    MMM-GoogleAssistant not running
    55 Posts 5 Posters 22.3k Views 5 Watching
    • W Offline
      wirdman
      @Bugsounet @blake_northrup okay because for me now everything work welle but i cannot ask to my google to play something on spotify
      blake_northrupB S 2 Replies Last reply Reply Quote 0
      • blake_northrupB Offline
        blake_northrup @wirdman
        @wirdman Yeah, I will dig around a bit to see what I can come up with. At least mine is controlling my smart devices, so that works for now. Please let me know if you figure it out, and I will do the same.
          sdetweil @wirdman
          @wirdman can u use the windows Spotify connect to play Spotify on your mirror pi? ( I can)
          you have to install one of the Spotify system extensions to make play on pi work.
          I thought bugsounet said he updated the MMM-Spotify module to do that recently.
          • W Offline
            wirdman @sdetweil
            this part ? cause i have mmm-spotify
              sdetweil @wirdman
              @wirdman no. the raspotify system extension
              https://pimylifeup.com/raspberry-pi-spotify/
              it is outside mm
              it is required to play Spotify on pi. with or without mm
              • W Offline
                wirdman @sdetweil
                @sdetweil oh no i didn t know i gonna do that
                  A Former User
                  if you want to use MMM-Spotify:
                  npm run spotify step is not needed (only if you want visual)
                  npm run librespot is needed only if you want to listen music in mirror
                  spotify A2D config should be :
                  spotify: {
                    useSpotify: true, // because you use and love this sub-module
                    useIntegred: false, // if you use MMM-Spotify
                    useLibrespot: true, // if you use librespot
                    connectTo: "A2D", // set your device name to librespot
                    username: "MyUsername", // Spotify username for librespot
                    password: "MyPassword, // Spotify password for librespot
                  better it’s clear with that ;)
                    Mauro-1998
                    I also have a problem, I installed everything according to the documentation and it was done correctly, but when I run the application an error appears and the screen goes black. I need help please, thanks.
                    Captura de pantalla de 2020-08-01 00-14-11.png Captura de pantalla de 2020-08-01 00-13-56.png
                      A Former User
                      It’s meens that snowboy module is not builded correctly
                      I think when you did npm install you should have some errors, right ?
                      or maybe you did have no error but you try to do an npm fix command
                      what OS do you use ?
                        sdetweil @Guest
                        @Bugsounet this post
                        https://forum.magicmirror.builders/topic/13383/mmm-googleassistant-doesn-t-run
                        says running Ubuntu, and note that mm is in a subfolder from the users home folder
                        /home/mauro/Escritorio/MagicMirror
                        one error posted shows
                        cannot find module ./lib/node/index.js error
                          A Former User
                          I have some know issue with ubuntu
                          Snowboy don’t want to build
                          I have not ubuntu installed to debug it but maybe some package is missing ?
                          If someone have a working version in ubuntu, simply contact me for updating script/dependencies
                          in all case, It’s ouside the requirement of GA (for this moment)
                            A Former User
                            @sdetweil said in MMM-GoogleAssistant not running:
                            it’s meens node_modules/@bugsounet/snowboy/lib/node/index.js don’t exist so ?
                              you can use free VMware player to create a single virtual machine of some other os.
                              download the os iso boot disk image, and use VMware player to launch it
                                A Former User
                                humm, yes, I have virtualbox installed on my debian machine, i will try
                                  sdetweil @Guest
                                  @Bugsounet or on windows as host machine
                                    A Former User
                                    I’m not an windows user ;(
                                      sdetweil @Guest
                                      @Bugsounet not a problem. just adding for others, don’t need a Linux host to make a Virtual Machine
                                        A Former User
                                        I’m making you walk;) I’m installing it!
                                          sdetweil @Guest
                                          @Bugsounet lol. only the drugs ‘make’ me walk!! another month doc says, will feel mostly better!
                                            A Former User
                                            mouahahah ;)
                                            I think it will not be long too me!
                                            • 3 / 3
