    Need help from an CSS expert!
    6 Posts 3 Posters 6.0k Views 3 Watching
      Mr.Sponti
      I’m a complete novice to CSS and momentary it’s all Greek for me. I would like to change an existing style sheet provided by BenRoe (MMM-FHEM) for my own modul, but it would take me days to find the right code to change it to the layout below. An expert would presumably spend only a few minutes to create the necessary css file.
      Below the existing display and style sheet of temperature values plus the layout I would like to realize.
      Any hint how to start or assistance would be highly appreciated!
      Thanks in advance.
      alt text
      .MMM-M2-Pimatic .flex-container {
        display: flex;
        display: -webkit-box;
        display: -moz-box;
        display: -ms-flexbox;
        display: -webkit-flex;
        flex-wrap: wrap;
        flex-direction: column;
        justify-content:flex-end;
      .MMM-M2-Pimatic .module-content .flex-item {
        /*margin: auto;*/
      .region.left .MMM-M2-Pimatic .flex-container,
      .region.center .MMM-M2-Pimatic .flex-container,
      .region.right .MMM-M2-Pimatic .flex-container {
        -webkit-flex-direction: column;
        align-items: flex-start;
        -webkit-align-items: flex-end;
        max-width: 300px;
      .region.left .MMM-M2-Pimatic .flex-container .flex-item > div,
      .region.center .MMM-M2-Pimatic .flex-container .flex-item > div,
      .region.right .MMM-M2-Pimatic .flex-container .flex-item > div {
        display: inline-block;
        min-width: 70px;
      .MMM-M2-Pimatic .flex-item .title {
        border-bottom: 1px solid #666;
      .region.left .MMM-M2-Pimatic .flex-item .title,
      .region.center .MMM-M2-Pimatic .flex-item .title,
      .region.right .MMM-M2-Pimatic .flex-item .title{
        border-bottom: none;
      .MMM-M2-Pimatic .flex-item .value {
        margin: 10px 5px;
      .region.left .MMM-M2-Pimatic .flex-item .value,
      .region.center .MMM-M2-Pimatic .flex-item .value,
      .region.right .MMM-M2-Pimatic .flex-item .value{
        margin: 0;
        font-size: 1em;
      .MMM-M2-Pimatic .value i {
        margin-right: 8px;
        font-size: 0.75em;
      T strawberry 3.141S 2 Replies Last reply Reply Quote 0
      • T Offline
        tosti007 Module Developer @Mr.Sponti
        @Mr.Sponti odd that nobody has said something here yet. Anyways a hint on how to start is read a tutorial about flex boxes, since he is using that. This is in my opinion always a good one. Hope this helps! Let me know if you are able to figure it out on your own or if you need my help :)
        Note: I am no expert, but I do know my way around in css.
        If there is anything don’t hesitate to contact me!
        ProfileSwitcher, TouchNotifications
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Mr.Sponti
          @Mr.Sponti I guess changing the flex-direction from column to row of the container should be a good starting point
          • T Offline
            tosti007 Module Developer @strawberry 3.141
            @strawberry-3.141 I didn’t want to spoil the fun of learning it :) :P
              Mr.Sponti
              @tosti007 , @strawberry 3.141 - ok, you all right, it is not a failure to investigate a bit time to consult the internet and to learn new things!
              I found and implemented a solution based on a table definition:
              alt text
              That’s was exactly what I was looking for!
              T 1 Reply Last reply Reply Quote 2
              • T Offline
                @Mr.Sponti Good to hear that you have what you were looking for :D Looks nice!
