    Gosund SP111
    15 Posts 2 Posters 2.5k Views 2 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @lordhelix
      @lordhelix updateinterval is the interval for an update of the module DOM in ms, so 60 seconds. Can not be the source of error.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • L Offline
        lordhelix
        Gosund SP 111 and SP112
        i tried with localhost first, but nothing happens. I will try out with your tips.
        • L Offline
          lordhelix
          @lavolp3 said in Gosund SP111:
          npm start dev
          pi@raspberrypi:~/MagicMirror $ npm start dev
          > magicmirror@2.11.0 start /home/pi/MagicMirror
          > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
          [2020-06-21 00:39:48.599] [LOG]    Starting MagicMirror: v2.11.0
          [2020-06-21 00:39:48.613] [LOG]    Loading config ...
          [2020-06-21 00:39:48.623] [LOG]    Loading module helpers ...
          [2020-06-21 00:39:48.663] [LOG]    Initializing new module helper ...
          [2020-06-21 00:39:48.665] [LOG]    Module helper loaded: MMM-Admin-Interface
          [2020-06-21 00:39:48.668] [LOG]    No helper found for module: alert.
          [2020-06-21 00:39:48.739] [LOG]    Initializing new module helper ...
          [2020-06-21 00:39:48.740] [LOG]    Module helper loaded: updatenotification
          [2020-06-21 00:39:48.741] [LOG]    No helper found for module: clock.
          [2020-06-21 00:39:49.470] [LOG]    Initializing new module helper ...
          [2020-06-21 00:39:49.472] [LOG]    Module helper loaded: calendar
          [2020-06-21 00:39:49.474] [LOG]    No helper found for module: currentweather.
          [2020-06-21 00:39:49.476] [LOG]    No helper found for module: weatherforecast.
          [2020-06-21 00:39:49.477] [LOG]    No helper found for module: MMM-WiFiPassword.
          [2020-06-21 00:39:49.481] [LOG]    Initializing new module helper ...
          [2020-06-21 00:39:49.482] [LOG]    Module helper loaded: MMM-BurnIn
          [2020-06-21 00:39:49.486] [LOG]    Initializing new module helper ...
          [2020-06-21 00:39:49.487] [LOG]    Module helper loaded: MMM-COVID19
          [2020-06-21 00:39:49.749] [LOG]    Initializing new module helper ...
          [2020-06-21 00:39:49.750] [LOG]    Module helper loaded: MMM-Tasmota
          [2020-06-21 00:39:49.751] [LOG]    No helper found for module: MMM-MQTT.
          [2020-06-21 00:39:49.752] [LOG]    All module helpers loaded.
          [2020-06-21 00:39:49.955] [LOG]    Starting server on port 8080 ...
          [2020-06-21 00:39:49.985] [INFO]   You're using a full whitelist configuration to allow for all IPs
          [2020-06-21 00:39:50.000] [LOG]    Server started ...
          [2020-06-21 00:39:50.012] [LOG]    Connecting socket for: MMM-Admin-Interface
          [2020-06-21 00:39:50.016] [LOG]    Starting node helper for: MMM-Admin-Interface
          [2020-06-21 00:39:50.147] [LOG]    Connecting socket for: updatenotification
          [2020-06-21 00:39:50.149] [LOG]    Connecting socket for: calendar
          [2020-06-21 00:39:50.151] [LOG]    Starting node helper for: calendar
          [2020-06-21 00:39:50.153] [LOG]    Connecting socket for: MMM-BurnIn
          [2020-06-21 00:39:50.155] [LOG]    Connecting socket for: MMM-COVID19
          [2020-06-21 00:39:50.156] [LOG]    Starting node helper for: MMM-COVID19
          [2020-06-21 00:39:50.158] [LOG]    Connecting socket for: MMM-Tasmota
          [2020-06-21 00:39:50.166] [LOG]    Sockets connected & modules started ...
          [2020-06-21 00:39:50.299] [LOG]    Whoops! There was an uncaught exception...
          [2020-06-21 00:39:50.300] [ERROR]  Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
              at Server.setupListenHandle [as _listen2] (net.js:1226:14)
              at listenInCluster (net.js:1274:12)
              at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
              at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
            code: 'EADDRINUSE',
            errno: 'EADDRINUSE',
            syscall: 'listen',
            address: '127.0.0.1',
            port: 8080
          [2020-06-21 00:39:50.314] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [2020-06-21 00:39:50.316] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [2020-06-21 00:39:50.323] [LOG]    Launching application.
          Sorry, i cant read this information. There is an issus, but i cant located them.
          • lavolp3L Offline
            @lordhelix you have the mirror running via pm2 already.
            You need to do
            pm2 stop all
            npm start dev
            • L Offline
              lordhelix
              @lavolp3 Thank you. It looks like the topic isn’t subscribed.
              My MQTT-DATA
              09:31:09 MQT: tele/Testdose/STATE = {"Time":"2020-06-21T09:31:09","Uptime":"0T10:37:28","UptimeSec":38248,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":2,"SSId":"XXX2,4GHz","BSSId":"44:4E:6D:94:88:30","Channel":1,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:03"}}
              09:31:09 MQT: tele/Testdose/SENSOR = {"Time":"2020-06-21T09:31:09","ENERGY":{"TotalStartTime":"2020-06-20T19:39:40","Total":0.195,"Yesterday":0.195,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":0,"Current":0.000}}
              09:31:11 MQT: stat/Testdose/RESULT = {"POWER":"ON"}
              09:31:11 MQT: stat/Testdose/POWER = ON
              09:31:16 MQT: stat/Testdose/RESULT = {"POWER":"OFF"}
              09:31:16 MQT: stat/Testdose/POWER = OFF
              09:36:09 MQT: tele/Testdose/STATE = {"Time":"2020-06-21T09:36:09","Uptime":"0T10:42:28","UptimeSec":38548,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":2,"SSId":"XXX2,4GHz","BSSId":"44:4E:6D:94:88:30","Channel":1,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:03"}}
              09:36:09 MQT: tele/Testdose/SENSOR = {"Time":"2020-06-21T09:36:09","ENERGY":{"TotalStartTime":"2020-06-20T19:39:40","Total":0.195,"Yesterday":0.195,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":0,"Current":0.000}}
              pi@raspberrypi:~ $ pm2 stop all
              [PM2] Applying action stopProcessId on app [all](ids: 0)
              [PM2] [MagicMirror](0) ✓
              │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
              │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
              pi@raspberrypi:~ $ cd MagicMirror
              [2020-06-21 10:29:22.516] [LOG]    Starting MagicMirror: v2.11.0
              [2020-06-21 10:29:22.528] [LOG]    Loading config ...
              [2020-06-21 10:29:22.537] [LOG]    Loading module helpers ...
              [2020-06-21 10:29:22.572] [LOG]    Initializing new module helper ...
              [2020-06-21 10:29:22.574] [LOG]    Module helper loaded: MMM-Admin-Interface
              [2020-06-21 10:29:22.577] [LOG]    No helper found for module: alert.
              [2020-06-21 10:29:22.654] [LOG]    Initializing new module helper ...
              [2020-06-21 10:29:22.654] [LOG]    Module helper loaded: updatenotification
              [2020-06-21 10:29:22.656] [LOG]    No helper found for module: clock.
              [2020-06-21 10:29:23.293] [LOG]    Initializing new module helper ...
              [2020-06-21 10:29:23.294] [LOG]    Module helper loaded: calendar
              [2020-06-21 10:29:23.295] [LOG]    No helper found for module: currentweather.
              [2020-06-21 10:29:23.296] [LOG]    No helper found for module: weatherforecast.
              [2020-06-21 10:29:23.297] [LOG]    No helper found for module: MMM-WiFiPassword.
              [2020-06-21 10:29:23.301] [LOG]    Initializing new module helper ...
              [2020-06-21 10:29:23.302] [LOG]    Module helper loaded: MMM-BurnIn
              [2020-06-21 10:29:23.305] [LOG]    Initializing new module helper ...
              [2020-06-21 10:29:23.306] [LOG]    Module helper loaded: MMM-COVID19
              [2020-06-21 10:29:23.541] [LOG]    Initializing new module helper ...
              [2020-06-21 10:29:23.543] [LOG]    Module helper loaded: MMM-Tasmota
              [2020-06-21 10:29:23.544] [LOG]    All module helpers loaded.
              [2020-06-21 10:29:23.723] [LOG]    Starting server on port 8080 ...
              [2020-06-21 10:29:23.739] [INFO]   You're using a full whitelist configuration t        o allow for all IPs
              [2020-06-21 10:29:23.752] [LOG]    Server started ...
              [2020-06-21 10:29:23.754] [LOG]    Connecting socket for: MMM-Admin-Interface
              [2020-06-21 10:29:23.756] [LOG]    Starting node helper for: MMM-Admin-Interface
              [2020-06-21 10:29:23.874] [LOG]    Connecting socket for: updatenotification
              [2020-06-21 10:29:23.876] [LOG]    Connecting socket for: calendar
              [2020-06-21 10:29:23.877] [LOG]    Starting node helper for: calendar
              [2020-06-21 10:29:23.878] [LOG]    Connecting socket for: MMM-BurnIn
              [2020-06-21 10:29:23.879] [LOG]    Connecting socket for: MMM-COVID19
              [2020-06-21 10:29:23.881] [LOG]    Starting node helper for: MMM-COVID19
              [2020-06-21 10:29:23.882] [LOG]    Connecting socket for: MMM-Tasmota
              [2020-06-21 10:29:23.888] [LOG]    Sockets connected & modules started ...
              [2020-06-21 10:29:24.008] [LOG]    Launching application.
              [2020-06-21 10:29:29.805] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXXXXXX/basic.ics - Interval: 300000
              [2020-06-21 10:29:31.246] [LOG]    MMM-Tasmota: "Connected to host: http://localhost:1883"
              [2020-06-21 10:29:31.248] [LOG]    MMM-Tasmota: "Subscribing to topic: stat/Testdose/#"
              [2020-06-21 10:29:31.296] [LOG]    MMM-Tasmota: "Subscribed to topic: stat/Testdose/#"
              [2020-06-21 10:31:12.139] [LOG]    MMM-Tasmota: "Received message from: stat/Testdose/RESULT"
              [2020-06-21 10:31:12.145] [LOG]    MMM-Tasmota: "Received message from: stat/Testdose/POWER"
              • lavolp3L Offline
                @lordhelix Can you please do a git pull and do the whole thing again (npm start dev)?
                I have increased debugging output so we can see the data that has been transferred to the module.
                Thank you!
                • L Offline
                  lordhelix
                  Hello @lavolp3 ,
                  i try the git pull…
                  pi@raspberrypi:~ $ cd MagicMirror/modules/MMM-Tasmota
                  pi@raspberrypi:~/MagicMirror/modules/MMM-Tasmota $ git pull
                  error: Objektdatei .git/objects/e3/ac23aabf6431dd82b8c207f734f8c046831f05 ist leer.
                  fatal: Loses Objekt e3ac23aabf6431dd82b8c207f734f8c046831f05 (gespeichert in .git/objects/e3/ac23aabf6431dd82b8c207f734f8c046831f05) ist beschädigt.
                  fatal: Die Gegenseite hat unerwartet abgebrochen.
                  I change the node-helper.js manually. Error. i delete the module and clone new.
                  [2020-06-22 19:22:16.259] [LOG]    Starting MagicMirror: v2.11.0
                  [2020-06-22 19:22:16.275] [LOG]    Loading config ...
                  [2020-06-22 19:22:16.284] [LOG]    Loading module helpers ...
                  [2020-06-22 19:22:16.325] [LOG]    Initializing new module helper ...
                  [2020-06-22 19:22:16.326] [LOG]    Module helper loaded: MMM-Admin-Interface
                  [2020-06-22 19:22:16.329] [LOG]    No helper found for module: alert.
                  [2020-06-22 19:22:16.399] [LOG]    Initializing new module helper ...
                  [2020-06-22 19:22:16.400] [LOG]    Module helper loaded: updatenotification
                  [2020-06-22 19:22:16.401] [LOG]    No helper found for module: clock.
                  [2020-06-22 19:22:17.118] [LOG]    Initializing new module helper ...
                  [2020-06-22 19:22:17.119] [LOG]    Module helper loaded: calendar
                  [2020-06-22 19:22:17.120] [LOG]    No helper found for module: currentweather.
                  [2020-06-22 19:22:17.122] [LOG]    No helper found for module: weatherforecast.
                  [2020-06-22 19:22:17.123] [LOG]    No helper found for module: MMM-WiFiPassword.
                  [2020-06-22 19:22:17.126] [LOG]    Initializing new module helper ...
                  [2020-06-22 19:22:17.127] [LOG]    Module helper loaded: MMM-BurnIn
                  [2020-06-22 19:22:17.131] [LOG]    Initializing new module helper ...
                  [2020-06-22 19:22:17.132] [LOG]    Module helper loaded: MMM-COVID19
                  [2020-06-22 19:22:17.406] [LOG]    Initializing new module helper ...
                  [2020-06-22 19:22:17.407] [LOG]    Module helper loaded: MMM-Tasmota
                  [2020-06-22 19:22:17.408] [LOG]    All module helpers loaded.
                  [2020-06-22 19:22:17.611] [LOG]    Starting server on port 8080 ...
                  [2020-06-22 19:22:17.629] [INFO]   You're using a full whitelist configuration to allow for all IPs
                  [2020-06-22 19:22:17.642] [LOG]    Server started ...
                  [2020-06-22 19:22:17.645] [LOG]    Connecting socket for: MMM-Admin-Interface
                  [2020-06-22 19:22:17.647] [LOG]    Starting node helper for: MMM-Admin-Interface
                  [2020-06-22 19:22:17.780] [LOG]    Connecting socket for: updatenotification
                  [2020-06-22 19:22:17.781] [LOG]    Connecting socket for: calendar
                  [2020-06-22 19:22:17.783] [LOG]    Starting node helper for: calendar
                  [2020-06-22 19:22:17.784] [LOG]    Connecting socket for: MMM-BurnIn
                  [2020-06-22 19:22:17.785] [LOG]    Connecting socket for: MMM-COVID19
                  [2020-06-22 19:22:17.786] [LOG]    Starting node helper for: MMM-COVID19
                  [2020-06-22 19:22:17.788] [LOG]    Connecting socket for: MMM-Tasmota
                  [2020-06-22 19:22:17.795] [LOG]    Sockets connected & modules started ...
                  [2020-06-22 19:22:17.933] [LOG]    Launching application.
                  [2020-06-22 19:22:24.276] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXXXXX/basic.ics - Interval: 300000
                  [2020-06-22 19:22:25.493] [LOG]    MMM-Tasmota: "Connected to host: http://localhost:1883"
                  [2020-06-22 19:22:25.495] [LOG]    MMM-Tasmota: "Subscribing to topic: stat/Testdose/#"
                  [2020-06-22 19:22:25.545] [LOG]    MMM-Tasmota: "Subscribed to topic: stat/Testdose/#"
                  [2020-06-22 19:25:12.232] [LOG]    MMM-Tasmota: "Received message from stat/Testdose/RESULT: {\"POWER\":\"ON\"}"
                  [2020-06-22 19:25:12.342] [LOG]    MMM-Tasmota: "Received message from stat/Testdose/POWER: ON"
                  • lavolp3L Offline
                    @lordhelix what is your mqtt configuration in the devices? Especially the telemetry interval? It seems you see a message that power state has changed but no state and power data that gets distributed in intervals. Have you waited long enough?
                    • L Offline
                      lordhelix
                      Hello @lavolp3 ,
                      i wait 25 minutes yesterday.
                      interval: 300 // 5 minutes, i don´t change it, this is default.
                      I change the Period to 10 seconds, but the same problem.
                      • lavolp3L Offline
                        @lordhelix we should track this on github to not spam here, can you please open an issue?
                        I’m currently out of ideas, but will follow up on github. I need your input to see that my module works for others :-)
