    [DEBUG] Default Weather Module with OpenWeatherMap One Call API
    openweathermaponecallapidefaultweathermodulehourlycurrentdaily
    7 Posts 5 Posters 4.5k Views 5 Watching
    • L
      lost
      Hey all, I’m trying to get a basic implementation of OpenWeatherMap’s One Call API working inside the default Weather module, mainly so I can get hourly weather data, but I’m running into some problems.
      Link to Branch.
      Files with changes inside the modules/default/weather/ directory:
      • weather.js
      • weatherprovider.js
      • providers/openweathermap.js
      • wdatahourly.njk (renamed from wdataHourly.njk, Windows is being stupid)
      Sample Module Configuration: (all included config parameters are required for the moment)
      module: "weather",
      position: "bottom_center",
      header: "Hourly Forecast",
      	type: "wDataHourly", // wDataCurrent and wDataDaily theoretically work but currently don't have .njk files
      	apiKey: "OPENWEATHERMAPAPIKEY", // your OpenWeatherMap API key
      	lat: 40.7128, // your latitude
      	lon: -74.0060, // your longitude
      	weatherEndpoint: "/onecall",
      	maxNumberOfEntries: 12
      The module just stays at “Loading …” indefinitely. The console tab in the menu that shows up after I hit Ctrl+Shift+I doesn’t report any errors or warnings, so I’m not sure what’s causing the readings to not show up.
      Any advice is appreciated since I haven’t worked too much with in the past with JavaScript, Node.js, etc. so I’m not sure what the proper way to troubleshoot problems is.
      *edit: The module seems to be loaded just fine and the weather provider gets initialized as expected. Still not sure what the problem could be.
      console log 01
      console log 02
      • L
        lost
        minor correction, the maxNumberOfEntries config parameter is wrong, it should be maxEntries instead:
        module: "weather",
        	maxEntries: 12
        • L
          lost
          Got it working! I think I’ll just avoid dot notation from now on…
          Repo is linked below. If anyone’s looking to use this, OpenWeatherMap’s One Call API asks for latitude and longitude instead of a location or location ID. But in return, you can get not only current and daily (max 7 days) forecasts, but also hourly forecasts (max 48 hours).
          All original functionality of the module should remain intact.
          Sample Module Configurations:
          	module: "weather",
          	position: "bottom_left",
          	header: "Current Forecast",
          		type: "wDataCurrent",
          		initialLoadDelay: 0,
          	module: "weather",
          		initialLoadDelay: 2500,
          		maxEntries: 32, // max 48, set by OWM One Call API
          		showPrecipitationAmount: true
          	module: "weather",
          	position: "bottom_right",
          	header: "Daily Forecast",
          		type: "wDataDaily",
          		initialLoadDelay: 5000,
          		maxEntries: 7, // max 7, set by OWM One Call API
          		colored: true,
          Sample MagicMirror Output:
          Current, Hourly, and Daily Forecasts using the OpenWeatherMap One Call API
          Link to Branch
          Not making a pull request yet since I don’t know how the default Weather module is meant to be designed.
          • Feedy88F
            Feedy88
            Hey @lost,
            thanks for creating this. I am currently building my first mirror and have issues with the weather module from the master (only showing “Loading”) and hence wanted to try yours, as I am looking for hourly data anyways.
            However, I am a total noob to git and stuff, so I don’t know how to install your branch. Could you help me out here? Much appreciated in advance.
            • J
              julien-vancouver
              Thanks for your work, ive tried using your config above and have run into two issues.
              module: “weather”,
              position: “bottom_left”,
              header: “Current Forecast”,
              weatherProvider: “openweathermap”,
              weatherEndpoint: “/onecall”,
              type: “wDataCurrent”,
              apiKey: “xxxxxxx”, // your OpenWeatherMap API key
              1. using the type: “wDataCurrent” results in “UNDEFINED”
                however if I change variable to Current, I then run into issue 2.
              2. loading. Similar to your original post, my screen remains forever loading and doesn’t load the retrieved values.
              any other thoughts or tips & tricks on how to resolve?
              • I
                icemanmw
                i had the same problem and changed type: “wDataCurrent”, to type: “current”, because in the folder /home/pi/MagicMirror/modules/default/weather i found the files
                current.njk
                hourly.njk
                forecast.njk
                now is runs
                • D
                  dangarlen @icemanmw
                  This post is deleted!
