    Mirror display not showing changes made to config filedock
    9 Posts 3 Posters 2.1k Views 3 Watching
    • P Offline
      Perkinje
      After making changes to the config file, like 12hr time format, adding modules etc. I restart MM and it’s as if no changes were made. It just displays the sample config. When I reopen the config file then changes are still there. I’ve even tried rebooting the whole pi with no luck. MM is running in a docker on a pi3.
      thedoorsfanaticT 1 Reply Last reply Reply Quote 0
      • thedoorsfanaticT Offline
        thedoorsfanatic @Perkinje
        @Perkinje
        Did you rename the file to config.js?
        My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
        • P Offline
          Perkinje
          yes, the filename is config.js. It shows the default display config without my changes.
            sdetweil @Perkinje
            @Perkinje do you have something at boot that copies config.js.sample to config.js? perhaps?
            • P Offline
              Perkinje @sdetweil
              @sdetweil nope, and when I reopen the config.js file my changes are still there.
                sdetweil @Perkinje
                @Perkinje so, let’s check this again
                the file used for running is
                ~/MagicMirror/config/config.js
                • P Offline
                  Perkinje @sdetweil
                  @sdetweil Yes, it is. I don’t see how this is possible. I’ve checked the docker setup to confirm the location of the config/config.js and it is showing the file I’ve modified.
                    sdetweil @Perkinje
                    @Perkinje oh, docker… don’t know about that
                    • P Offline
                      Perkinje
                      I’ve given up docker. Runs fine with standard install. I’ll try docker with my next MM.
