    MMM-GoogleAssistant doesn't run
    20 Posts 6 Posters 6.4k Views 6 Watching
      Mauro-1998
      Hello How are you ?, I was trying to install Google Assistant in my Magic Mirror, according to the tutorial: https://github.com/bugsounet/MMM-GoogleAssistant/wiki/Installation and it was installed correctly, but at the time of testing it comes out a console error and the screen goes black. I need help please, thanks. I am testing it in Ubuntu and the configuration is copied from the page
      Captura de pantalla de 2020-08-01 00-14-11.png Captura de pantalla de 2020-08-01 00-13-56.png
      saljokeS 1 Reply Last reply Reply Quote 0
      • saljokeS Offline
        saljoke @Mauro-1998
        @Mauro-1998
        Hello. Sure is downloaded in modules directory? Retry npm install in MMM-GoogleAssistant directory.
        • ? Offline
          [[global:former-user]]
          wait, I’m installing Ubuntu for debugging ;)
          I will try to do a cross linux platform :p
            Mauro-1998 @saljoke
            @saljoke Yes, here is a photo
              Mauro-1998 @Guest
              @Bugsounet Ok, I will wait, thanks!
              • ? Offline
                @Mauro-1998
                There problem is not there
                The problem is a snowboy library needed by snowboy in main core is not found
                so it’s not an GA issue but a snowboy isssue
                I will install Ubuntu for see what happen
                  Mauro-1998 @Guest
                  @Bugsounet Ok thanks for your help!
                    Mauro-1998 @Guest
                    @Bugsounet
                    Fix the problem by re-installing the snowboy library at @ bugsounet / snowboy, thanks for your help!
                    • ? Offline
                      fixed so ?
                        Mauro-1998 @Guest
                        @Bugsounet
                        yes, install the library again in case it was an installation error and it worked, thanks for your help, it works perfectly!
                          bryan_1 @Mauro-1998
                          @Mauro-1998 hai, could you tell me how you reinstall the snowboy library? I have the same Problem, after installing the GoogleAssistant only black screen :-(
                          Thanks.
                          • ? Offline
                            can help with … reading wiki for example ?
                              bryan_1 @Guest
                              @Bugsounet sorry, I am a beginner. I have installed GoogleAssistant successfully
                              as in Wiki. But when I start MagicMirror, I have only blank screen.
                              • ? Offline
                                @bryan_1 said in MMM-GoogleAssistant doesn't run:
                                for me you have updated the module
                                I have installed GoogleAssistant successfully as in Wiki
                                now you tell me you have just installed
                                Sorry but I don’t know which answer to choose
                                or just maybe i’m stupid !?
                                  bryan_1 @Guest
                                  @Bugsounet I was trying to install Google Assistant in my Magic Mirror, according to the tutorial: https://github.com/bugsounet/MMM-GoogleAssistant/wiki/Installation and it was installed correctly, but at the time of testing it comes out a console error and the screen goes black.
                                  @Mauro-1998 he wrote, that he solved it by reinstalling the snowboy library. That’s why my question.
                                  • ? Offline
                                    Wiki says for installing:
                                    cd ~/MagicMirror/modules
                                    git clone https://github.com/bugsounet/MMM-GoogleAssistant
                                    cd MMM-GoogleAssistant
                                    npm install
                                    I think … you do that ;)
                                    after wiki says :
                                    Don’t forget to do ALL electron-rebuild steps. [You have to respond Y]
                                    No other npm commands are needed after installation (it can broken dependencies package) ! [not other command ! no npm fix, npm audit fix or other]
                                    to solve it try update command:
                                    cd ~/MagicMirror/modules/MMM-GoogleAssistant
                                    npm run update
                                    Note like you see… i just COPY/PAST the wiki …
                                    B C 2 Replies Last reply Reply Quote 0
                                      bryan_1 @Guest
                                      @Bugsounet i did the npm run update, It works now. Thanks a lot…man you’re the best
                                      • ? Offline
                                        @Bugsounet said in MMM-GoogleAssistant doesn't run:
                                        my wiki help ONLY if you want to read it ! ;)
                                        • C Offline
                                          Chethan @Guest
                                          i follow your steps but still am getting error 225
                                          what to do am really upset please help me
                                          the error looks like this
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 255
                                          npm ERR! MMM-GoogleAssistant@ preinstall: installer/preinstall.sh
                                          npm ERR! Exit status 255
                                            sdetweil @Chethan
                                            @chethan the author has left the forums. i have noticed that some of his modules are becoming unstable. either no longer installing or failing to run.
