    V2.1.X Updates
    Scheduled Pinned Locked Moved MagicMirror
    4 Posts 1 Posters 16.5k Views 5 Watching
    • MichMichM Offline
      MichMich
      As an end of year present, I just released version V2.1.0:
      https://github.com/MichMich/MagicMirror/releases/tag/v2.1.0
      Special thanks to @roramirez for a LOT of awesome contributions.
      [2.1.0] - 2016-12-31
      Note: This update uses new dependencies. Please update using the following command: git pull && npm install
      Added
      • Finnish translation.
      • Danish translation.
      • Turkish translation.
      • Option to limit access to certain IP addresses based on the value of ipWhitelist in the config.js, default is access from localhost only (Issue #456).
      • Added ability to change the point of time when calendar events get relative.
      • Add Splash screen on boot.
      • Add option to show humidity in currentWeather module.
      • Add VSCode IntelliSense support.
      • Module API: Add Visibility locking to module system. See documentation for more information.
      • Module API: Method to overwrite the module’s header. See documentation for more information.
      • Module API: Option to define the minimum MagicMirror version to run a module. See documentation for more information.
      • Calendar module now broadcasts the event list to all other modules using the notification system. See documentation for more information.
      • Possibility to use the the calendar feed as the source for the weather (currentweather & weatherforecast) location data. See documentation for more information.
      • Added option to show rain amount in the weatherforecast default module
      • Add module updatenotification to get an update whenever a new version is availabe. See documentation for more information.
      • Add the abilty to set timezone on the date display in the Clock Module
      • Ability to set date format in calendar module
      • Possibility to use currentweather for the compliments
      • Added option disabled for modules.
      • Added option address to set bind address.
      • Added option onlyTemp for currentweather module to show show only current temperature and weather icon.
      • Added option remoteFile to compliments module to load compliment array from filesystem.
      • Added option zoom to scale the whole mirror display with a given factor.
      • Added option roundTemp for currentweather and weatherforecast modules to display temperatures rounded to nearest integer.
      • Added abilty set the classes option to compliments module for style and text size of compliments.
      • Added ability to configure electronOptions
      • Calendar module: option to hide private events
      • Add root_path for global vars
      Updated
      • Modified translations for Frysk.
      • Modified core English translations.
      • Updated package.json as a result of Snyk security update.
      • Improve object instantiation to prevent reference errors.
      • Improve logger. Log.log() now accepts multiple arguments.
      • Remove extensive logging in newsfeed node helper.
      • Calendar times are now uniformly capitalized.
      • Modules are now secure, and Helmet is now used to prevent abuse of the Mirror’s API.
      Fixed
      • Solve an issue where module margins would appear when the first module of a section was hidden.
      • Solved visual display errors on chrome, if all modules in one of the right sections are hidden.
      • Global and Module default config values are no longer modified when setting config values.
      • Hide a region if all modules in a region are hidden. Prevention unwanted margins.
      • Replaced electron-prebuilt package with electron in order to fix issues that would happen after 2017.
      • Documentation of alert module
      1 Reply Last reply Reply Quote 11
      • MichMichM Offline
        MichMich
        April Fools! But this is no joke! We’ve just released an update for MagicMirror.
        Thanks to all of the contributors for all of their hard work! You guys are awesome and deserve those MagicMirror compliments!
        [2.1.1] - 2017-04-01
        Changed
        • Add anytime group for Compliments module.
        • Compliments module can use remoteFile without default daytime arrays defined
        • Installer: Use init config.js from config.js.sample.
        • Switched out rrule package for rrule-alt and fixes in ical.js in order to fix calendar issues. (#565)
        • Make mouse events pass through the region fullscreen_above to modules below.
        • Scaled the splash screen down to make it a bit more subtle.
        • Replace HTML tables with markdown tables in README files.
        • Added DAYAFTERTOMORROW, UPDATE_NOTIFICATION and UPDATE_NOTIFICATION_MODULE to Finnish translations.
        • Run npm test on Travis automatically
        • Show the splash screen image even when is reboot or halted.
        • Added some missing translaton strings in the sv.json file.
        • Run task jsonlint to check translation files.
        • Restructured Test Suite
        Added
        • Added Docker support (Pull Request #673).
        • Calendar-specific support for maximumEntries, and maximumNumberOfDays.
        • Add loaded function to modules, providing an async callback.
        • Made default newsfeed module aware of gesture events from MMM-Gestures
        • Add use pm2 for manager process into Installer RaspberryPi script.
        • Russian Translation.
        • Afrikaans Translation.
        • Add postinstall script to notify user that MagicMirror installed successfully despite warnings from NPM.
        • Init tests using mocha.
        • Option to use RegExp in Calendar’s titleReplace.
        • Hungarian Translation.
        • Icelandic Translation.
        • Add use a script to prevent when is run by SSH session set DISPLAY enviroment.
        • Enable ability to set configuration file by the enviroment variable called MM_CONFIG_FILE.
        • Option to give each calendar a different color.
        • Option for colored min-temp and max-temp.
        • Add test e2e helloworld.
        • Add test e2e enviroment.
        • Add chai-as-promised npm module to devDependencies.
        • Basic set of tests for clock module.
        • Run e2e test in Travis.
        • Estonian Translation.
        • Add test for compliments module for parts of day.
        • Korean Translation.
        • Added console warning on startup when deprecated config options are used.
        • Add option to display temperature unit label to the current weather module.
        • Added ability to disable wrapping of news items.
        • Added in the ability to hide events in the calendar module based on simple string filters.
        • Updated Norwegian translation.
        • Added hideLoading option for News Feed module.
        • Added configurable dateFormat to clock module.
        • Added multiple calendar icon support.
        • Added tests for Translations, dev argument, version, dev console.
        • Added test anytime feature compliments module.
        • Added test ipwhitelist configuration directive.
        • Added test for calendar module: default, basic-auth, backward compability, fail-basic-auth.
        • Added meta tags to support fullscreen mode on iOS (for server mode)
        • Added ignoreOldItems and ignoreOlderThan options to the News Feed module
        • Added test for MM_PORT enviroment variable.
        • Added a configurable Week section to the clock module.
        Fixed
        • Update .gitignore to not ignore default modules folder.
        • Remove white flash on boot up.
        • Added update in Raspberry Pi installation script.
        • Fix an issue where the analog clock looked scrambled. (#611)
        • If units is set to imperial, the showRainAmount option of weatherforecast will show the correct unit.
        • Module currentWeather: check if temperature received from api is defined.
        • Fix an issue with module hidden status changing to true although lock string prevented showing it.
        • Fix newsfeed module bug (removeStartTags)
        • Fix when is set MM_PORT enviroment variable.
        • Fixed missing animation on this.show(speed) when module is alone in a region.
        1 Reply Last reply Reply Quote 4
        • MichMichM Offline
          MichMich
          It’s that time of the year again. A fresh new version of MagicMirror is waiting for you! Thanks to everyone who contributed! You guys rock!
          https://github.com/MichMich/MagicMirror/releases/tag/v2.1.2
          [2.1.2] - 2017-07-01
          Changed
          • Revert Docker related changes in favor of docker-MagicMirror. All Docker images are outsourced. (#856)
          • Change Docker base image (Debian + Node) to an arm based distro (AlpineARM + Node) (#846)
          • Fix the dockerfile to have it running from the first time.
          Added
          • Add in option to wrap long calendar events to multiple lines using wrapEvents configuration option.
          • Add test e2e show title newsfeed for newsfeed module.
          • Add task to check configuration file.
          • Add test check URLs of vendors.
          • Add test of match current week number on clock module with showWeek configuration.
          • Add test default modules present modules/default/defaultmodules.js.
          • Add unit test calendar_modules function capFirst.
          • Add test for check if exists the directories present in defaults modules.
          • Add support for showing wind direction as an arrow instead of abbreviation in currentWeather module.
          • Add support for writing translation fucntions to support flexible word order
          • Add test for check if exits the directories present in defaults modules.
          • Add calendar option to set a separate date format for full day events.
          • Add ability for currentweather module to display indoor temperature via INDOOR_TEMPERATURE notification
          • Add ability to change the path of the custom.css.
          • Add translation Dutch to Alert module.
          • Added Romanian translation.
          Updated
          • Added missing keys to Polish translation.
          • Added missing key to German translation.
          • Added better translation with flexible word order to Finnish translation
          Fixed
          • Fix instruction in README for using automatically installer script.
          • Bug of duplicated compliments as described in here.
          • Fix double message about port when server is starting
          • Corrected Swedish translations for TODAY/TOMORROW/DAYAFTERTOMORROW.
          • Removed unused import from js/electron.js
          • Made calendar.js respect config.timeFormat irrespecive of locale setting
          • Fixed alignment of analog clock when a large calendar is displayed in the same side bar
          • MichMichM Offline
            MichMich
            On this perfect day where Max Verstappen won the Malaysian Grand Prix F1 Race, we can welcome the next release of the MagicMirror framework. Version 2.1.3. A lot of love for everyone that contributed!
            https://github.com/MichMich/MagicMirror/releases/tag/v.2.1.3
            [2.1.3] - 2017-10-01
            Changed
            • Remove Roboto fonts files inside fonts and these are installed by npm install command.
            Added
            • Add clientonly script to start only the electron client for a remote server.
            • Add symbol and color properties of event when CALENDAR_EVENTS notification is broadcasted from default/calendar module.
            • Add .vscode/ folder to .gitignore to keep custom Visual Studio Code config out of git.
            • Add unit test the capitalizeFirstLetter function of newfeed module.
            • Add new unit tests for function shorten in calendar module.
            • Add new unit tests for function getLocaleSpecification in calendar module.
            • Add unit test for js/class.js.
            • Add unit tests for function roundValue in currentweather module.
            • Add test e2e showWeek feature in spanish language.
            • Add warning Log when is used old authentication method in the calendar module.
            • Add test e2e for helloworld module with default config text.
            • Add ability for currentweather module to display indoor humidity via INDOOR_HUMIDITY notification.
            • Add Welsh (Cymraeg) translation.
            • Add Slack badge to Readme.
            Updated
            • Changed ‘default.js’ - listen on all attached interfaces by default.
            • Add execution of npm list after the test are ran in Travis CI.
            • Change hooks for the vendors e2e tests.
            • Add log when clientonly failed on starting.
            • Add warning color when are using full ip whitelist.
            • Set version of the express-ipfilter on 0.3.1.
            Fixed
            • Fixed issue with incorrect allignment of analog clock when displayed in the center column of the MM.
            • Fixed ipWhitelist behaviour to make empty whitelist ([]) allow any and all hosts access to the MM.
            • Fixed issue with calendar module where ‘excludedEvents’ count towards ‘maximumEntries’.
            • Fixed issue with calendar module where global configuration of maximumEntries was not overridden by calendar specific config (see module doc).
            • Fixed issue where this.file(filename) returns a path with two hashes.
            • Workaround for the WeatherForecast API limitation.
