    MMM-GoogleAssistant not running
    55 Posts 5 Posters 23.4k Views 5 Watching
    • W
      wirdman
      hello i try to install many time the google asssistant but is not apear in my magic mirror but is loaded
      thanks ou for your help
        A Former User
        what should apear on loaded ?
        • W
          wirdman
          i have a black screen in my mirror
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js:6:18)
             at Module._compile (internal/modules/cjs/loader.js:786:30)
             at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
             at Module.load (internal/modules/cjs/loader.js:645:32)
          [2020-07-14 16:59:18.379] [ERROR]  Whoops! There was an uncaught exception...
          [2020-07-14 16:59:18.380] [ERROR]  /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js:12
             DetectionResult[DetectionResu.ts",
          SyntaxError: Invalid or unexpected token
             at Module._compile (internal/modules/cjs/loader.js:722:23)
             at Function.Module._load (internal/modules/cjs/loader.js:560:12)
             at Module.require (internal/modules/cjs/loader.js:685:19)
             at require (internal/modules/cjs/helpers.js:16:16)
          [2020-07-14 16:59:18.388] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [2020-07-14 16:59:18.389] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [2020-07-14 16:59:18.557] [LOG]    Launching application.
          • W
            wirdman
            this is my config.js
            		  module: "MMM-GoogleAssistant",
            		  position: "fullscreen_above",
            		    debug: false,
            		    assistantConfig: {
            		      lang: "en-US",
            		      projectId: "", // Required to use gaction.
            		      modelId: "", // (OPTIONAL for gaction)
            		      instanceId: "", // (OPTIONAL for gaction)
            		      latitude: 51.508530,
            		      longitude: -0.076132,
            		    responseConfig: {
            		      useScreenOutput: true,
            		      screenOutputCSS: "screen_output.css",
            		      screenOutputTimer: 5000,
            		      activateDelay: 250,
            		      useAudioOutput: true,
            		      useChime: true,
            		      newChime: false,
            		      useNative: true,
            		      playProgram: "mpg321"
            		    micConfig: { // put there configuration generated by auto-installer
            		      recorder: "arecord",
            		      device: "plughw:2",
            		    customActionConfig: {
            		      autoMakeAction: false,
            		      autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
            		      actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
            		    snowboy: {
            		      audioGain: 2.0,
            		      Frontend: true,
            		      Model: "jarvis",
            		      Sensitivity: null
            		    A2DServer: {
            		      useA2D: false,
            		      stopCommand: "stop"
            		    recipes: [ "with-MMM-TelegramBot.js" ]
            				  module:
              A Former User
              and why you edit snowboy sources ?
              • W
                wirdman
                i dont do
                  sdetweil @wirdman
                  @wirdman said in MMM-GoogleAssistant not running:
                  looks like sd card trouble ahead, make backup NOW… get new card
                  • W
                    wirdman
                    really beceause without google assitant my magic mirror running
                      sdetweil @wirdman
                      @wirdman
                      if you didn’t edit that file yourself, this looks like random file system corruption
                      once it starts, it never gets better
                      SD cards are write once, and then next write that old spaces cannot be reused, so it is marked used and dropped.
                      eventually the card fills up… I have lost 8-10 cards so far over 3 years…
                      • W
                        wirdman
                        i have that in my shelle when i try to run it
                        [2020-07-14 17:13:37.219] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js:12
                        okay i going right now buy a new sd card and i try it again
                          A Former User
                          just for information : original is there
                          so if you don’t edit it
                          Your SD card have a problem
                          • W
                            wirdman
                            okay thanks a lot for you help i going buy a new card a i tell you if it’s working 😃
                            • W
                              wirdman
                              This post is deleted!
                              • W
                                wirdman
                                hey @Bugsounet and @sdetweil
                                i delete it re install it and now is since to work but is not on my mirror
                                here my npm start :
                                > magicmirror@2.12.0 start /home/pi/MagicMirror
                                [2020-07-15 01:23:28.851] [LOG]    Starting MagicMirror: v2.12.0
                                [2020-07-15 01:23:28.867] [LOG]    Loading config ...
                                [2020-07-15 01:23:28.876] [LOG]    Loading module helpers ...
                                [2020-07-15 01:23:28.882] [LOG]    No helper found for module: alert.
                                [2020-07-15 01:23:28.989] [LOG]    Initializing new module helper ...
                                [2020-07-15 01:23:28.991] [LOG]    Module helper loaded: updatenotification
                                [2020-07-15 01:23:28.993] [LOG]    No helper found for module: clock.
                                [2020-07-15 01:23:29.821] [LOG]    Initializing new module helper ...
                                [2020-07-15 01:23:29.823] [LOG]    Module helper loaded: calendar
                                [2020-07-15 01:23:29.824] [LOG]    No helper found for module: compliments.
                                [2020-07-15 01:23:29.826] [LOG]    No helper found for module: currentweather.
                                [2020-07-15 01:23:29.827] [LOG]    No helper found for module: weatherforecast.
                                [2020-07-15 01:23:33.352] [LOG]    Initializing new module helper ...
                                [2020-07-15 01:23:33.355] [LOG]    Module helper loaded: MMM-GoogleAssistant
                                [2020-07-15 01:23:33.358] [LOG]    No helper found for module: MMM-SwissCommute.
                                [2020-07-15 01:23:34.709] [LOG]    Initializing new module helper ...
                                [2020-07-15 01:23:34.711] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
                                [2020-07-15 01:23:34.795] [LOG]    Initializing new module helper ...
                                [2020-07-15 01:23:34.798] [LOG]    Module helper loaded: newsfeed
                                [2020-07-15 01:23:34.799] [LOG]    All module helpers loaded.
                                [2020-07-15 01:23:35.213] [LOG]    Starting server on port 8080 ...
                                [2020-07-15 01:23:35.243] [INFO]   You're using a full whitelist configuration to allow for all IPs
                                [2020-07-15 01:23:35.267] [LOG]    Server started ...
                                [2020-07-15 01:23:35.269] [LOG]    Connecting socket for: updatenotification
                                [2020-07-15 01:23:35.273] [LOG]    Connecting socket for: calendar
                                [2020-07-15 01:23:35.276] [LOG]    Starting node helper for: calendar
                                [2020-07-15 01:23:35.278] [LOG]    Connecting socket for: MMM-GoogleAssistant
                                [2020-07-15 01:23:35.281] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
                                [2020-07-15 01:23:35.284] [LOG]    Connecting socket for: newsfeed
                                [2020-07-15 01:23:35.288] [LOG]    Starting node helper for: newsfeed
                                [2020-07-15 01:23:35.290] [LOG]    Sockets connected & modules started ...
                                [2020-07-15 01:23:35.621] [LOG]    Launching application.
                                [2020-07-15 01:23:41.914] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics - Interval: 300000
                                [2020-07-15 01:23:42.376] [LOG]    Create new news fetcher for url: https://www.lemonde.fr/international/rss_full.xml - Interval: 300000
                                [2020-07-15 01:23:42.532] [INFO]   Checking git for module: MMM-GoogleAssistant
                                [2020-07-15 01:23:42.621] [INFO]   Checking git for module: MMM-SwissCommute
                                [2020-07-15 01:23:42.706] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
                                [2020-07-15 01:23:42.800] [LOG]    [ASSISTANT] MMM-GoogleAssistant Version: 2.2.1
                                [2020-07-15 01:23:42.831] [ERROR]  (node:25329) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                [2020-07-15 01:23:42.835] [ERROR]  (node:25329) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                [2020-07-15 01:23:44.440] [LOG]    Refreshed access token because it has expired. Expired at: 01:23:42 now is: 01:23:44
                                [2020-07-15 01:23:44.509] [LOG]    Refreshed access token because it has expired. Expired at: 02:23:44 now is: 01:23:44
                                [2020-07-15 01:23:45.202] [INFO]   Newsfeed-Fetcher: Broadcasting 20 items.
                                [2020-07-15 01:23:45.224] [LOG]    Refreshed access token because it has expired. Expired at: 02:23:44 now is: 01:23:45
                                [2020-07-15 01:23:47.028] [LOG]    [SNOWBOY] Model selected: jarvis
                                [2020-07-15 01:23:47.042] [LOG]    [SNOWBOY] snowboy v1.5.0 Initialized...
                                [2020-07-15 01:23:47.067] [LOG]    [ASSISTANT] RECIPE_LOADED: with-MMM-TelegramBot.js
                                [2020-07-15 01:23:47.073] [LOG]    [ASSISTANT] Use native program (mpg321) for audio response
                                [2020-07-15 01:23:47.078] [LOG]    [SOUND] mpg321 Initialized
                                [2020-07-15 01:23:47.083] [LOG]    [ASSISTANT] Google Assistant is initialized.
                                [2020-07-15 01:23:48.183] [INFO]   Calendar-Fetcher: Broadcasting 4 events.
                                here my confi.js
                                /* Magic Mirror Config Sample
                                  * MIT Licensed.
                                var config = {
                                        port: 8080,
                                        ipWhitelist: [], // Set [] to allow all IP addresses.
                                        language: "fr",
                                        timeFormat: 24,
                                        units: "metric",
                                                        module: "alert",
                                                        module: "updatenotification",
                                                        position: "top_bar"
                                                        module: "clock",
                                                        position: "top_left"
                                                        header: "Calendrier",
        symbol: "calendar-check-o ",
        url: "https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics"
                                                        module: "compliments",
                                                        position: "lower_third"
                                                        module: "currentweather",
        locationID: "2660646",  //ID from http://www.openweathermap.org/help/city_list.txt
        appid: "a159eb40caad1348cda97718adc69d6d"
                                                        module: "weatherforecast",
                                                        header: "Météo",
                                                        header: "Météo",
        locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
        appid: ""
                                    debug: false,
                                    assistantConfig: {
                                      lang: "en-US",
                                    responseConfig: {
                                      activateDelay: 250,
                                      useChime: true,
                                      newChime: false,
                                      useNative: true,
                                      device: "plughw:2",
                                    snowboy: {
                                      audioGain: 2.0,
                                      Frontend: true,
                                      Model: "jarvis",
                                      Sensitivity: null
                                    A2DServer: {
                                      useA2D: false,
                                      stopCommand: "stop"
                                		module: 'MMM-SwissCommute',
                                		position: 'top_left',
                                		header: 'En Louche',
                                			to: 'Lancy-Bachet', // Destination station
                                			maximumEntries: 4, // Max departures displayed
                                			minWalkingTime: 10 // Minimum time to get to the station
                                				  module: "MMM-NowPlayingOnSpotify",
                                					clientID: "622ad97f8ed24ad9aa3b81531aae033f",
                                					clientSecret: "418079ac53a848679c37ac9613485136",
                                					accessToken: "BQCWLLN5elD8_f9zR7q9947jqCacUYNQ-6RzF8W_R1vx89DVTwkZBjpa1AR89PNw-yLdFziPjg_-hth6WVTPgQvekE5YPnz5ywbBzY0V_TBEa2N1hyucipaXSrmtBx5e2VaFf_SGrjzIkIeeKQ",
                                					refreshToken: "AQA-F5RgN04XC8NP5oOymHEWY_HqW4EwzUCx28GBHfjtLiCf3ordxs55HDxSjy1NwDWJlxthmAVKCRwNUrN3sqDX51JDRVjHP6y6wDnwZ1gs2RJ2tLPwIxJM3SuAgXOAlOk"
                                                        module: "newsfeed",
                                                        position: "lower_third",
        feeds: [
        title: "Le Monde, Paris",
        url: "https://www.lemonde.fr/international/rss_full.xml"
        showSourceTitle: true,
        showPublishDate: true
                                  A Former User
                                  module: “MMM-GoogleAssistant”,
                                  position: “top_right”,
                                  • why top_right and not fullscreen_above position ?
                                  • why recipes: [ "with-MMM-TelegramBot.js" ] if you don’t use TelegramBot module ?
                                  • W
                                    wirdman @Guest
                                    @Bugsounet
                                    hello mon google assistant ne veux plus aller sur youtube depuis la mise à jour
                                    et aussi je ne sais pas pourquoi pour MMM-Spotify j’ai une erreur a la commande
                                    il ne veux pas me donner le token
                                    cd ~/MagicMirror/modules/MMM-Spotify
                                    node first_auth.js
                                    erreur
                                    pi@raspberrypi:~/MagicMirror/modules/MMM-Spotify $ node first_auth.js
                                    internal/modules/cjs/loader.js:638
                                        throw err;
                                    Error: Cannot find module './Spotify.js'
                                        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                        at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                        at Module.require (internal/modules/cjs/loader.js:692:17)
                                        at require (internal/modules/cjs/helpers.js:25:18)
                                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:3:17)
                                        at Module._compile (internal/modules/cjs/loader.js:778:30)
                                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                        at Module.load (internal/modules/cjs/loader.js:653:32)
                                        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                    merci d avance
                                      A Former User
                                      ah oui lol … désolé j’ai oublier de modifier le script avec la nouvelle librairie (bravo !)
                                      Je vais corriger ça de suite !
                                      pour A2D et GA, la commande de mise a jour est npm run update
                                      a executer dans chaque repertoire (GA et A2D)
                                      • W
                                        wirdman @Guest
                                        @Bugsounet
                                        aah je croyais avoir tout cassé 😁😁😁😁
                                          A Former User
                                          non personne est parfait !
                                          Laisse moi 10 min et c’est good ;)
                                            A Former User
                                            voila !
                                            git pull et go !
                                            (et peut etre: npm install… a voir)
                                            • 1 / 3
