    MMM-GoogleAssistant not running
    55 Posts 5 Posters 22.0k Views 5 Watching
    • W Offline
      wirdman @sdetweil
      this part ? cause i have mmm-spotify
        sdetweil @wirdman
        @wirdman no. the raspotify system extension
        https://pimylifeup.com/raspberry-pi-spotify/
        it is outside mm
        it is required to play Spotify on pi. with or without mm
        • W Offline
          wirdman @sdetweil
          @sdetweil oh no i didn t know i gonna do that
            [[global:former-user]]
            if you want to use MMM-Spotify:
            npm run spotify step is not needed (only if you want visual)
            npm run librespot is needed only if you want to listen music in mirror
            spotify A2D config should be :
            spotify: {
              useSpotify: true, // because you use and love this sub-module
              useIntegred: false, // if you use MMM-Spotify
              useLibrespot: true, // if you use librespot
              connectTo: "A2D", // set your device name to librespot
              username: "MyUsername", // Spotify username for librespot
              password: "MyPassword, // Spotify password for librespot
            better it’s clear with that ;)
              Mauro-1998
              I also have a problem, I installed everything according to the documentation and it was done correctly, but when I run the application an error appears and the screen goes black. I need help please, thanks.
              Captura de pantalla de 2020-08-01 00-14-11.png Captura de pantalla de 2020-08-01 00-13-56.png
                It’s meens that snowboy module is not builded correctly
                I think when you did npm install you should have some errors, right ?
                or maybe you did have no error but you try to do an npm fix command
                what OS do you use ?
                  sdetweil @Guest
                  @Bugsounet this post
                  https://forum.magicmirror.builders/topic/13383/mmm-googleassistant-doesn-t-run
                  says running Ubuntu, and note that mm is in a subfolder from the users home folder
                  /home/mauro/Escritorio/MagicMirror
                  one error posted shows
                  cannot find module ./lib/node/index.js error
                    I have some know issue with ubuntu
                    Snowboy don’t want to build
                    I have not ubuntu installed to debug it but maybe some package is missing ?
                    If someone have a working version in ubuntu, simply contact me for updating script/dependencies
                    in all case, It’s ouside the requirement of GA (for this moment)
                      @sdetweil said in MMM-GoogleAssistant not running:
                      it’s meens node_modules/@bugsounet/snowboy/lib/node/index.js don’t exist so ?
                        you can use free VMware player to create a single virtual machine of some other os.
                        download the os iso boot disk image, and use VMware player to launch it
                          humm, yes, I have virtualbox installed on my debian machine, i will try
                            sdetweil @Guest
                            @Bugsounet or on windows as host machine
                              I’m not an windows user ;(
                                sdetweil @Guest
                                @Bugsounet not a problem. just adding for others, don’t need a Linux host to make a Virtual Machine
                                  I’m making you walk;) I’m installing it!
                                    sdetweil @Guest
                                    @Bugsounet lol. only the drugs ‘make’ me walk!! another month doc says, will feel mostly better!
                                      mouahahah ;)
                                      I think it will not be long too me!
                                      • 3 / 3
