    Wich controller board for my lcd screen?
    displayhardware
    11 Posts 2 Posters 8.4k Views 2 Watching
    • K Offline
      Komiek
      Hello!
      Dus anyone know Which controller Board to buy for my display?
      I got my display out of my old Sony PCG-5J5M laptop.
      alt text
      Regards!
      • K Offline
        Komiek
        This is the back of the display I took Out Of My Old Sony laptop:
        https://www.dropbox.com/s/rvazpvuf0ejlf3j/IMG_20200629_114035.jpg?dl=0
          MadScientist
          Here is the datasheet of your LCD panel. It’s a single channel 6-bit LCD which runs at 3.3V.
          That means you can use any universal LCD controller board with LVDS interface. Back when I build my mirror I bought the V56 boards. The T53.03 is a newer version I think. The advantage is that you can flash the firmware via USB and it has a TV tuner. The disadvantage is that it’s not powering back on after it went into standby mode (- can be solved with a relay if wanted).
          If you want it super simple and VGA is enough for you, you can go with a MT561-B. Those things are tiny and dirt cheap.
          K 2 Replies Last reply Reply Quote 0
          • K Offline
            Komiek @MadScientist
            @MadScientist
            Thank you!
            I would like a controller board with HDMI.
            is this one fine:
            https://nl-m.banggood.com/T_V53_03-Universal-LCD-LED-TV-Controller-Driver-Board-TV-or-PC-or-VGA-or-HDMI-or-USB+7-Key-Button+2ch-6bit-30pins-LVDS-Cable+1-Lamp-Inverter-p-1401873.html
            It is t53.03.
            • K Offline
              @MadScientist
              🤔, this is not fine either…
              So Maybe there is an alternative? Or I have to buy a vga tot HDMI convertor 🤔
                MadScientist
                The board you’ve linked is correct.
                A VGA to HDMI will work just fine. A VGA board with inverter, cables, and keypad should be around 3.50€ to 5€ and a VGA-HDMI adapter around 2.50€
                • K Offline
                  @MadScientist
                  Thanks Again!
                  I’ll go for the MT561-B
                  Will This one be fine?:
                  https://nl-m.banggood.com/LCD-Controller-Board-40P-8-bit-HD-DVI-VGA-Audio-PC-Module-Kit-For-B156XW02-15_6-Inch-Display-p-1045418.html?gmcCountry=NL&currency=EUR&cur_warehouse=CN&createTmp=1
                  How will the LCD display get its power? My LCD display has a two pole power plug 🤔
                    MadScientist
                    That controller board is for a AUO B156XW02 panel. It’s also 1-CH 6-bit but with LED backlight. In principle it should work but it runs a higher resolution.(*) It’s best to order these boards specifically for the panel you have.
                    I was referring to this kind of controller board plus VGA-HDMI adapter (only an example!). You configure those boards via jumpers.
                    • That shouldn’t be a problem. You just have to configure the resolution within your operating system yourself.
                    • K Offline
                      @MadScientist
                      I’ll go for the aliexpress controller board. Only thing that worries me is that I don’t see a power cable. How will my display get power?
                      And where does the controller board itself get its power from?
                      Do I have to buy additional power cables at the local electronic hardware store?
                        MadScientist
                        You see the red 6-pin connector? You apply 5V to them.
