    MMM-GoogleAssistant problem with .asoundrc
    12 Posts 3 Posters 2.3k Views 3 Watching
      RIKKO14
      Hello,
      I am trying to install MMM-GoogleAssistant from: https: //www.magicmirrorcentral.com/get-google-assistant-magic-mirror/ because I did not succeed from the official link: https: // github.com/gauravsacc/MMM-GoogleAssistant.
      I block with the .asoundrc and I have a doubt with the node_helper.js
      This is my arecord -land my aplay -l
      pi@raspberrypi:~ $ arecord -l
      **** Liste des Périphériques Matériels CAPTURE ****
      carte 1: USB [WordForum USB], périphérique 0: USB Audio [USB Audio]
        Sous-périphériques: 1/1
        Sous-périphérique #0: subdevice #0
      pi@raspberrypi:~ $ aplay -l
      **** Liste des Périphériques Matériels PLAYBACK ****
      carte 0: b1 [bcm2835 HDMI 1], périphérique 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
        Sous-périphériques: 4/4
        Sous-périphérique #1: subdevice #1
        Sous-périphérique #2: subdevice #2
        Sous-périphérique #3: subdevice #3
      carte 2: Headphones [bcm2835 Headphones], périphérique 0: bcm2835 Headphones [bcm2835 Headphones]
      pi@raspberrypi:~ $
      If I understand correctly, my microphone is card 2 and device 0 and my headphones are card 1 and device 0, is that correct ?
      I wanted to create a .asoundrc in /home/pi but apparently I had a hidden file. Whenever I open the .asoundrc file here is what is written :
      pcm.!default {
        type asym
        capture.pcm "mic"
        playback.pcm "speaker"
      pcm.mic {
        type plug
        slave {
          pcm "hw:<2>,<0>"
      pcm.speaker {
        type plug
        slave {
          pcm "hw:<1>,<0>"
      pcm.output {
      	type hw
      	card 2
      ctl.!default {
      	type hw
      	card 2
      as explained here : https://developers.google.com/assistant/sdk/guides/library/python/embed/audio I copy in .asoundrc file like this :
      pcm.!default {
        type asym
        capture.pcm "mic"
      pcm.mic {
        type plug
        slave {
          pcm "hw:<2>,<0>"
      pcm.speaker {
        type plug
        slave {
          pcm "hw:<1>,<0>"
      but when i type the commands speaker-test -t wav, arecord --format=S16_LE --duration=5 --rate=16000 --file-type=raw out.raw et aplay --format=S16_LE --rate=16000 out.raw
      the terminal display :
      pi@raspberrypi:~ $ speaker-test -t wav
      speaker-test 1.1.8
      Le périphérique de lecture est default
      Les paramètres du flux sont 48000Hz, S16_LE, 1 canaux
      fichier(s) WAV
      ALSA lib conf.c:4926:(parse_args) Parameter DEV must be an integer
      ALSA lib conf.c:5031:(snd_config_expand) Parse arguments error: Argument invalide
      ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM hw:<1>,<0>
      Erreur d'ouverture à la lecture: -22,Argument invalide
      pi@raspberrypi:~ $ arecord --format=S16_LE --duration=5 --rate=16000 --file-type=raw out.raw
      ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM hw:<2>,<0>
      arecord: main:828: erreur à l'ouverture audio: Argument invalide
      pi@raspberrypi:~ $ aplay --format=S16_LE --rate=16000 out.raw
      aplay: main:828: erreur à l'ouverture audio: Argument invalide
      pi@raspberrypi:~ $
      and when i open again the .asoundrc file the therminal display :
      pcm.!default {
        type asym
        capture.pcm "mic"
      pcm.mic {
        type plug
        slave {
          pcm "hw:<2>,<0>"
      pcm.speaker {
        type plug
        slave {
          pcm "hw:<1>,<0>"
      pcm.output {
      	type hw
      	card 2
      ctl.!default {
      	type hw
      	card 2
      WHAT IS THE PROBLEM ?
      also, as explained here [https://www.magicmirrorcentral.com/get-google-assistant-magic-mirror/]
      i copied my keys i copied my keys in the following files node_helper.js, MMM-GoogleAssistant.js, pi/assistant.py are they well completed ? because I have a doubt about the node_helper.js ?
      my node_helper.js :
      /* Magic Mirror
       * Module: MMM-GA
       * By Gaurav
      'use strict';
      var NodeHelper = require("node_helper");
      var PubNub = require('pubnub');
        initGoogleAssistant: function(payload) {
          var self = this;
          this.pubnub = new PubNub({
            //publishKey,subscribeKey
            pub-c-387c2c32-ca85-4491-b6b3-7a38708ba39c, sub-c-286db504-bcfd-11ea-9208-3200fd38a8e3
            publishKey: payload.publishKey,
            subscribeKey: payload.subscribeKey,
          this.pubnub.addListener({
            status: function(statusEvent) {
              if (statusEvent.category === "PNConnectedCategory") {
                //publishSampleMessage();
            message: function(message) {
              if (message.message === 'ON_CONVERSATION_TURN_STARTED') {
                self.sendSocketNotification('ON_CONVERSATION_TURN_STARTED', null);
              } else if (message.message === 'ON_CONVERSATION_TURN_FINISHED') {
                self.sendSocketNotification('ON_CONVERSATION_TURN_FINISHED', null);
              } else if (message.message.includes('ON_RECOGNIZING_SPEECH_FINISHED')) {
                var query = message.message.split(":");
                self.sendSocketNotification('ON_RECOGNIZING_SPEECH_FINISHED', query[1]);
            presence: function(presenceEvent) {
              // handle presence
          this.pubnub.subscribe({
            channels: ['magicmirror']
          if (notification === 'INIT') {
            console.log("now initializing assistant");
            this.initGoogleAssistant(payload);
      My MMM-GoogleAssistant.js :
      /* Magic Mirror
       * Module: MMM-GoogleAssistant
       * By Gaurav
      Module.register("MMM-GoogleAssistant", {
        // Module config defaults.
        defaults: {
          header: "Google Asistant",
          maxWidth: "100%",
          publishKey: 'pub-c-387c2c32-ca85-4491-b6b3-7a38708ba39c',
          subscribeKey: 'sub-c-286db504-bcfd-11ea-9208-3200fd38a8e3',
          updateDelay: 500
        // Define start sequence.
        start: function() {
          Log.info('Starting module: Google Assistant Now');
          var self = this;
          this.assistantActive = false;
          this.processing = false;
          this.userQuery = null;
          //this.sendSocketNotification('INIT', 'handshake');
          this.sendSocketNotification('INIT', self.config);
        getDom: function() {
          Log.log('Updating DOM for GA');
          if (this.assistantActive == true) {
            if (this.processing == true) {
              wrapper.innerHTML = "<img src='MMM-GoogleAssistant/assistant_active.png'></img><br/>" + this.userQuery;
            } else {
              wrapper.innerHTML = "<img src='MMM-GoogleAssistant/assistant_active.png'></img>";
          } else {
            wrapper.innerHTML = "<img src='MMM-GoogleAssistant/assistant_inactive.png'></img>";
          return wrapper;
          var self = this;
          delay = self.config.updateDelay;
          if (notification == 'ON_CONVERSATION_TURN_STARTED') {
            this.assistantActive = true;
            delay = 0;
          } else if (notification == 'ON_CONVERSATION_TURN_FINISHED') {
          } else if (notification == 'ON_RECOGNIZING_SPEECH_FINISHED') {
            this.userQuery = payload;
            this.processing = true;
            delay = 0;
          this.updateDom(delay);
      My pi/assistant.py :
      #!/usr/bin/env python
      # Copyright (C) 2017 Google Inc.
      # Licensed under the Apache License, Version 2.0 (the "License");
      # you may not use this file except in compliance with the License.
      # You may obtain a copy of the License at
      #     http://www.apache.org/licenses/LICENSE-2.0
      # Unless required by applicable law or agreed to in writing, software
      # distributed under the License is distributed on an "AS IS" BASIS,
      # WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
      # See the License for the specific language governing permissions and
      # limitations under the License.
      from __future__ import print_function
      import argparse
      import os.path
      import json
      import os
      import google.oauth2.credentials
      #import RPi.GPIO as GPIO
      from google.assistant.library import Assistant
      from google.assistant.library.event import EventType
      from google.assistant.library.file_helpers import existing_file
      from pubnub.callbacks import SubscribeCallback
      from pubnub.enums import PNStatusCategory
      from pubnub.pnconfiguration import PNConfiguration
      from pubnub.enums import PNReconnectionPolicy
      from pubnub.pubnub import PubNub
      #GPIO.setmode(GPIO.BCM)
      #GPIO.setup(25, GPIO.OUT)
      global pubnub
      #Pubnub Communication
      def my_publish_callback(envelope, status):
          # Check whether request successfully completed or not
          if not status.is_error():
              pass  # Message successfully published to specified channel.
          else:
              pass  # Handle message publish error. Check 'category' property to find out possible issue
              # because of which request did fail.
              # Request can be resent using: [status retry];
      class MySubscribeCallback(SubscribeCallback):
          def presence(self, pubnub, presence):
              pass  # handle incoming presence data
          def status(self, pubnub, status):
              if status.category == PNStatusCategory.PNUnexpectedDisconnectCategory:
                  pass  # This event happens when radio / connectivity is lost
              elif status.category == PNStatusCategory.PNConnectedCategory:
                  # Connect event. You can do stuff like publish, and know you'll get it.
                  # Or just use the connected event to confirm you are subscribed for
                  # UI / internal notifications, etc
                  pubnub.publish().channel("magicmirror").message("hello from python!!").async(my_publish_callback)
              elif status.category == PNStatusCategory.PNReconnectedCategory:
                  pass
                  # Happens as part of our regular operation. This event happens when
                  # radio / connectivity is lost, then regained.
              elif status.category == PNStatusCategory.PNDecryptionErrorCategory:
                  pass
                  # Handle message decryption error. Probably client configured to
                  # encrypt messages and on live data feed it received plain text.
          def message(self, pubnub, message):
              print (message.message)
              # pass  # Handle new message stored in message.message
      def init_pubnub():
          global pubnub
          pnconfig = PNConfiguration()
          pnconfig.subscribe_key = 'sub-c-286db504-bcfd-11ea-9208-3200fd38a8e3'
          pnconfig.publish_key = 'pub-c-387c2c32-ca85-4491-b6b3-7a38708ba39c'
          pnconfig.reconnect_policy = PNReconnectionPolicy.LINEAR
          pubnub = PubNub(pnconfig)
          pubnub.add_listener(MySubscribeCallback())
          pubnub.subscribe().channels('magicmirror').execute()
          print ('pubnub subscription completed')
      #googleassistant events processing
      def process_event(event):
          """Pretty prints events.
          Prints all events that occur with two spaces between each new
          conversation and a single space between turns of a conversation.
          Args:
              event(event.Event): The current event to process.
          if event.type == EventType.ON_CONVERSATION_TURN_STARTED:
              os.system("aplay start.wav")
              pubnub.publish().channel("magicmirror").message("ON_CONVERSATION_TURN_STARTED").async(my_publish_callback)
              print()
              #GPIO.output(25,True)
          if (event.type == EventType.ON_CONVERSATION_TURN_FINISHED and
                  event.args and not event.args['with_follow_on_turn']):
              pubnub.publish().channel("magicmirror").message("ON_CONVERSATION_TURN_FINISHED").async(my_publish_callback)
              print()
              #GPIO.output(25,False)
          if event.type == EventType.ON_RECOGNIZING_SPEECH_FINISHED:
              pubnub.publish().channel("magicmirror").message("ON_RECOGNIZING_SPEECH_FINISHED : "+event.args['text']).async(my_publish_callback)
              print()
      def init_googleAssistant():
          parser = argparse.ArgumentParser(
              formatter_class=argparse.RawTextHelpFormatter)
          parser.add_argument('--credentials', type=existing_file,
                              metavar='OAUTH2_CREDENTIALS_FILE',
                              default=os.path.join(
                                  os.path.expanduser('/home/pi/.config'),
                                  'google-oauthlib-tool',
                                  'credentials.json'
                              help='Path to store and read OAuth2 credentials')
          args = parser.parse_args()
          with open(args.credentials, 'r') as f:
              credentials = google.oauth2.credentials.Credentials(token=None,
        **json.load(f))
          with Assistant(credentials,"magic-mirror-device-id") as assistant:
              for event in assistant.start():
      def main():
          init_pubnub()
      if __name__ == '__main__':
          main()
      Finally, if I try to open with VLC the start.wav file in /home/pi/MagicMirror/modules/MMM-GoogleAssistant/pi, here is what is displayed, is there a link ?
      La sortie audio a échoué:
      Le périphérique audio « default » ne peut pas être utilisé :
      Argument invalide.
      Argument invalide.
        sdetweil @RIKKO14
        @RIKKO14 headphones is things u put over your ears to hear sound.
        arecord -l showed one device for capturing sound (a microphone) at card 0, device 0
        aplay -l showed two devices that can make sound.
          RIKKO14
          @sdeweil sorry but i don’t anderstand…
          you say :
          But I see with the arecord-l :
          so my microphone should be on card 1, device 0, no ?
          So :
          HDMI free in card 0, device 0 (i don’t use it)
          and my headphones in card 2, device 0,
          I would have mistakenly switched the 2 ?
          And why when i open the .asoundrc file after writing what’s here : https://developers.google.com/assistant/sdk/guides/library/python/embed/audio the file is different after writting the command speaker-test -t wavand arecord --format=S16_LE --duration=5 --rate=16000 --file-type=raw out.raw
          Do you know if i wrote in my my node_helper.js, my My MMM-GoogleAssistant.jsand my pi/assistant.py are good ?
          And finally, does the procedure described in Introduction to the Google Assistant Library (https://developers.google.com/assistant/sdk/guides/library/python) still work because I just read at the top of the page ( I hadn’t paid attention): “Warning: The Google Assistant Library for Python is deprecated as of June 28th, 2019. Use the Google Assistant Service instead.”, and return to the Introduction to "the Google Assistant Service page "(https://developers.google.com/assistant/sdk/guides/service/python) so should I rather follow the procedure described in the Google Assistant Service and then continue step 3 of this page: https://www.magicmirrorcentral.com/get-google-assistant-magic-mirror/ ?
            sdetweil @RIKKO14
            @RIKKO14 sorry, got the mic card wrong
            you are mixing instructions.
            I don’t care what Google doc you read.
            MMM-GoogleAssistant doc is the only doc that matters.
            and NEVER change the module source code files. change config.js only.
            @Bugsounet will have to help on his module
              RIKKO14
              So my mic card is card 0, device 0 ?
              and my 3.5 jacks speakers is card 2, device 0 ?
              is that correct ?
              The MMM-GoogleAssistant of @Bugsounet doen’t work, at the end of the page it’s write : “By terms of Google Assistant SDK, You are not allowed to use or provide this module for commercial purpose.”
              the only MMM-GoogleAssistant which works is the gauravsacc/MMM-GoogleAssistant, but i don’t anderstand what to do in the part :
              “Register your GA device
              Register your GA device using the register-tool available here and replace the magic-mirror-device-id in the assistant.py with your unique device id https://developers.google.com/assistant/sdk/reference/device-registration/device-tool”,
              I dont’ anderstand the open page : “Registration Tool Help” in the link.
              and finally, the link to Setup Google Assistant on Pi return to the same google page for Introduction to the Google Assistant Library and it’s wrote in red at the top of the page “Warning: The Google Assistant Library for Python is deprecated as of June 28th, 2019. Use the Google Assistant Service instead.”
              can you just confirm me my number of card and device for my mic and my headphones according to you ? Thank you
                sdetweil @RIKKO14
                @RIKKO14 we are not selling mm, so not commercial use. you are adding a module to your personal system ( unless YOU intend to sell it)
                I don’t know about the older module. only that @Bugsounet has done a lot of work to get it going
                • ? Offline
                  A Former User
                  @RIKKO14 said in MMM-GoogleAssistant problem with .asoundrc:
                  je ne savais pas que je fesais des module qui ne fonctionnait pas ;)
                  Merci toutefois de me l’apprendre :)
                  cela veux simplement dire qu’il n’est pas permis d’utiliser ce module a des fin commerciale
                    RIKKO14
                    @Bugsounet TOUTES MES PLATES EXCUSES !!! J’avais donc mal compris, vraiment désolé…
                    I continue in English because it is required here (and that you will understand that I all pages and tutorials read with google translate …):
                    But then why in the page of your MMM-GoogleAssistant there is only the link git@github.com: bugsounet / MMM-GoogleAssistant.git and not all the description to install MMM-GoogleAssistant ?
                    • ? Offline
                      A Former User
                      It’s on wiki page …
                      just read ;)
                      It’s write on Readme page
                        RIKKO14
                        Great, thank you !
                        So can you confirm me the card and device for my mic and headphones ?
                        • ? Offline
                          A Former User
                          It’s depend of you device.
                          It’s the job of micConfig check at the end of install
                          Attention:
                          you share some personal data in your config.
                          You can have some takeover
                          Don’t forget … it’s a forum ! everyone read this !
                            RIKKO14
                            I tried to edit my 1st post but I can’t: “You are only allowed to edit posts for 3600 second (s) after posting”.
                            in the case I published which is:
                            pi@raspberrypi:~ $
                            my mic in on card 1, device 0 because " Liste des Périphériques Matériels CAPTURE", and my 3.5 jack headphone is on card 2, device 0 because " Liste des Périphériques Matériels PLAYBACK" , and in card 0, device 0 it’s HDMI.
                            is it correct ?
