    weatherforecast showing only two days.
    31 Posts 22 Posters 16.0k Views 21 Watching
    • E Offline
      erik.voznak
      Hey Guys,
      After latest update of MagicMirror (v2.12.0) module weatherforecast is showing only two day forecast no matter what I configure in “maxNumberOfDays” option.
      Can you please help me? I tried to search for any errors in logs regarding this module or api response, but I wasn`t lucky.
      Below is my config for this module and screenshot to show that it shows only two days.
      module: “weatherforecast”,
      position: “top_right”,
      header: “Predpoveď počasia”,
      lang: “sk”,
      locationID: “3060972”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      appid: “6ba6364f776c4927bf2145c8582e8c3c”,
      maxNumberOfDays: “7”,
      colored: “true”,
      fade: “false”,
      fadePoint: “1”,
      showRainAmount: “true”,
      scale: “true”,
      alt text
      • lavolp3L Offline
        lavolp3 Module Developer @erik.voznak
        @erik-voznak have you tried
        maxNumberOfDays: 7
        needs to be a number instead of a string.
        fadePoint as well.
        You need to be careful with the format of the values.
        Look into the readme what format is expected.
        https://docs.magicmirror.builders/modules/weatherforecast.html#configuration-options
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • H Offline
          heeroy
          I have the same problem Tryed to change in module config to change numbers of days,tried in weatherforecast.js,always the same Anybody knows how to solve problem?
          • E Offline
            erik.voznak @lavolp3
            @lavolp3
            tried right now and no change.
            maxNumberOfDays: 7,
            colored: “true”,
            fade: “false”,
            fadePoint: 1,
            lavolp3L 1 Reply Last reply Reply Quote -1
            • lavolp3L Offline
              @erik-voznak @heeroy
              Have you updated?
              Seems to be fixed in latest release from this morning
              https://github.com/MichMich/MagicMirror/issues/2018
              https://forum.magicmirror.builders/topic/13182/v2-12-0
              • E Offline
                @lavolp3
                I did update this morning and issue started after update…
                [2020-07-02 13:37:30.638] [LOG] Starting MagicMirror: v2.12.0
                [2020-07-02 13:37:30.651] [LOG] Loading config …
                • ? Offline
                  [[global:former-user]]
                  This post is deleted!
                  • O Offline
                    oemel09
                    Had the same issue after the update.
                    The problem is, that the weatherforecast first checks the paid version of the API to get full day forecasts (https://api.openweathermap.org/data/2.5/forecast/daily?id=xxx&cnt=7&units=metric&lang=de&APPID=xxx)
                    This results in a 401 for me because I’m using a free API token.
                    Next the weatherforecast module falls back using the 5 day / 3 hour Forecast API by using the same cnt value (https://api.openweathermap.org/data/2.5/forecast?id=xxx&cnt=7&units=metric&lang=de&APPID=xxx). Here the value 7 for cnt returns 7 entries, that’s why there is only a two day forecast.
                    I’ll try to write a fix.
                    In the meantime as a quick fix you can change line 297 of weatherforecast.js from:
                    params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 17 ? 7 : this.config.maxNumberOfDays);
                    to
                    params += "&cnt=" + (this.config.maxNumberOfDays < 1 || this.config.maxNumberOfDays > 5 ? 40 : this.config.maxNumberOfDays * 8);
                    Remeber the fallback API provides only a 5 day forecast, that’s why maxNumberOfDays is limited to 5.
                    E T D W H 6 Replies Last reply Reply Quote 9
                    • E Offline
                      erik.voznak @oemel09
                      @hango, yeah I know I shouldn`t but I am using free API so… but anyway I will change appid.
                      @oemel09, Many thanks man, your fix helped and finally it is working as intended.
                      alt text
                      • C Offline
                        castletonroad
                        This fix worked for me too, so thanks very much.
                        Also, showRainAmount: “false” does not work - i still see mm rain forecast against each day.
                        This is all a little disappointing as up until the recent upgrade, ‘weatherforecast’ was working perfectly.
                        And BTW, in trying to resolve the problem with ‘weatherforecast’, before coming to this thread, I also tried the ‘weather’ module, the replacement for ‘currentweather’ and ‘weatherforecast’. I couldn’t get that to work in ‘forecast’ mode, only in ‘current’ mode. The module just displays ‘Loading…’.
                        Ho-hum…
                        S kayakbabeK 2 Replies Last reply Reply Quote 1
                          sdetweil @castletonroad
                          @castletonroad
                          how about no quotes
                          showRainAmount: false,
                          values that are all numbers, or true and false do not need quotes
                          everything else does need quotes
                          C 1 Reply Last reply Reply Quote 1
                          • C Offline
                            castletonroad @sdetweil
                            @sdetweil Great, that sorted things nicely!
                            How ever did I miss that in the config instructions… :astonished_face:
                            • T Offline
                              tenyo @oemel09
                              @oemel09 Thanks a lot!
                                dh1201
                                Thanks for the ‘quick fix’ - Works perfectly.
                                  ArthurOff
                                  Will this be fixed in the next update or do we need to adjust manually?
                                    sdetweil @ArthurOff
                                    @ArthurOff next release (3 months), OR you can use the develop branch now til then, 2.12+.
                                      ArthurOff @sdetweil
                                      @sdetweil haha, got it!
                                        DavidCarreira @oemel09
                                        @oemel09 Thanks, your fix is working fine!
                                        • F Offline
                                          FatTony123
                                          @oemel09… yep, just can confirm. This fix works like charm ;-)
                                          • W Offline
                                            Wilfried @oemel09
                                            @oemel09 Perfect. Thanks for the workaround.
