    pm2 Autostart invert issue
    Scheduled Pinned Locked Moved Solved Bug Hunt
    32 Posts 4 Posters 11.9k Views 4 Watching
    • EthyxE Offline
      Ethyx @Ethyx
      @sdetweil yeah and the issue still somehow persists
        sdetweil @Ethyx
        @Ethyx you had to use
        sudo nano /boot/config.txt
        to edit that file, right?
        • EthyxE Offline
          Ethyx
          @sdetweil yes. i followed everything that was on this website.
            sdetweil @Ethyx
            @Ethyx r u running buster?
            try this
            https://pimylifeup.com/raspberry-pi-rotate-screen/
            EthyxE evroomE 2 Replies Last reply Reply Quote 0
            • EthyxE Offline
              Ethyx @sdetweil
              @sdetweil that was the aritcle i referred to before i posted it here and yes i am using buster.
              • evroomE Offline
                evroom @sdetweil
                @sdetweil said in pm2 Autostart invert issue:
                try this
                @Ethyx
                Did you try this?
                display_hdmi_rotate=2
                Make sure you only have one of the options active; not that you rotate a rotated screen. :-)
                MagicMirror version: 2.33.0
                Test environment:
                MagicMirror version: v2.33.0
                  sdetweil @evroom
                  @Ethyx did u try this? in config.txt?
                  • EthyxE Offline
                    Ethyx
                    @evroom @sdetweil Yes. that did not work.
                    • BKeyportB Offline
                      BKeyport Module Developer
                      One thing - are you using a Pi 4? Or the “Fake KMS” drivers? If so, boot.txt won’t work - nor will anything else, really.
                      If the Mirror is running - directly on the pi, or through VNC, Alt-Space, then N. This will give you your desktop. then use your OSKey or the menu icon, go to preferences, and see if “Screen configuration” exists. If it does, set your rotation there, and remove it everywhere else.
                      EthyxE 1 Reply Last reply Reply Quote 1
                      • EthyxE Offline
                        Ethyx @BKeyport
                        @BKeyport I am using a Pi 4 for this matter. I don’t know what a KMS driver is, actually. Screen Configuration does not appear but I use a command that works the same way:
                        DISPLAY=:0 xrandr --output HDMI-1 --rotate inverted
                        • 3 / 4
