    MM cant boot, wont boot!
    40 Posts 5 Posters 16.6k Views 5 Watching
      sdetweil @Cyric
      @Cyric on the mirror black screen
      • C Offline
        Cyric @sdetweil
        @sdetweil when I go into the developer console, it says " devtools was disconnected from the page. Once the page is reloaded, devtools will automatically reconnect."
        If I x out of that and go to console, it’s empty.
        • C Offline
          Cyric
          More troubleshooting: I deleted the config.js and it loaded and said I needed to load a config.js file. I loaded the sample one, and it went back ot being a black screen.
            sdetweil @Cyric
            @Cyric ok, where do u start mm? pm2 or nom start manually
            if pm2 do
            pm2 logs --lines=100
            if nom start, the console output is right there.
            let us know what u find
            • C Offline
              Cyric @sdetweil
              @sdetweil Here is what it gave me when i tried npm start:
              "magicmirror@2.11.0 start /home/pi/MagicMirror
              DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
              [2020-07-02 21:33:26.029] [LOG] Starting MagicMirror: v2.11.0
              [2020-07-02 21:33:26.054] [LOG] Loading config …
              [2020-07-02 21:33:26.071] [LOG] Loading module helpers …
              [2020-07-02 21:33:26.079] [LOG] No helper found for module: alert.
              [2020-07-02 21:33:26.249] [LOG] Initializing new module helper …
              [2020-07-02 21:33:26.251] [LOG] Module helper loaded: updatenotification
              [2020-07-02 21:33:26.253] [LOG] No helper found for module: clock.
              [2020-07-02 21:33:26.279] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘ical’
              Require stack:
              • /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js
              • /home/pi/MagicMirror/modules/default/calendar/node_helper.js
              • /home/pi/MagicMirror/js/app.js
              • /home/pi/MagicMirror/js/electron.js
              • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
              [2020-07-02 21:33:26.282] [LOG] Loading module helpers …
              [2020-07-02 21:33:26.284] [LOG] No helper found for module: alert.
              [2020-07-02 21:33:26.286] [LOG] Initializing new module helper …
              [2020-07-02 21:33:26.287] [LOG] Module helper loaded: updatenotification
              [2020-07-02 21:33:26.289] [LOG] No helper found for module: clock.
              [2020-07-02 21:33:26.300] [ERROR] App threw an error during load
              [2020-07-02 21:33:26.303] [ERROR] Error: Cannot find module ‘ical’
              Require stack:
              • at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                at Module.require (internal/modules/cjs/loader.js:685:19)
                at require (internal/modules/cjs/helpers.js:16:16)
                at Object. (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:8:14)
                at Module._compile (internal/modules/cjs/loader.js:786:30)
                at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
                at Module.load (internal/modules/cjs/loader.js:645:32)
                [2020-07-02 21:33:26.308] [ERROR] Whoops! There was an uncaught exception…
                [2020-07-02 21:33:26.310] [ERROR] Error: Cannot find module ‘ical’
                Require stack:
                at Module.load (internal/modules/cjs/loader.js:645:32) {
                code: ‘MODULE_NOT_FOUND’,
                requireStack: [
                ‘/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js’,
                ‘/home/pi/MagicMirror/modules/default/calendar/node_helper.js’,
                ‘/home/pi/MagicMirror/js/app.js’,
                ‘/home/pi/MagicMirror/js/electron.js’,
                ‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,
                undefined
                [2020-07-02 21:33:26.337] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [2020-07-02 21:33:26.338] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues"
                sdetweil @Cyric
                @Cyric >Cannot find module ‘ical’
                hm…
                the calendar reader module is not found
                can you do
                cd ~/MagicMirror
                rm package-lock.json
                rm -rf node_ modules
                npm install
                • C Offline
                  Cyric
                  I ran that, then did npm start again. It told me: "> magicmirror@2.11.0 start /home/pi/MagicMirror
                  [2020-07-03 07:35:17.160] [ERROR] App threw an error during load
                  [2020-07-03 07:35:17.189] [ERROR] Error: Cannot find module ‘/home/pi/MagicMirror/js/…/modules/default/defaultmodules.js’
                  Require stack:
                    at Object. (/home/pi/MagicMirror/js/app.js:12:22)
                    at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                    A JavaScript error occurred in the main process
                    Uncaught Exception:
                    Require stack:
                    at Function.Module._load (internal/modules/cjs/loader.js:560:12)"
                  Now it won’t load the black screen. I have not rebooted yet.
                    sdetweil @Cyric
                    @Cyric weird
                    do
                    cd ~/MagicMirror
                    git checkout modules/default/defaultmodules.js
                    then try npm start again
                    C 2 Replies Last reply Reply Quote 0
                    • C Offline
                      Cyric @sdetweil
                      This post is deleted!
                      • C Offline
                        Cyric @sdetweil
                        @sdetweil ok, progress. It started magic mirror with a black screen and no mouse. Before it was a black screen with the mouse, and it said electron instead of magic mirror 2. I rebooted and tried to reload my config.js, but it didn’t help.
                        • 2 / 4
