    Make Mirror brighter through custom.css
    9 Posts 5 Posters 4.2k Views 5 Watching
      simphi
      Hi I’ve always used MMM-Remote-Control to increase the birightness of my MagicMirror. But since I switched to a client-only Instance with MM running in docker on my home-server, the module doesnt work anymore. So now I want to increase the brighntess through a custom.css. The problem is: Im a complete beginner with css. Do you guys already have such a custom.css? Can you share it maybe?
      Thanks in advance.
      T lavolp3L 2 Replies Last reply Reply Quote 0
      • T Offline
        TheDuDiop @simphi
        @simphi hello here can you see my custom it’s not completely done yet. but it might help you a little
         * Magic Mirror                                      *
         * Custom CSS                                        *
         * By Michael Teeuw http://michaelteeuw.nl           *
         * MIT Licensed.                                     *
         * Add any custom CSS below.                         *
         * Changes to this files will be ignored by GIT. *
        html {
          cursor: none;
          overflow: hidden;
          background: #2a313b;
        ::-webkit-scrollbar {
          display: none;
        body {
          margin: 10px;
          position: absolute;
          width: calc(100% - 20px);
          height: calc(100% - 20px);
          font-weight: 400;
          font-size: 2em;
          line-height: 1.5em;
          margin-bottom: -10px;
          -webkit-font-smoothing: antialiased;
        .dimmed {
            color: #000;
        .normal {
            color: #000;
        .bright {
          color: #000;
        .header {
          color: #000;
        .module.calendar{
          background-color:#2a313b;
          border-radius:8px;
          padding:8px;
          color: #00f2ff;
          border: 1px solid ##00f2ff;
          width:300px;
          height: 150px;
        .module.clock {
          background-color:#FFCC00;
          border-radius:8px;
          padding:8px;
          color: #FFCC00;
          border: 1px solid #2a313b;
          width:300px;
          height: 150px;
        .module.updatenotification {
        	color: #FFCC00;
        	border: 1px solid #FFCC00;
        • lavolp3L Offline
          lavolp3 Module Developer @simphi
          @simphi yeah you can include these items in custom.css and play with them
          .dimmed {
          color: #ccc;
          .normal {
          color: #eee;
          .bright {
          color: #fff;
          Color: #fff is white. You could also write it as #ffffff.
          #eee or #eeeeee is a very light grey.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
            sdetweil @TheDuDiop
            @TheDuDiop please use code blocks for technical info
            paste, mark the text, hit the </> button above the editor to wrap in a code block
            please edit and correct
              simphi
              I just read the code from the MMM-Remote Module and created this CSS. Seems to work well:
              body {
              	color: #ffffff;
              header {
              	color: #ffffff;
              	border-bottom: 1px solid #ffffff;
              .dimmed {
              	color: #cccccc;
              .normal {
              	color: #ffffff;
              .bright {
              	color: #ffffff;
              Thank you all!
              • T Offline
                TheDuDiop @sdetweil
                @sdetweil sorry was too late. to edit. will do it at the next post thanks for the hint
                Error
                You are only allowed to edit posts for 3600 second(s) after posting
                  sdetweil @TheDuDiop
                  @TheDuDiop just means try to do it right , helps us all help you
                    Jagsi @simphi
                    @simphi Hy - I copied this to my custom.css file but nothing changed in the appearance of the mirror? Can someone give me hint what I did wrong?
                    • lavolp3L Offline
                      lavolp3 Module Developer @Jagsi
                      @Jagsi post your custom.css and we can try to help
