    pm2 Autostart invert issue
    Scheduled Pinned Locked Moved Solved Bug Hunt
    32 Posts 4 Posters 11.5k Views 4 Watching
    • EthyxE Offline
      Ethyx
      how do you do that tho?
        sdetweil @Ethyx
        @Ethyx Google is your friend
        https://www.raspberrypi-spy.co.uk/2017/11/how-to-rotate-the-raspberry-pi-display-output/
        EthyxE 2 Replies Last reply Reply Quote 0
        • EthyxE Offline
          Ethyx @sdetweil
          @sdetweil so true
          • EthyxE Offline
            Ethyx @sdetweil
            @sdetweil the issue still persists
              sdetweil @Ethyx
              @Ethyx u set the rotation in /boot/config.txt and rebooted and rotation was changed, yes?
              the remove xrandr from mm.sh
              • EthyxE Offline
                Ethyx @sdetweil
                @sdetweil ok on it
                • EthyxE Offline
                  Ethyx @sdetweil
                  @sdetweil this time even when I give ^q, the screen is not inverted as opposed to last time.
                    sdetweil @Ethyx
                    @Ethyx so the /boot/config.txt didn’t work. read more
                    EthyxE 1 Reply Last reply Reply Quote 0
                    • EthyxE Offline
                      Ethyx @sdetweil
                      @sdetweil yep
                      S EthyxE 2 Replies Last reply Reply Quote 0
                        sdetweil @Ethyx
                        @Ethyx you added
                        display_rotate=2
                        to config.txt, right, and saved it
                        • 2 / 4
