Gosund SP111
15 Posts 2 Posters 1.8k Views 2 Watching
  • L Offline
    lordhelix
    Hello @lavolp3 ,
    i try the git pull…
    pi@raspberrypi:~ $ cd MagicMirror/modules/MMM-Tasmota
    pi@raspberrypi:~/MagicMirror/modules/MMM-Tasmota $ git pull
    error: Objektdatei .git/objects/e3/ac23aabf6431dd82b8c207f734f8c046831f05 ist leer.
    fatal: Loses Objekt e3ac23aabf6431dd82b8c207f734f8c046831f05 (gespeichert in .git/objects/e3/ac23aabf6431dd82b8c207f734f8c046831f05) ist beschädigt.
    fatal: Die Gegenseite hat unerwartet abgebrochen.
    I change the node-helper.js manually. Error. i delete the module and clone new.
    pi@raspberrypi:~/MagicMirror $ npm start dev
    > magicmirror@2.11.0 start /home/pi/MagicMirror
    > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
    [2020-06-22 19:22:16.259] [LOG]    Starting MagicMirror: v2.11.0
    [2020-06-22 19:22:16.275] [LOG]    Loading config ...
    [2020-06-22 19:22:16.284] [LOG]    Loading module helpers ...
    [2020-06-22 19:22:16.325] [LOG]    Initializing new module helper ...
    [2020-06-22 19:22:16.326] [LOG]    Module helper loaded: MMM-Admin-Interface
    [2020-06-22 19:22:16.329] [LOG]    No helper found for module: alert.
    [2020-06-22 19:22:16.399] [LOG]    Initializing new module helper ...
    [2020-06-22 19:22:16.400] [LOG]    Module helper loaded: updatenotification
    [2020-06-22 19:22:16.401] [LOG]    No helper found for module: clock.
    [2020-06-22 19:22:17.118] [LOG]    Initializing new module helper ...
    [2020-06-22 19:22:17.119] [LOG]    Module helper loaded: calendar
    [2020-06-22 19:22:17.120] [LOG]    No helper found for module: currentweather.
    [2020-06-22 19:22:17.122] [LOG]    No helper found for module: weatherforecast.
    [2020-06-22 19:22:17.123] [LOG]    No helper found for module: MMM-WiFiPassword.
    [2020-06-22 19:22:17.126] [LOG]    Initializing new module helper ...
    [2020-06-22 19:22:17.127] [LOG]    Module helper loaded: MMM-BurnIn
    [2020-06-22 19:22:17.131] [LOG]    Initializing new module helper ...
    [2020-06-22 19:22:17.132] [LOG]    Module helper loaded: MMM-COVID19
    [2020-06-22 19:22:17.406] [LOG]    Initializing new module helper ...
    [2020-06-22 19:22:17.407] [LOG]    Module helper loaded: MMM-Tasmota
    [2020-06-22 19:22:17.408] [LOG]    All module helpers loaded.
    [2020-06-22 19:22:17.611] [LOG]    Starting server on port 8080 ...
    [2020-06-22 19:22:17.629] [INFO]   You're using a full whitelist configuration to allow for all IPs
    [2020-06-22 19:22:17.642] [LOG]    Server started ...
    [2020-06-22 19:22:17.645] [LOG]    Connecting socket for: MMM-Admin-Interface
    [2020-06-22 19:22:17.647] [LOG]    Starting node helper for: MMM-Admin-Interface
    [2020-06-22 19:22:17.780] [LOG]    Connecting socket for: updatenotification
    [2020-06-22 19:22:17.781] [LOG]    Connecting socket for: calendar
    [2020-06-22 19:22:17.783] [LOG]    Starting node helper for: calendar
    [2020-06-22 19:22:17.784] [LOG]    Connecting socket for: MMM-BurnIn
    [2020-06-22 19:22:17.785] [LOG]    Connecting socket for: MMM-COVID19
    [2020-06-22 19:22:17.786] [LOG]    Starting node helper for: MMM-COVID19
    [2020-06-22 19:22:17.788] [LOG]    Connecting socket for: MMM-Tasmota
    [2020-06-22 19:22:17.795] [LOG]    Sockets connected & modules started ...
    [2020-06-22 19:22:17.933] [LOG]    Launching application.
    [2020-06-22 19:22:24.276] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXXXXX/basic.ics - Interval: 300000
    [2020-06-22 19:22:25.493] [LOG]    MMM-Tasmota: "Connected to host: http://localhost:1883"
    [2020-06-22 19:22:25.495] [LOG]    MMM-Tasmota: "Subscribing to topic: stat/Testdose/#"
    [2020-06-22 19:22:25.545] [LOG]    MMM-Tasmota: "Subscribed to topic: stat/Testdose/#"
    [2020-06-22 19:25:12.232] [LOG]    MMM-Tasmota: "Received message from stat/Testdose/RESULT: {\"POWER\":\"ON\"}"
    [2020-06-22 19:25:12.342] [LOG]    MMM-Tasmota: "Received message from stat/Testdose/POWER: ON"
    L 1 Reply Last reply Jun 22, 2020, 8:36 PM Reply Quote 0
    • L Offline
      lavolp3 Module Developer @lordhelix
      @lordhelix what is your mqtt configuration in the devices? Especially the telemetry interval? It seems you see a message that power state has changed but no state and power data that gets distributed in intervals. Have you waited long enough?
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • L Offline
        lordhelix
        Hello @lavolp3 ,
        i wait 25 minutes yesterday.
        interval: 300 // 5 minutes, i don´t change it, this is default.
        I change the Period to 10 seconds, but the same problem.
        L 1 Reply Last reply Jun 23, 2020, 12:09 PM Reply Quote 0
        • L Offline
          @lordhelix we should track this on github to not spam here, can you please open an issue?
          I’m currently out of ideas, but will follow up on github. I need your input to see that my module works for others :-)
          • L Offline
            @lordhelix I have again increased debugging output.
            Please update the module again and report back on github.
            Thanks!
            2 / 2
