MMM-GoogleAssistant not running
Tu va etre connu !!! ton nickname est sur le Readme ! ;)
@wirdman : c’est good ?
j ai essayé de voir un peut mais l’assistant fonctionne très bien mais il est incapable de lancer une video youtube ou de contrôler Spotify
en revanche on peut caster sans problème
Merci d’avance pour tout le travail que tu fais
quand je lance une requete :
transcription: { transcription: 'joue les beattles sur youtube', done: true }, continue: false, volume: null, lastQuery: { type: 'MIC', key: null, lang: 'fr-FR', useScreenOutput: true, useAudioOutput: true, status: 'standby', chime: true } }
@Bugsounet hahahaha incroyable pour le readme😁
This morning I noticed that my MMM-GoogleAssistant needed an update, so I updated the module, and now get the black electron screen instead of the Magic Mirror screen. If I removed the module from the config, the Mirror comes up correctly, but when I add my config back, it goes black again. I have tried everything, from removing, then reinstalling, npm rebuild, electron rebuild, and nada. Was working fine until then. Any help would be greatly appreciated. See errors below:
Module helper loaded: MMM-NowPlayingOnSpotify
[2020-07-17 13:07:48.310] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
Expected directory: electron-v6.1-linux-arm-glibc
Found: [node-v72-linux-arm-glibc]
This problem can often be fixed by running “npm rebuild” on the current system
Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc_node.node’
Require stack:- /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js
- /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client_interceptors.js
- /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client.js
- /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/index.js
- /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/google-assistant/components/assistant.js
- /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/google-assistant/index.js
- /home/pi/MagicMirror/modules/MMM-GoogleAssistant/components/assistant.js
- /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
[2020-07-17 13:07:48.311] [LOG] Loading module helpers …
[2020-07-17 13:07:48.313] [LOG] No helper found for module: alert.
[2020-07-17 13:07:48.314] [LOG] Initializing new module helper …
[2020-07-17 13:07:48.314] [LOG] Module helper loaded: updatenotification
[2020-07-17 13:07:48.315] [LOG] No helper found for module: clock.
[2020-07-17 13:07:48.316] [LOG] Initializing new module helper …
[2020-07-17 13:07:48.317] [LOG] Module helper loaded: calendar
[2020-07-17 13:07:48.318] [LOG] No helper found for module: MMM-Rainbow.
[2020-07-17 13:07:48.319] [LOG] No helper found for module: compliments.
[2020-07-17 13:07:48.320] [LOG] Initializing new module helper …
[2020-07-17 13:07:48.320] [LOG] Module helper loaded: MMM-SystemStats
[2020-07-17 13:07:48.321] [LOG] Initializing new module helper …
[2020-07-17 13:07:48.322] [LOG] Module helper loaded: MMM-Remote-Control
[2020-07-17 13:07:48.323] [LOG] No helper found for module: currentweather.
[2020-07-17 13:07:48.324] [LOG] No helper found for module: weatherforecast.
[2020-07-17 13:07:48.325] [LOG] No helper found for module: MMM-EyeCandy.
[2020-07-17 13:07:48.327] [LOG] Initializing new module helper …
[2020-07-17 13:07:48.327] [LOG] Module helper loaded: MMM-NowPlayingOnSpotify
[2020-07-17 13:07:48.352] [ERROR] App threw an error during load
[2020-07-17 13:07:48.354] [ERROR] Error: Failed to load gRPC binary module because it was not installed for the current system
- at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js:53:17)
at Module._compile (internal/modules/cjs/loader.js:786:30)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
at Module.load (internal/modules/cjs/loader.js:645:32)
at Function.Module._load (internal/modules/cjs/loader.js:560:12)
at Module.require (internal/modules/cjs/loader.js:685:19)
at require (internal/modules/cjs/helpers.js:16:16)
at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client_interceptors.js:144:12)
[2020-07-17 13:07:48.356] [ERROR] Whoops! There was an uncaught exception…
[2020-07-17 13:07:48.357] [ERROR] Error: Failed to load gRPC binary module because it was not installed for the current system
Require stack: - /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js
at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10) {
code: ‘MODULE_NOT_FOUND’
[2020-07-17 13:07:48.371] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[2020-07-17 13:07:48.372] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
[2020-07-17 13:07:48.539] [LOG] Launching application.
@blake_northrup said in MMM-GoogleAssistant not running:
do you have run
npm run update
in google assistant folder and Assistant2Display folder ?
have it too but you can
at you mmm-GoogleAssistant folder runnpm install
or
npm rebuild
@wirdman You are the man sir! Much appreciated wirdman!
@blake_northrup did it work ?
@wirdman Yep, all good. I just needed to do npm rebuild in the MMM-GoogleAssistant folder. I was doing it in the MagicMirror folder. Thanks again!
pleasure
