    MM cant boot, wont boot!
    40 Posts 5 Posters 16.5k Views 5 Watching
      sdetweil @Cyric
      @Cyric can u show any errors from pm2 or npm start screen
      • C Offline
        Cyric @sdetweil
        @sdetweil main.js:478 Initializing MagicMirror.
        translator.js:202 Loading core translation file: translations/en.json
        translator.js:227 Loading core translation fallback file: translations/en.json
        loader.js:175 Load script: modules/default/alert//alert.js
        :8080/modules/default/alert//alert.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:185 Error on loading script: modules/default/alert//alert.js
        script.onerror @ loader.js:185
        loader.js:175 Load script: modules/default/updatenotification//updatenotification.js
        :8080/modules/default/updatenotification//updatenotification.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:185 Error on loading script: modules/default/updatenotification//updatenotification.js
        loader.js:175 Load script: modules/default/clock//clock.js
        :8080/modules/default/clock//clock.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:185 Error on loading script: modules/default/clock//clock.js
        loader.js:175 Load script: modules/default/calendar//calendar.js
        :8080/modules/default/calendar//calendar.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:185 Error on loading script: modules/default/calendar//calendar.js
        loader.js:175 Load script: modules/default/compliments//compliments.js
        :8080/modules/default/compliments//compliments.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:185 Error on loading script: modules/default/compliments//compliments.js
        loader.js:175 Load script: modules/default/currentweather//currentweather.js
        :8080/modules/default/currentweather//currentweather.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:185 Error on loading script: modules/default/currentweather//currentweather.js
        loader.js:175 Load script: modules/default/weatherforecast//weatherforecast.js
        :8080/modules/default/weatherforecast//weatherforecast.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:185 Error on loading script: modules/default/weatherforecast//weatherforecast.js
        loader.js:175 Load script: modules/default/newsfeed//newsfeed.js
        :8080/modules/default/newsfeed//newsfeed.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
        loader.js:185 Error on loading script: modules/default/newsfeed//newsfeed.js
        loader.js:194 Load stylesheet: css/custom.css
        main.js:496 All modules started!
        /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
        protocols.This exposes users of this app to unnecessary security risks.
        Consider loading the following resources over HTTPS or FTPS.
        • http://localhost:8080/css/main.css
        • http://localhost:8080/fonts/roboto.css
        • http://localhost:8080/socket.io/socket.io.js
        • http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
        • http://localhost:8080/js/defaults.js
        • http://localhost:8080/config/config.js
        • http://localhost:8080/vendor/vendor.js
        • http://localhost:8080/modules/default/defaultmodules.js
        • http://localhost:8080/js/logger.js
        • http://localhost:8080/translations/translations.js
        • http://localhost:8080/js/translator.js
        • http://localhost:8080/js/class.js
        • http://localhost:8080/js/module.js
        • http://localhost:8080/js/loader.js
        • http://localhost:8080/js/socketclient.js
        • http://localhost:8080/js/main.js
        • http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
        • http://localhost:8080/translations/en.json
        • http://localhost:8080/css/custom.css
        For more information and help, consult
        https://electronjs.org/docs/tutorial/security.
        This warning will not show up
        once the app is packaged.
        warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95
        /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
        Policy set or a policy with “unsafe-eval” enabled. This exposes users of
        (anonymous) @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145
          sdetweil @Cyric
          @Cyric are u running MM OS? or docker?
          those files should be there.
          cd ~/MagicMirror
          ls modules/default -laF
          C chrisparkerC 2 Replies Last reply Reply Quote 1
          • C Offline
            Cyric @sdetweil
            @sdetweil I’m running rasbian like the tutorial suggests.
            That command gave me: “pi@raspberrypi:~/MagicMirror $ ls modules/default -laF
            total 12
            drwxr-xr-x 2 pi pi 4096 Jul 3 08:21 ./
            drwxr-xr-x 3 pi pi 4096 Jul 3 08:21 …/
            -rw-r–r-- 1 pi pi 512 Jul 3 08:21 defaultmodules.js”
              sdetweil @Cyric
              @Cyric well. why are they. missing?
              I don’t know if this will work
              cd ~/MagicMirror
              git checkout modules/default
              if not, you will probably have to git clone and copy the files from the clone
              git clone https://github.com/MichMich/MagicMirror. git mm
              cp -r -p mm/modules/default ~/MagicMirror/modules
              • C Offline
                Cyric @sdetweil
                @sdetweil I have no idea what happened. I ran the update, restarted, and nothing worked.
                So, the command git checkout and nothing seemed to happen. I removed the folder and did the git clone of the directory. I tried to do git mm and it said mm is not a git command. I tried to run the last line you gave me, and it said no such file or directory.
                I really appreciate all your work on this.
                  sdetweil @Cyric
                  @Cyric that git clone was all one long line
                  clone this repo into a folder named mm
                  you removed the folder, that’s where it went further south
                  • C Offline
                    Cyric
                    This post is deleted!
                    • C Offline
                      Cyric @sdetweil
                      @sdetweil when I out the whole line in, it said fatal too many arguments. I made a new folder called mm and did the git clone of the site.
                      Forgot to run npm install, will do that and post results.
                      • C Offline
                        Cyric
                        ok, mostly back. My calendar and news feed is still stuck on loading, but everything else is back up. I will post some error logs later after i poke around.
                        Sam, thank you so much for your help. It is really appreciated.
                        • 3 / 4
