    MMM-GoogleAssistant not running
    55 Posts 5 Posters 18.3k Views 5 Watching
    • W Offline
      wirdman @sdetweil
      @sdetweil oh no i didn t know i gonna do that
      • ? Offline
        A Former User
        if you want to use MMM-Spotify:
        npm run spotify step is not needed (only if you want visual)
        npm run librespot is needed only if you want to listen music in mirror
        spotify A2D config should be :
        spotify: {
          useSpotify: true, // because you use and love this sub-module
          useIntegred: false, // if you use MMM-Spotify
          useLibrespot: true, // if you use librespot
          connectTo: "A2D", // set your device name to librespot
          username: "MyUsername", // Spotify username for librespot
          password: "MyPassword, // Spotify password for librespot
        better it’s clear with that ;)
          Mauro-1998
          I also have a problem, I installed everything according to the documentation and it was done correctly, but when I run the application an error appears and the screen goes black. I need help please, thanks.
          Captura de pantalla de 2020-08-01 00-14-11.png Captura de pantalla de 2020-08-01 00-13-56.png
          • ? Offline
            A Former User
            It’s meens that snowboy module is not builded correctly
            I think when you did npm install you should have some errors, right ?
            or maybe you did have no error but you try to do an npm fix command
            what OS do you use ?
              sdetweil @Guest
              @Bugsounet this post
              https://forum.magicmirror.builders/topic/13383/mmm-googleassistant-doesn-t-run
              says running Ubuntu, and note that mm is in a subfolder from the users home folder
              /home/mauro/Escritorio/MagicMirror
              one error posted shows
              cannot find module ./lib/node/index.js error
              • ? Offline
                A Former User
                I have some know issue with ubuntu
                Snowboy don’t want to build
                I have not ubuntu installed to debug it but maybe some package is missing ?
                If someone have a working version in ubuntu, simply contact me for updating script/dependencies
                in all case, It’s ouside the requirement of GA (for this moment)
                • ? Offline
                  A Former User
                  @sdetweil said in MMM-GoogleAssistant not running:
                  it’s meens node_modules/@bugsounet/snowboy/lib/node/index.js don’t exist so ?
                    sdetweil
                    you can use free VMware player to create a single virtual machine of some other os.
                    download the os iso boot disk image, and use VMware player to launch it
                    • ? Offline
                      A Former User
                      humm, yes, I have virtualbox installed on my debian machine, i will try
                        sdetweil @Guest
                        @Bugsounet or on windows as host machine
                        • 6
                        • 5 / 6
