    Config Error
    newcodeerror
    39 Posts 5 Posters 17.1k Views 5 Watching
      PHAGE.GOV @sdetweil
      @sdetweil i will do that in the future!
      but how do i go into the MM folder before NPM?
      and also literally change the Keys to the asterisks?
        sdetweil @PHAGE.GOV
        @PHAGE-GOV you open a terminal window on the desktop ctrl-alt-T, and then cd MagicMirror
        (just like you would do on Windows)
        or ssh into the pi from your windows pc, and THEN
        cd MagicMirror
        yes, when displaying on the forum, we request you hide sensitive info. (like to calendars, email, …)
        if u paid for your apikey and gave it away to anyone that can cut/paste, you MIGHT be unhappy!
        google apikeys are based on usage… have a couple hundred people using YOUR apikey might cost you
          PHAGE.GOV @sdetweil
          @sdetweil yeah, so note to self for the future lol
          so literally type “cd magic mirror” and that should fix it?
          and also change my api key in the future, not in the config file, right?
            sdetweil @PHAGE.GOV
            @PHAGE-GOV in the config file the apikey should be ok, only when u paste config to the forum should u blank it out…
            linux is case sensitive, so its
            cd MagicMirror
              PHAGE.GOV @sdetweil
              @sdetweil so i did the cd Magic Mirror and then ran pm2 start/mm.sh
              and i got a pm2 error “script not found: home/pi/MagicMirror/mm.sh”
                sdetweil @PHAGE.GOV
                @PHAGE-GOV use my pm2 setup script here
                P 2 Replies Last reply Reply Quote 0
                  PHAGE.GOV @sdetweil
                  @sdetweil well i tried lol
                  [2020-05-20 17:25:02.499] [LOG]    Starting MagicMirror: v2.11.0
                  [2020-05-20 17:25:02.506] [LOG]    Loading config ...
                  [2020-05-20 17:25:02.510] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:41
                  			Welcome_message "string"
                  SyntaxError: Unexpected identifier
                      at Module._compile (internal/modules/cjs/loader.js:722:23)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                      at Module.load (internal/modules/cjs/loader.js:645:32)
                      at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                      at Module.require (internal/modules/cjs/loader.js:685:19)
                      at require (internal/modules/cjs/helpers.js:16:16)
                      at loadConfig (/home/pi/MagicMirror/js/app.js:69:12)
                      at App.start (/home/pi/MagicMirror/js/app.js:210:3)
                      at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:115:7)
                      at Module._compile (internal/modules/cjs/loader.js:786:30)
                  [2020-05-20 17:25:02.511] [LOG]    Loading module helpers ...
                  [2020-05-20 17:25:02.555] [LOG]    Initializing new module helper ...
                  [2020-05-20 17:25:02.557] [LOG]    Module helper loaded: updatenotification
                  [2020-05-20 17:25:02.558] [LOG]    No helper found for module: helloworld.
                  [2020-05-20 17:25:02.559] [LOG]    All module helpers loaded.
                  [2020-05-20 17:25:02.680] [LOG]    Starting server on port 8080 ...
                  [2020-05-20 17:25:02.693] [LOG]    Server started ...
                  [2020-05-20 17:25:02.694] [LOG]    Connecting socket for: updatenotification
                  [2020-05-20 17:25:02.695] [LOG]    Sockets connected & modules started ...
                  [2020-05-20 17:25:02.785] [LOG]    Launching application.
                  [2020-05-20 17:25:24.052] [LOG]    Shutting down server...
                  [2020-05-20 17:25:24.053] [LOG]    Stopping module helper: updatenotifica
                    sdetweil @PHAGE.GOV
                    @PHAGE-GOV said in Config Error:
                    Welcome_message “string”
                      PHAGE.GOV @sdetweil
                      @sdetweil would it be a good idea at this point to just delete and reinstall lol
                        PHAGE.GOV @sdetweil
                        @sdetweil wait so how do i fix that line? like what would you recomend?
                          sdetweil @PHAGE.GOV
                          @PHAGE-GOV that is what you have to figure out… run the syntax checker
                          npm run config:check
                          the error is typically reported on the line following the error, but maybe not in this case.
                          read this
                          https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1589635889121
                          you are asking for people to do the work for you, and not learning… time to learn
                          P 3 Replies Last reply Reply Quote 0
                            PHAGE.GOV @sdetweil
                            @sdetweil okay mom lmaoo, and yes, i agree
                              PHAGE.GOV @sdetweil
                              so sensei @sdetweil , i got this.
                              hecking file...  /home/pi/MagicMirror/config/config.js
                              Line 41 col 4 Parsing error: Unexpected token Welcome_message
                              so does that just mean i should delete that line altogether?
                                PHAGE.GOV @sdetweil
                                @sdetweil wait so it said the options were “string” and “false” for “welcome message” thats where its wrong, so i think its fixed?? ill update if it isnt fixed lol
                                  sdetweil @PHAGE.GOV
                                  no idea… maybe it is an important line,
                                  but as I said, the error is reported on the line after the actual problem
                                  if u read the linked getting started
                                  you would see that elements in config.js are
                                      sometext : somevalue
                                  where somevalue MUST be quoted before and after (single or double doesn’t matter, as long as both ends are the same)
                                  unless somevalue is true/false, or a number
                                  AND you need to add a continuation char (comma ,) at the end to the line if the next line
                                  is include in this info, or more info is comming (another module config for example)
                                    PHAGE.GOV @sdetweil
                                    @sdetweil yeah ill try that, i tried fixing “string” because it had an extra space in it but i got the no config.js file again, i will try looking for the other stuff rn
                                    S lavolp3L 2 Replies Last reply Reply Quote 0
                                      sdetweil @PHAGE.GOV
                                      if it has an error in the config, it throws up its hands and says no config…
                                      yes there is one, but he can’t tell what to do
                                      • lavolp3L Offline
                                        lavolp3 Module Developer @PHAGE.GOV
                                        @PHAGE-GOV I guess you have that part in the alert module.
                                        It needs to be like @sdetweil said. on the left side a single word, here welcome_message. You need to take care of underlines and the upper-/lowercase.
                                        Then there is a : and then the value which can be a string or false.
                                        welcome_message: 'Any string you like'
                                        OR
                                        welcome_message: false
                                        How to troubleshoot modules
                                        MMM-soccer v2, MMM-AVStock
                                          sdetweil @lavolp3
                                          @lavolp3 but his error was
                                          so, one at least more this is wrong
                                          • lavolp3L Offline
                                            @sdetweil Looking at above post, there’s looots of errors in the config.
                                            @PHAGE-GOV we can’t lead you through all of these.
                                            You need to understand how config.js needs to look. Only one comma set false or forgotten breaks the whole file and the mirror.
