    MM cant boot, wont boot!
    40 Posts 5 Posters 17.2k Views 5 Watching
    • C Offline
      Cyric
      rebooted this morning, reinstalled a module, and everything is back except the weather only shows 2 days. Thank you again for your help Sam.
      • chrisparkerC Offline
        chrisparker @sdetweil
        @sdetweil I’ve going through the same thing. I had a good running copy of MM and I attempted to upgrade to the latest version. It would not boot. I followed this thread as far as discovering that all the modules had been deleted. I used the command to reinstall the default module, then reinstalled my selected modules from the MM Package Manager. Still doesn’t work, it only shows a blank screen with a pointer.
        Running npm restart gives:
        > magicmirror@2.12.0 start /home/pi/MagicMirror
        [2020-07-05 17:36:08.008] [LOG]    Starting MagicMirror: v2.12.0
        [2020-07-05 17:36:08.021] [LOG]    Loading config ...
        [2020-07-05 17:36:08.031] [LOG]    Loading module helpers ...
        [2020-07-05 17:36:08.035] [LOG]    No helper found for module: MMM-Carousel.
        [2020-07-05 17:36:08.046] [LOG]    Initializing new module helper ...
        [2020-07-05 17:36:08.048] [LOG]    Module helper loaded: MMM-WatchDog
        [2020-07-05 17:36:08.700] [LOG]    Initializing new module helper ...
        [2020-07-05 17:36:08.701] [LOG]    Module helper loaded: MMM-SystemStats
        [2020-07-05 17:36:08.819] [LOG]    Initializing new module helper ...
        [2020-07-05 17:36:08.820] [LOG]    Module helper loaded: MMM-PilotWX
        [2020-07-05 17:36:08.822] [LOG]    No helper found for module: MMM-DigClock.
        [2020-07-05 17:36:08.828] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'cheerio'
        Require stack:
        - /home/pi/MagicMirror/modules/MMM-DailyDilbert/node_helper.js
        [2020-07-05 17:36:08.830] [LOG]    Loading module helpers ...
        [2020-07-05 17:36:08.831] [LOG]    No helper found for module: MMM-Carousel.
        [2020-07-05 17:36:08.833] [LOG]    Initializing new module helper ...
        [2020-07-05 17:36:08.835] [LOG]    Module helper loaded: MMM-WatchDog
        [2020-07-05 17:36:08.836] [LOG]    Initializing new module helper ...
        [2020-07-05 17:36:08.837] [LOG]    Module helper loaded: MMM-SystemStats
        [2020-07-05 17:36:08.838] [LOG]    Initializing new module helper ...
        [2020-07-05 17:36:08.839] [LOG]    Module helper loaded: MMM-PilotWX
        [2020-07-05 17:36:08.840] [LOG]    No helper found for module: MMM-DigClock.
        [2020-07-05 17:36:08.843] [ERROR]  App threw an error during load
        [2020-07-05 17:36:08.845] [ERROR]  Error: Cannot find module 'cheerio'
        Require stack:
            at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
            at Function.Module._load (internal/modules/cjs/loader.js:531:27)
            at Module.require (internal/modules/cjs/loader.js:685:19)
            at require (internal/modules/cjs/helpers.js:16:16)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DailyDilbert/node_helper.js:3:15)
            at Module._compile (internal/modules/cjs/loader.js:786:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
            at Module.load (internal/modules/cjs/loader.js:645:32)
        [2020-07-05 17:36:08.848] [ERROR]  Whoops! There was an uncaught exception...
        [2020-07-05 17:36:08.849] [ERROR]  Error: Cannot find module 'cheerio'
        Require stack:
            at Module.load (internal/modules/cjs/loader.js:645:32) {
          code: 'MODULE_NOT_FOUND',
          requireStack: [
            '/home/pi/MagicMirror/modules/MMM-DailyDilbert/node_helper.js',
            '/home/pi/MagicMirror/js/app.js',
            '/home/pi/MagicMirror/js/electron.js',
            '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
            undefined
        [2020-07-05 17:36:08.860] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-07-05 17:36:08.861] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        [2020-07-05 17:36:09.030] [LOG]    Launching application.
        and running npm run config:check gives:
        > magicmirror@2.12.0 config:check /home/pi/MagicMirror
        > node js/check_config.js
        [2020-07-05 17:37:18.657] [INFO]   Checking file...  /home/pi/MagicMirror/config/config.js
        [2020-07-05 17:37:18.948] [LOG]    Line 1 col 1 Definition for rule 'prettier/prettier' was not found.
        /home/pi/MagicMirror/js/check_config.js:66
        			throw new Error("Wrong syntax in config file!");
        Error: Wrong syntax in config file!
            at /home/pi/MagicMirror/js/check_config.js:66:10
            at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! magicmirror@2.12.0 config:check: `node js/check_config.js`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.12.0 config:check script.
        npm ERR!     /home/pi/.npm/_logs/2020-07-05T15_37_18_992Z-debug.log
        and that log shows:
        1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'config:check' ]
        2 info using npm@6.14.4
        3 info using node@v10.20.1
        4 verbose run-script [ 'preconfig:check', 'config:check', 'postconfig:check' ]
        5 info lifecycle magicmirror@2.12.0~preconfig:check: magicmirror@2.12.0
        6 info lifecycle magicmirror@2.12.0~config:check: magicmirror@2.12.0
        7 verbose lifecycle magicmirror@2.12.0~config:check: unsafe-perm in lifecycle true
        8 verbose lifecycle magicmirror@2.12.0~config:check: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle$
        9 verbose lifecycle magicmirror@2.12.0~config:check: CWD: /home/pi/MagicMirror
        10 silly lifecycle magicmirror@2.12.0~config:check: Args: [ '-c', 'node js/check_config.js' ]
        11 silly lifecycle magicmirror@2.12.0~config:check: Returned: code: 1  signal: null
        12 info lifecycle magicmirror@2.12.0~config:check: Failed to exec config:check script
        13 verbose stack Error: magicmirror@2.12.0 config:check: `node js/check_config.js`
        13 verbose stack Exit status 1
        13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js$
        13 verbose stack     at EventEmitter.emit (events.js:198:13)
        13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spaw$
        13 verbose stack     at ChildProcess.emit (events.js:198:13)
        13 verbose stack     at maybeClose (internal/child_process.js:982:16)
        13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        14 verbose pkgid magicmirror@2.12.0
        15 verbose cwd /home/pi/MagicMirror
        16 verbose Linux 4.19.97-v7+
        17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "config:check"
        18 verbose node v10.20.1
        19 verbose npm  v6.14.4
        20 error code ELIFECYCLE
        21 error errno 1
        22 error magicmirror@2.12.0 config:check: `node js/check_config.js`
        22 error Exit status 1
        23 error Failed at the magicmirror@2.12.0 config:check script.
        23 error This is probably not a problem with npm. There is likely additional logging output above.
        24 verbose exit [ 1, true ]
        I’m out of ideas - can anybody help please?
        TIA,
        Chris
          sdetweil @chrisparker
          @chrisparker somebody is missing one of their dependencies
          do
          cd ~/MagicMirror
          npm install cheerio
          then try to start
          chrisparkerC 1 Reply Last reply Reply Quote 0
            sdetweil @Cyric
            @Cyric 2 days, I think they pushed a fix for that, do
            cd ~/MagicMirror
            git checkout develop
            git pull
            then restart mm
            C 1 Reply Last reply Reply Quote 1
            • C Offline
              Cyric @sdetweil
              @sdetweil So i tried that and it said “error: Your local changes to the following files would be overwritten by checkout:
              package-lock.json
              Please commit your changes or stash them before you switch branches.
              Aborting”
              but i havent edited the package-lock.json, so i don’t know why its saying that. Since the problems started when i ran the update, i’m nervous to mess with anything again.
                sdetweil @Cyric
                @Cyric package-lock. Jason is shipped as part of the project, AND updated every time one does npm install, so it will always present a problem.
                just erase it, and then git pull again
                • C Offline
                  Cyric @sdetweil
                  @sdetweil So i should delete the package-lock.json file, then run
                  cd ~/MagicMirror
                  git pull
                  and then restart mm?
                    sdetweil @Cyric
                    @Cyric yes
                    • C Offline
                      Cyric
                      awesome, that worked.
                      Thank you!
                        @sdetweil Thanks. Turned out there were several dependencies missing that are needed by the Dilbert module.
                        I’ve now reloaded my config files and all is well - thanks!
                        • 4 / 4
