: home/pi/MagicMirror/mm.sh”
                      sdetweil @PHAGE.GOV
                      @PHAGE-GOV use my pm2 setup script here
                      P 2 Replies Last reply Reply Quote 0
                        PHAGE.GOV @sdetweil
                        @sdetweil well i tried lol
                        [2020-05-20 17:25:02.499] [LOG]    Starting MagicMirror: v2.11.0
                        [2020-05-20 17:25:02.506] [LOG]    Loading config ...
                        [2020-05-20 17:25:02.510] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:41
                        SyntaxError: Unexpected identifier
                            at Module._compile (internal/modules/cjs/loader.js:722:23)
                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                            at Module.load (internal/modules/cjs/loader.js:645:32)
                            at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                            at Module.require (internal/modules/cjs/loader.js:685:19)
                            at require (internal/modules/cjs/helpers.js:16:16)
                            at loadConfig (/home/pi/MagicMirror/js/app.js:69:12)
                            at App.start (/home/pi/MagicMirror/js/app.js:210:3)
                            at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:115:7)
                            at Module._compile (internal/modules/cjs/loader.js:786:30)
                        [2020-05-20 17:25:02.511] [LOG]    Loading module helpers ...
                        [2020-05-20 17:25:02.555] [LOG]    Initializing new module helper ...
                        [2020-05-20 17:25:02.557] [LOG]    Module helper loaded: updatenotification
                        [2020-05-20 17:25:02.558] [LOG]    No helper found for module: helloworld.
                        [2020-05-20 17:25:02.559] [LOG]    All module helpers loaded.
                        [2020-05-20 17:25:02.680] [LOG]    Starting server on port 8080 ...
                        [2020-05-20 17:25:02.693] [LOG]    Server started ...
                        [2020-05-20 17:25:02.694] [LOG]    Connecting socket for: updatenotification
                        [2020-05-20 17:25:02.695] [LOG]    Sockets connected & modules started ...
                        [2020-05-20 17:25:02.785] [LOG]    Launching application.
                        [2020-05-20 17:25:24.052] [LOG]    Shutting down server...
                        [2020-05-20 17:25:24.053] [LOG]    Stopping module helper: updatenotifica
                        • 1 / 4
