    Transit module stopped working
    29 Posts 5 Posters 7.6k Views 5 Watching
      sdetweil @elliob
      @elliob it was in the pm2 log in the 1st post of this topic
      • N Offline
        nipper2000h @elliob
        @elliob I’m using pm2 to start MM so from the root directory:
        pm2 logs mm
          sdetweil @nipper2000h
          @nipper2000h the logs are stored in the users .pm2 folder. doesn’t matter where I issue the pm2 commands
          • E Offline
            Elaniobro
            The module is getting the data, but its not updating with the this.updateDom method. I am not sure if this was deprecated or not. Looking into it.
              sdetweil @Elaniobro
              @Elaniobro how does it use this.updateDom()
              • E Offline
                Elaniobro @sdetweil
                @sdetweil Its called in the socketNotificationReceived() here:
                https://github.com/Elaniobro/MMM-nyc-transit/blob/master/MMM-nyc-transit.js#L358-L360
                  sdetweil @Elaniobro
                  @Elaniobro where is self set.? and fadeSpeed?
                  • E Offline
                    Elaniobro @sdetweil
                    @sdetweil They aren’t, they can be removed. Issue I am seeing is the payload is not populated indo the getDom()
                    I am setting this.result = payload which on intitial load/start of the module is undefined, which is expected, since the API promise has not been fulfilled. Later on, the socketNotificationReceived() recieves a payload which is set to this.result but in the getDom() var data = this.result is never updated.
                    I am unsure of where/what caused this breakdown, as last time I touched the code was Apr 30. This is leading me to believe something changed in Core, but I am unaware of what that might be.
                      sdetweil @Elaniobro
                      @Elaniobro are u debugging w the developers window?
                      you can walk thru the code as it executes
                      ctrl-shift-i and select the sources tab, use the tree on the left to find your module, and it’s source
                      then click the left edge of a line of code u want to examine, and a stop will be added.
                      usually a problem like this is because the ‘this.’ pointer doesn’t point where u think it does.
                      sorry, I am in hospital for a few more days and cannot debug from here
                      • E Offline
                        Elaniobro @sdetweil
                        @sdetweil Thank you for your feedback. I am/was already debugging in the manner you mentioned. I was able to resolve the bug(s), but now I am still not seeing any data. My best guess is somewhere along the fetch of the data something changed or broke. The application is returning data, but the response is empty.
                        payload = [{ downTown: [] }, { upTown: [] }]
                        For some reason, just not getting any data :/
                        I am still digging in.
                        • 2 / 3
