    Config Error
    newcodeerror
    39 Posts 5 Posters 17.3k Views 5 Watching
      sdetweil @PHAGE.GOV
      @PHAGE-GOV in the config file the apikey should be ok, only when u paste config to the forum should u blank it out…
      linux is case sensitive, so its
      cd MagicMirror
        PHAGE.GOV @sdetweil
        @sdetweil so i did the cd Magic Mirror and then ran pm2 start/mm.sh
        and i got a pm2 error “script not found: home/pi/MagicMirror/mm.sh”
          sdetweil @PHAGE.GOV
          @PHAGE-GOV use my pm2 setup script here
          P 2 Replies Last reply Reply Quote 0
            PHAGE.GOV @sdetweil
            @sdetweil well i tried lol
            [2020-05-20 17:25:02.499] [LOG]    Starting MagicMirror: v2.11.0
            [2020-05-20 17:25:02.506] [LOG]    Loading config ...
            [2020-05-20 17:25:02.510] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:41
            			Welcome_message "string"
            SyntaxError: Unexpected identifier
                at Module._compile (internal/modules/cjs/loader.js:722:23)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                at Module.load (internal/modules/cjs/loader.js:645:32)
                at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                at Module.require (internal/modules/cjs/loader.js:685:19)
                at require (internal/modules/cjs/helpers.js:16:16)
                at loadConfig (/home/pi/MagicMirror/js/app.js:69:12)
                at App.start (/home/pi/MagicMirror/js/app.js:210:3)
                at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:115:7)
                at Module._compile (internal/modules/cjs/loader.js:786:30)
            [2020-05-20 17:25:02.511] [LOG]    Loading module helpers ...
            [2020-05-20 17:25:02.555] [LOG]    Initializing new module helper ...
            [2020-05-20 17:25:02.557] [LOG]    Module helper loaded: updatenotification
            [2020-05-20 17:25:02.558] [LOG]    No helper found for module: helloworld.
            [2020-05-20 17:25:02.559] [LOG]    All module helpers loaded.
            [2020-05-20 17:25:02.680] [LOG]    Starting server on port 8080 ...
            [2020-05-20 17:25:02.693] [LOG]    Server started ...
            [2020-05-20 17:25:02.694] [LOG]    Connecting socket for: updatenotification
            [2020-05-20 17:25:02.695] [LOG]    Sockets connected & modules started ...
            [2020-05-20 17:25:02.785] [LOG]    Launching application.
            [2020-05-20 17:25:24.052] [LOG]    Shutting down server...
            [2020-05-20 17:25:24.053] [LOG]    Stopping module helper: updatenotifica
              sdetweil @PHAGE.GOV
              @PHAGE-GOV said in Config Error:
              Welcome_message “string”
                PHAGE.GOV @sdetweil
                @sdetweil would it be a good idea at this point to just delete and reinstall lol
                  PHAGE.GOV @sdetweil
                  @sdetweil wait so how do i fix that line? like what would you recomend?
                    sdetweil @PHAGE.GOV
                    @PHAGE-GOV that is what you have to figure out… run the syntax checker
                    npm run config:check
                    the error is typically reported on the line following the error, but maybe not in this case.
                    read this
                    https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1589635889121
                    you are asking for people to do the work for you, and not learning… time to learn
                    P 3 Replies Last reply Reply Quote 0
                      PHAGE.GOV @sdetweil
                      @sdetweil okay mom lmaoo, and yes, i agree
                        PHAGE.GOV @sdetweil
                        so sensei @sdetweil , i got this.
                        hecking file...  /home/pi/MagicMirror/config/config.js
                        Line 41 col 4 Parsing error: Unexpected token Welcome_message
                        so does that just mean i should delete that line altogether?
                          PHAGE.GOV @sdetweil
                          @sdetweil wait so it said the options were “string” and “false” for “welcome message” thats where its wrong, so i think its fixed?? ill update if it isnt fixed lol
                            sdetweil @PHAGE.GOV
                            no idea… maybe it is an important line,
                            but as I said, the error is reported on the line after the actual problem
                            if u read the linked getting started
                            you would see that elements in config.js are
                                sometext : somevalue
                            where somevalue MUST be quoted before and after (single or double doesn’t matter, as long as both ends are the same)
                            unless somevalue is true/false, or a number
                            AND you need to add a continuation char (comma ,) at the end to the line if the next line
                            is include in this info, or more info is comming (another module config for example)
                              PHAGE.GOV @sdetweil
                              @sdetweil yeah ill try that, i tried fixing “string” because it had an extra space in it but i got the no config.js file again, i will try looking for the other stuff rn
                              S lavolp3L 2 Replies Last reply Reply Quote 0
                                sdetweil @PHAGE.GOV
                                if it has an error in the config, it throws up its hands and says no config…
                                yes there is one, but he can’t tell what to do
                                • lavolp3L
                                  lavolp3 Module Developer @PHAGE.GOV
                                  @PHAGE-GOV I guess you have that part in the alert module.
                                  It needs to be like @sdetweil said. on the left side a single word, here welcome_message. You need to take care of underlines and the upper-/lowercase.
                                  Then there is a : and then the value which can be a string or false.
                                  welcome_message: 'Any string you like'
                                  OR
                                  welcome_message: false
                                  How to troubleshoot modules
                                  MMM-soccer v2, MMM-AVStock
                                    sdetweil @lavolp3
                                    @lavolp3 but his error was
                                    so, one at least more this is wrong
                                    • lavolp3L
                                      @sdetweil Looking at above post, there’s looots of errors in the config.
                                      @PHAGE-GOV we can’t lead you through all of these.
                                      You need to understand how config.js needs to look. Only one comma set false or forgotten breaks the whole file and the mirror.
                                      • lavolp3L
                                        lavolp3 Module Developer @lavolp3
                                        @lavolp3 The alert part needs to look like this:
                                        			module: "alert",
                                        			position: "right",
                                        			welcome_message: "a string"
                                          PHAGE.GOV @sdetweil
                                          @sdetweil okay so ive been combing through the code, and since i didnt know how to properly edit .json files, i had alot of cleanup to do, im still not done, but getting there. what is a trailing space though? i dont know what to remove
                                            PHAGE.GOV @lavolp3
                                            @lavolp3
                                            			module: "compliments",
                                            			position: "lower_third",
                                            			compliments: {
                                            				"anytime" : [
                                            					"Hey there sexy!"
                                            				"morning" : [
                                            so 64 is the compliments line and it says it has trailing spaces. Im actually learning so much about json files rn so thank you @sdetweil and @lavolp3
