    MMM-Screencast don`t work
    13 Posts 6 Posters 4.5k Views 6 Watching
      Stevent
      Hello,
      sorry for my bad englisch, here is the config, what do I wrong that the Screencast dont work? I work the last two days on this problem, search the hole Internet and the board
      > > magicmirror@2.11.0 start /home/pi/MagicMirror
      > > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      > [2020-05-26 13:15:58.517] [LOG]    Starting MagicMirror: v2.11.0
      > [2020-05-26 13:15:58.524] [LOG]    Loading config ...
      > [2020-05-26 13:15:58.528] [LOG]    Loading module helpers ...
      > [2020-05-26 13:15:58.566] [LOG]    Initializing new module helper ...
      > [2020-05-26 13:15:58.567] [LOG]    Module helper loaded: updatenotification
      > [2020-05-26 13:15:58.568] [LOG]    No helper found for module: clock.
      > [2020-05-26 13:15:58.913] [LOG]    Initializing new module helper ...
      > [2020-05-26 13:15:58.914] [LOG]    Module helper loaded: calendar
      > [2020-05-26 13:15:58.915] [LOG]    No helper found for module: compliments.
      > [2020-05-26 13:15:58.979] [LOG]    Initializing new module helper ...
      > [2020-05-26 13:15:58.980] [LOG]    Module helper loaded: MMM-Remote-Control
      > [2020-05-26 13:15:58.981] [LOG]    Initializing new module helper ...
      > [2020-05-26 13:15:58.982] [LOG]    Module helper loaded: MMM-Remote-Control-Repository
      > [2020-05-26 13:15:58.982] [LOG]    No helper found for module: MMM-OpenmapWeather.
      > [2020-05-26 13:15:58.983] [LOG]    No helper found for module: weatherforecast.
      > [2020-05-26 13:15:59.297] [LOG]    Initializing new module helper ...
      > [2020-05-26 13:15:59.297] [LOG]    Module helper loaded: MMM-AlexaControl
      > [2020-05-26 13:15:59.319] [LOG]    Initializing new module helper ...
      > [2020-05-26 13:15:59.319] [LOG]    Module helper loaded: newsfeed
      > [2020-05-26 13:15:59.320] [LOG]    No helper found for module: MMM-pages.
      > [2020-05-26 13:15:59.320] [LOG]    No helper found for module: MMM-page-indicator.
      > [2020-05-26 13:15:59.586] [LOG]    Initializing new module helper ...
      > [2020-05-26 13:15:59.587] [LOG]    Module helper loaded: MMM-Screencast
      > [2020-05-26 13:15:59.587] [LOG]    All module helpers loaded.
      > [2020-05-26 13:15:59.710] [LOG]    Starting server on port 8080 ...
      > [2020-05-26 13:15:59.715] [INFO]   You're using a full whitelist configuration to allow for all IPs
      > [2020-05-26 13:15:59.732] [LOG]    Server started ...
      > [2020-05-26 13:15:59.733] [LOG]    Connecting socket for: updatenotification
      > [2020-05-26 13:15:59.734] [LOG]    Connecting socket for: calendar
      > [2020-05-26 13:15:59.734] [LOG]    Starting node helper for: calendar
      > [2020-05-26 13:15:59.735] [LOG]    Connecting socket for: MMM-Remote-Control
      > [2020-05-26 13:15:59.735] [LOG]    Starting node helper for: MMM-Remote-Control
      > [2020-05-26 13:15:59.741] [LOG]    Connecting socket for: MMM-Remote-Control-Repository
      > [2020-05-26 13:15:59.742] [LOG]    Connecting socket for: MMM-AlexaControl
      > [2020-05-26 13:15:59.742] [LOG]    MMM-AlexaControl helper, started...
      > [2020-05-26 13:15:59.743] [LOG]    Connecting socket for: newsfeed
      > [2020-05-26 13:15:59.743] [LOG]    Starting module: newsfeed
      > [2020-05-26 13:15:59.743] [LOG]    Connecting socket for: MMM-Screencast
      > [2020-05-26 13:15:59.744] [LOG]    Sockets connected & modules started ...
      > [2020-05-26 13:15:59.750] [LOG]    Whoops! There was an uncaught exception...
      > [2020-05-26 13:15:59.758] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      > [2020-05-26 13:15:59.758] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      > [2020-05-26 13:15:59.915] [LOG]    Launching application.
      pi@raspberrypi:~ $ cd MagicMirror/config
      pi@raspberrypi:~/MagicMirror/config $ display=:0 npm start >> log.log
      [2020-05-26 13:15:59.751] [ERROR]  Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
          at Server.setupListenHandle [as _listen2] (net.js:1226:14)
          at listenInCluster (net.js:1274:12)
          at doListen (net.js:1413:7)
          at processTicksAndRejections (internal/process/task_queues.js:84:9) {
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '0.0.0.0',
        port: 8080
      [2020-05-26 13:16:00.304] [ERROR]  ERROR! Could not find main module js file for MMM-API
      Thank you very much
      StoffbeuteluweS S 2 Replies Last reply Reply Quote 0
        JohnBachini
        @Stevent you need to post your conifg minus token/account/password information, dont think you can get much help with just what you have provided.
        • StoffbeuteluweS Offline
          Stoffbeuteluwe Project Sponsor @Stevent
          @Stevent I have tried the module on Mac and it’s also not working …
            sdetweil @Stevent
            @Stevent said in MMM-Screencast don`t work:
            errno: ‘EADDRINUSE’,
            syscall: ‘listen’,
            address: ‘0.0.0.0’,
            port: 8080
            did u specify a port? the default is 8569
            port	Optional A port to run the dialserver on Type number default 8569
            you cannot use the same port as MM does
              JohnBachini
              @Stevent Try changing port to something other than 8080, I’m guessing something else is using that port, Like MagicMirror itself.
                JohnBachini @JohnBachini
                @JohnBachini
                @sdetweil you beat me to it… :-)
                  Stevent
                  Sorry, here is the config, no custom Port in Screencast configurated.
                  var config = {
                  	address: "0.0.0.0", // Address to listen on, can be:
                  	                      // Default, when address config is lefthttp://bulk.openweathermap.org/sample/city.list.json.gz out or empty, is "localhost"
                  	port: 8080,
                  	ipWhitelist: [], // Set [] to allow all IP addresses
                  	language: "de",
                  	timeFormat: 24,
                  	units: "metric",
                  			     // false, default for all  NON-armv6l devices
                              module: 'MMM-Remote-Control',  // uncomment the following line to show the URL of the remote control on the mirror
                              position: 'bottom_left',  // you can hide this module afterwards from the remote control itself
                                  customCommand: {},  // Optional, See "Using Custom Commands" below
                  		customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                  		showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                                  pages: 2,
                  			module: "MMM-Remote-Control-Repository",
                              module: 'MMM-AlexaControl',
                              position: 'middle_center',
                              image: false,
                              pm2ProcessName: "mm",
                              monitorToggle: true,
                              vcgencmd: "vcgencmd",
                              deviceName: "Spiegel",
                  	        pages: 2
                          module: 'MMM-pages',
                                  modules:
                                      [[ "MMM-OpenmapWeather","weatherforecast","newsfeed","calendar", "compliments"],
                                       [ "MMM-OpenmapWeather","MMM-Screencast"]],
                                  fixed: ["clock", "currentweather", "MMM-AlexaControl", "MMM-page-indicator","MMM-Screencast"],
                          module: 'MMM-page-indicator',
                          position: 'bottom_bar',
                              pages: 2
                  		module: 'MMM-Screencast',
                  		position: 'bottom_right', // This position is for a hidden <div /> and not the screencast window
                  			position: 'center',
                  			// position: "center",
                  			height: 300,
                  			width: 500,
                  			castName: "SpiegelRasp",
                  JerryPJ 1 Reply Last reply Reply Quote 0
                    JohnBachini
                    @Stevent
                    I quickly tried that module and it does work, what if you specify different port than 8080 in screencast config.
                    If that makes no difference, what happens if you change ip address on which Magicmirror listens on at top of your config.
                    address: “0.0.0.0”, //Address to listen on - Change this to ip of your MagicMirror.
                      Stevent
                      Not work change Port,
                      but diferent pm2 log after change
                      address: “0.0.0.0”,
                      to
                      address:“IPfromRASP”,
                      0|MagicMir | [2020-06-15 20:28:02.945] [ERROR]  Error [ERR_SERVER_ALREADY_LISTEN]: Listen method has been called more than once without closing.
                      0|MagicMir |     at Server.listen (net.js:1312:11)
                      0|MagicMir |     at DialServer.start (/home/pi/MagicMirror/modules/MMM-Screencast/DialServer.js:122:17)
                      0|MagicMir |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Screencast/node_helper.js:13:21)
                      0|MagicMir |     at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:113:11)
                      0|MagicMir |     at Socket.emit (events.js:200:13)
                      0|MagicMir |     at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                      0|MagicMir |     at processTicksAndRejections (internal/process/task_queues.js:82:9)
                        JohnBachini
                        @Stevent i notice in your config for pages you have screencast twice , one in second page and one in fixed
                          Stevent
                          @JohnBachini said in MMM-Screencast don&#x60;t work:
                          I change it but no change in the log
                            AR2020 @Stevent
                            @stevent Im sure its your Alexa module, cut it off your config save the config file, try it after. If it works I have this same problem Alexa module conflicts with cast but its not the port i tried custom port on cast module.
                            • JerryPJ Offline
                              JerryP @Stevent
                              @stevent said in MMM-Screencast don&#x60;t work:
                               		position: 'center',
                               		height: 300,
                               		width: 500,
                              		castName: 'SpiegelRasp',
                              Pleas tray this to copy past in your config file
                              i’ts working one mine
